Version: 8
I found the API lv_chart_set_series_width in the old version, but I didn’t found it in the lv_chart.h or others files in v8.
How to Change the width of the Chart series ? Is there any founctions?
Version: 8
Hi @wnower ,
I believe you should use lv_obj_set_style_line_width(chart, 1, LV_PART_INDICATOR); for a line width of 1 pixel.
See docs here.
Hope that helps.
Kind Regards,
Pete
I’m using lvgl 8.3.8,
It doesn’t change the thickness of the chart series if use 1, 2 or more with following function…
Do I miss something?
lv_obj_set_style_line_width(ui->screen_chart_1, 10, LV_PART_INDICATOR);
