Before posting
masterbranch.- Be sure you have checked the relevant part of the documentation.
V8.1
I am input something in textea , when KEY_ENTER is pressed by the keypad, textea recv twice click event when the key press and key release
static void ta_event_cb(lv_event_t * e)
lv_indev_t * indev = lv_indev_get_act();
if(indev == NULL) return;
lv_indev_type_t indev_type = lv_indev_get_type(indev);
lv_obj_t * ta = lv_event_get_target(e);
lv_obj_t * kb = lv_event_get_user_data(e);
if(code == LV_EVENT_CLICKED ) { //&& indev_type == LV_INDEV_TYPE_ENCODER
LV_LOG_USER("disp kb");
lv_keyboard_set_textarea(kb, ta);
lv_obj_clear_flag(kb, LV_OBJ_FLAG_HIDDEN);
// lv_group_focus_obj(kb);
// lv_group_set_editing(lv_obj_get_group(kb), kb);
lv_obj_set_height(tv, LV_VER_RES / 2);
lv_obj_align(kb, LV_ALIGN_BOTTOM_MID, 0, 0);
if(code == LV_EVENT_READY || code == LV_EVENT_CANCEL) {
LV_LOG_USER("hid kb");
lv_obj_add_flag(kb, LV_OBJ_FLAG_HIDDEN);
lv_obj_set_height(tv, LV_VER_RES);
if(code == LV_EVENT_KEY){
LV_LOG_USER("ta key=%d", lv_event_get_key(e));
[A 51.959] [Info] (51.959, +6668) indev_keypad_proc: 10 key is pressed (in lv_indev.c line #412)
[A 51.959] [User] (51.959, +0) ta_event_cb: hid kb (in lv_demo_keypad_encoder.c line #224)
[A 51.961] [User] (51.961, +2) ta_event_cb: ta key=10 (in lv_demo_keypad_encoder.c line #230)
[A 51.963] [Info] (51.963, +2) flex_update: update 0x200b848c container (in lv_flex.c line #211)
[A 51.967] [Info] (51.967, +4) flex_update: update 0x200b8038 container (in lv_flex.c line #211)
[A 51.969] [Info] (51.969, +2) flex_update: update 0x200b8544 container (in lv_flex.c line #211)
[A 51.973] [Info] (51.973, +4) flex_update: update 0x200b8600 container (in lv_flex.c line #211)
[A 51.975] [Info] (51.973, +0) flex_update: update 0x200b848c container (in lv_flex.c line #211)
[A 51.975] [Info] (51.975, +2) flex_update: update 0x200b8038 container (in lv_flex.c line #211)
[A 51.977] [Info] (51.977, +2) flex_update: update 0x200b8878 container (in lv_flex.c line #211)
[A 51.981] [Info] (51.981, +4) flex_update: update 0x200b9558 container (in lv_flex.c line #211)
[A 51.983] [Info] (51.983, +2) flex_update: update 0x200b8544 container (in lv_flex.c line #211)
[A 51.987] [Info] (51.987, +4) flex_update: update 0x200b8600 container (in lv_flex.c line #211)
[A 52.083] [Info] (52.083, +96) indev_keypad_proc: 10 key is released (in lv_indev.c line #496)
[A 52.083] [User] (52.083, +0) ta_event_cb: disp kb (in lv_demo_keypad_encoder.c line #214)
[A 52.087] [Info] (52.087, +4) flex_update: update 0x200b848c container (in lv_flex.c line #211)
[A 52.091] [Info] (52.091, +4) flex_update: update 0x200b8038 container (in lv_flex.c line #211)
[A 52.095] [Info] (52.095, +4) flex_update: update 0x200b8544 container (in lv_flex.c line #211)
[A 52.099] [Info] (52.097, +2) flex_update: update 0x200b8600 container (in lv_flex.c line #211)
[A 52.099] [Info] (52.099, +2) flex_update: update 0x200b848c container (in lv_flex.c line #211)
[A 52.101] [Info] (52.101, +2) flex_update: update 0x200b8038 container (in lv_flex.c line #211)
[A 52.103] [Info] (52.103, +2) flex_update: update 0x200b8878 container (in lv_flex.c line #211)
[A 52.107] [Info] (52.107, +4) flex_update: update 0x200b9558 container (in lv_flex.c line #211)
[A 52.109] [Info] (52.109, +2) flex_update: update 0x200b8544 container (in lv_flex.c line #211)
[A 52.111] [Info] (52.111, +2) flex_update: update 0x200b8600 container (in lv_flex.c line #211)
