V8.x imgbtn clear flag CHECKABLE not working?
Before posting
  • Be sure you have checked the relevant part of the documentation.
Setting checkable to false for an imgbtn in v7 work perfectly, but I have struggled to get the same behavior in v8 by clearing the CHECKABLE flag, ie:
lv_obj_clear_flag(nav_btn_left, LV_OBJ_FLAG_CHECKABLE);
Specifically I do not want the imgbtn to change colors (ie from grey to a lighter grey based on styling) after being pressed. I think this should be working and I am missing something simple.
teensy 4.1
v8.1
Clearing the CHECKABLE flag should prevent an imgbtn from changing based on styling. I can likely override the styling, but it would be cleaner to be able to use the flag.
Clearing the CHECKABLE flag.
Not going to include the image code as it’s kinda large:
#define COLOR_SCR_TEXT lv_color_hex(0xe7e9ec)
#define COLOR_BTN_DIS lv_color_hex3(0x888)
lv_style_t imgbtn_style;
lv_style_init(&imgbtn_style);
lv_style_set_img_recolor_opa(&imgbtn_style, LV_OPA_40);
lv_style_set_img_recolor(&imgbtn_style, COLOR_SCR_TEXT);
lv_obj_t *nav_btn_left = lv_imgbtn_create(NULL);
lv_obj_add_style(nav_btn_left, &imgbtn_style, 0);
lv_obj_set_style_img_recolor(nav_btn_left, COLOR_BTN_DIS, LV_PART_MAIN | LV_IMGBTN_STATE_DISABLED);
With my current grey color it is hard to capture the different colors with a pic.
CHECHKABLE means the object toggles between LV_STATE_DEFAULT and LV_STATE_CHECKED when clicked.
However there is an issue in this line:
It should be
lv_obj_set_style_img_recolor(nav_btn_left, COLOR_BTN_DIS, LV_PART_MAIN | LV_STATE_DISABLED);
Or simple:
lv_obj_set_style_img_recolor(nav_btn_left, COLOR_BTN_DIS, LV_STATE_DISABLED);
Thanks @kisvegabor! Changing to use the LV_STATE_DISABLED enum fixed the issue.
Setting LV_IMGBTN_STATE_DISABLED was the same as setting LV_STATE_FOCUSED, which matches the behavior I was seeing.
Good to hear it works now :slight_smile:
