Before posting
lv_style_init(&style);
chart = lv_chart_create(src);
lv_style_set_line_width(&style,2);
lv_obj_set_style_bg_opa(chart,LV_OPA_50,LV_PART_SELECTED);
lv_obj_set_size(chart, 200, 150);
lv_obj_center(chart);
lv_chart_set_type(chart, LV_CHART_TYPE_LINE); /*Show lines and points too*/
lv_style_set_bg_opa(&style, LV_OPA_50); /*Max. opa.*/
lv_style_set_bg_color(&style, lv_palette_main(LV_PALETTE_YELLOW));
lv_style_set_bg_grad_color(&style, lv_palette_main(LV_PALETTE_PINK));
lv_style_set_bg_grad_dir(&style, LV_GRAD_DIR_VER);
lv_style_set_bg_main_stop(&style, 255);
lv_style_set_bg_grad_stop(&style, 188);
lv_obj_add_style(chart, &style, 0);
lv_chart_set_series_width(chart,2);
/*Add two data series*/
lv_chart_series_t * ser1 = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_RED), LV_CHART_AXIS_PRIMARY_Y);
lv_chart_series_t * ser2 = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_GREEN), LV_CHART_AXIS_SECONDARY_Y);
/*Add a faded are effect*/
//lv_obj_set_style_local_bg_opa(chart, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, LV_OPA_50); /*Max. opa.*/
//lv_obj_set_style_local_bg_grad_dir(chart, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, LV_GRAD_DIR_VER);
//lv_obj_set_style_local_bg_main_stop(chart, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, 255); /*Max opa on the top*/
//lv_obj_set_style_local_bg_grad_stop(chart, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, 0); /*Transparent on the bottom*/
/*Set the next points on 'ser1'*/
lv_chart_set_next_value(chart, ser1, 31);
lv_chart_set_next_value(chart, ser1, 66);
lv_chart_set_next_value(chart, ser1, 10);
lv_chart_set_next_value(chart, ser1, 89);
lv_chart_set_next_value(chart, ser1, 63);
lv_chart_set_next_value(chart, ser1, 30);
lv_chart_set_next_value(chart, ser1, 70);
lv_chart_set_next_value(chart, ser1, 90);
/*Directly set points on 'ser2'*/
ser2->y_points[0] = 90;
ser2->y_points[1] = 70;
ser2->y_points[2] = 65;
ser2->y_points[3] = 65;
ser2->y_points[4] = 65;
ser2->y_points[5] = 65;
ser2->y_points[6] = 65;
ser2->y_points[7] = 65;
ser2->y_points[8] = 65;
ser2->y_points[9] = 65;
lv_chart_refresh(chart); /*Required after direct set*/
