Copy some images to the assets folder in the project’s location
Add widgets, apply styles, add events and create animations to them
Share your experience here
A command-line window is also opened with EdgeLine. We left it visible for debugging purposes.
Please, do not close this window, and if you see any issues take a screenshot of it as well.
If you have any questions, found bugs, have any ideas, please open a new topic here in the EdgeLine category.
was able to load it and sort of run it on linux with wine. login buttons froze up a couple times but after login it seemed to almost work. i might try again on windows to see if at wasnt working past that or i dont have any idea what im doing yet (equally likely)
Thanks for the feedback. We haven’t tested it with Wine.
The “normal” Linux version is almost working, there is only a mystery with the project location selector window. Somehow it randomly freezes
I installed the EE with not problems in my Inspiron i3, 8G RAM, 420G SSD under Windows10. I setup a screen with two panels and some widgets in each in not time, very easy. The only drawback is that, in my PC, drawing and adding new widgets takes a lot of time, a new widget takes 5 seconds in appears once added. Also, it looks like a lot of widgets are missing, I suppose they are under construction.
Wish list:
add a configurable (ON/OFF and points distance) grid to align the objects in the panel
resize the objects from corners without losing the X Y relationship.
Thanks for the feedback. I think because there is no certificate on the installer and the exe.
We will add the certification for the next beta version.
Uh, 5 seconds is really odd. The rendered image is sent to EdgeLine via a localhost port. It shouldn’t be that fast. Maybe it’s also an antivirus issue? Is it faster if you disable your antivirus software?
I agree with that
X/Y are kept according to the selected “Align” mode (see near to the width, height, x, y input fields.)
antivirus blocks the app and url. its strange didnt it?
interesting what have u done in app - that triggers AV.
i am working in C# in visual studio when i am developing app for windows, but ive never got such reaction from AV.
