V8.0 Disable tabview sliding
Before posting
  • Read the
In 6.2 Tabview had an option to disable sliding (lv_tabview_set_sliding), I can’t find it in 8.0 or any way in the documentation to turn this off.
I’m using the simulator.
Disable Tabview Sliding, only changing tabs by clicking the buttons
I have tried lv_obj_set_scrollbar_mode(main_tabview, LV_SCROLLBAR_MODE_OFF);
main_tabview = lv_tabview_create(lv_scr_act(), LV_DIR_TOP, 20);
    lv_obj_set_size(main_tabview, 320, 146);
    lv_obj_set_pos(main_tabview, 0, 24);
    lv_obj_add_flag(lv_tabview_get_tab_btns(main_tabview), LV_OBJ_FLAG_HIDDEN);
	lv_obj_add_style(main_tabview, &cont_style, 0);
    for (i = 0; i < MAX_WIN_ID; i++)
		tab_win[i] = lv_tabview_add_tab(main_tabview, tab_name[i]);
		lv_obj_set_scrollbar_mode(tab_win[i], LV_SCROLLBAR_MODE_OFF);
		tab_win_create[i](tab_win[i]);
        lv_obj_add_style(tab_win[i], &pad_style, 0);
do this:
lv_obj_clear_flag(t1, LV_OBJ_FLAG_SCROLLABLE);
Thank you very much, it has been solved.
One more question, I want to set a button and a list in a tab, I just want the list to slide, but the problem I’m currently having is but when I slide the list, the button will slide with it, how should I fix this problem? Thanks!
I tried using lv_obj_clear_flag in version 8.2 in order to prevent tabview slider.
It did not work. Any other ideas?
Mine v8.3 clear all related flag but no luck the TabView still slidable.
lv_obj_clear_flag( ui_TabView1, LV_OBJ_FLAG_CLICK_FOCUSABLE | LV_OBJ_FLAG_SCROLLABLE | LV_OBJ_FLAG_SCROLL_ELASTIC | LV_OBJ_FLAG_SCROLL_MOMENTUM | LV_OBJ_FLAG_SCROLL_CHAIN );    /// Flags
Version 8.3.6 not working either. Any suggestion?
Found a solution in example lv_example_anim.c:
lv_obj_clear_flag(lv_tabview_get_content(mainTabSet), LV_OBJ_FLAG_SCROLLABLE);
This did it for me :slight_smile:
@Ernst GREATTTT!!! Thanks alot, this solved it for me too! :partying_face:
OK, now we should know that the TabView having its own container child inside, that need to be set flag manually to LV_OBJ_FLAG_SCROLLABLE, not the TabView itself.
I am curious about what more this container can do. I didn’t see anything of this in the manual. LVGL biggest hurdle is, for me, the documentation. However, I like the library a lot.
Hello, if I recall correctly “container” is a name used in Squareline Studio (LVGL editor) and it is basically just an empty base object in which child objects can be placed.
In LVGL, a container would simply be made by creating a base object type: Base object (lv_obj) — LVGL documentation
Visually speaking, this creates a sort of container or panel in which other objects (widgets, etc.) can be placed by making them children of this “container” object.
Anyway, as I mentioned the Tabview having its own container child inside, that need to apply it own LV_OBJ_FLAG_SCROLLABLE flag, if you Ernst want to know how this “container” can do, please look at the structure mentioned on top of the documentation:
https://docs.lvgl.io/8.3/widgets/extra/tabview.html?highlight=tabview
Tabview (lv_tabview)
Overview
The Tab view object can be used to organize content in tabs. The Tab view is built from other widgets:
Thank you for the link to the documentation @tpt.
Of course I’ve read this carefully. It is for a new LVGL user very difficult to discover what part of the tabView constellation is responsible for the scrolling. The flag LV_OBJ_FLAG_SCROLLABLE cannot be found on this page. This leads to uncertainties, are there any other flags introducing unexpected behaviour?
thank your work
