Before posting
master
branch.- Read the
I followed up PC simulator section and installed Java, Esclipse and MinGW64 in my computer, I tried to test PC simulator, the complier give me some fatal error:
…\lv_drivers\display\fbdev.c:17:10: fatal error: sys/mman.h: No such file or directory
#include <sys/mman.h>
#include <ioctl.h>
it means my system miss “mman.h” and “ioctl.h”
how can I get these files?
and ```
tags:
