yelll
April 24, 2023, 9:05am
1
Before posting
Get familiar with Markdown to format and structure your post
Be sure to update lvgl from the latest version from the master branch.
Be sure you have checked the FAQ and read the relevant part of the documentation .
If applicable use the Simulator to eliminate hardware related issues.
STM32L476RG Board and SSD1327 driver.
v8.3
I’m using
// lv_theme_mono_init(0, false, NULL);
// lv_theme_mono_is_inited();
this function, but I’m not sure what it does.
As you can see here it initializes the styles:
LV_GC_ROOT(_lv_theme_default_styles) = lv_mem_alloc(sizeof(my_theme_styles_t));
styles = (my_theme_styles_t *)LV_GC_ROOT(_lv_theme_default_styles);
theme.disp = disp;
theme.font_small = LV_FONT_DEFAULT;
theme.font_normal = LV_FONT_DEFAULT;
theme.font_large = LV_FONT_DEFAULT;
theme.apply_cb = theme_apply;
style_init(dark_bg, font);
if(disp == NULL || lv_disp_get_theme(disp) == &theme) lv_obj_report_style_change(NULL);
inited = true;
return (lv_theme_t *)&theme;
static void theme_apply(lv_theme_t * th, lv_obj_t * obj)
yelll
April 25, 2023, 12:08am
3
If you look at the blog, you apply that function on a gray scale LCD, why are you doing it?
This tutorial describes how I got LittlevGL working on a small 128x64 OLED display with a PIC24FJ microcontroller. The OLED display board I used had a SH1106 driver chip, but the code would probably work nealry unchanged with an SSD1306, and should...
The blog post is 4 years old and doesn’t apply to the current version of LVGL.
yelll
April 26, 2023, 7:04am
5
However, depending on whether or not that function is used, the area displayed is different. What does that function do?
