I have a devices which runs a project based on lvgl-V6.0.2 version, and now I update the lvgl library to V8.0.1 and run some demo on it(I display a image and run the docs example lv_example_btn_1()), and I found it has some problem. The image is shown successfully, but the button example, when I clicked the btn , the screen start flashing, and the botton effect seems not occur.
my disp is inited double buffering, is there double buffering has some different between V8.0.1 and V6.0.2
TI ARM335X
I have checked the porting steps from my 6.0.2 version project, it has ported to the 8.0.1version succesfuly. the same initial, the same devices.
/* Example for 3) also set disp_drv.full_refresh = 1 below*/
static lv_disp_draw_buf_t draw_buf_dsc_3;
static lv_color_t buf_3_1[MY_DISP_HOR_RES * MY_DISP_VER_RES]; /*A screen sized buffer*/
static lv_color_t buf_3_2[MY_DISP_HOR_RES * MY_DISP_VER_RES]; /*An other screen sized buffer*/
lv_disp_draw_buf_init(&draw_buf_dsc_3, buf_3_1, buf_3_2, MY_DISP_HOR_RES * MY_DISP_VER_RES); /*Initialize the display buffer*/
* Register the display in LVGL
static lv_disp_drv_t disp_drv; /*Descriptor of a display driver*/
disp_drv.hor_res = MY_DISP_HOR_RES;
disp_drv.ver_res = MY_DISP_VER_RES;
disp_drv.flush_cb = disp_flush;
/*Set a display buffer*/
disp_drv.draw_buf = &draw_buf_dsc_3;
/*Required for Example 3)*/
//disp_drv.full_refresh = 1
/* Fill a memory array with a color if you have GPU.
* Note that, in lv_conf.h you can enable GPUs that has built-in support in LVGL.
* But if you have a different GPU you can use with this callback.*/
//disp_drv.gpu_fill_cb = gpu_fill;
