Before posting
I add the lv_lib_png to my project, and init the file system throw the lv_port_fs_template.c, I filled the fs_open/fs_seek/fs_close/fs_read, and I init the lv_port_fs_init() and lv_png_init,then test the png_decoder_test.png, it shows no data, the png info seems get ok, but it shows error.
arm335x, Linux, use standard IO interface.
v-8.0.1
lv_port_fs_init();
lv_png_init();
//this one shows OK
LV_IMG_DECLARE(png_decoder_test);
lv_obj_t* img_1 = lv_img_create(lv_scr_act());
lv_img_set_src(img_1, &png_decoder_test);
lv_obj_align(img_1, LV_ALIGN_BOTTOM_MID, 0, 0);
//this one shows error
// LV_IMG_DECLARE(png_decoder_test);
lv_obj_t* img_2 = lv_img_create(lv_scr_act());
lv_img_set_src(img_2, "L:/run/storage/mmcblk0p3/png_decoder_test.png");
lv_obj_align(img_2, LV_ALIGN_CENTER, 0, 0);
