I can’t seem to get the touch screen working on ILI9488. I’m trying to run the tpcal.py but when it loads touch won’t register (the countdown from 5 doesn’t decrease).
It’s also possible the screen is not refreshing. I’ve seen other post that had the same problem and solved it by removing MISO on the display but that doesn’t seem to change anything for me. I’v also tried running the display and touch on different SPIs but it gives me an error (It should work on the same bus). When I touch the display I can see the IRQ pin go to 0V, which means the hardware is working.
I made sure to use the newest version of lv_micropython and update the submodules. Is it possible I’m using the wrong version? Normally I don’t like asking for help but I’v been at it for days and don’t know what else to try. I even bought another ILI9488 but it has the same problem.
The code I’m using is below:
import sys
sys.path.append('')
import espidf as esp
import lvgl as lv
lv.init()
from ili9XXX import ili9488
disp = ili9488(miso=19, mosi=23, clk=18, cs=4, dc=15, rst=2, spihost=esp.VSPI_HOST, mhz=40, factor=32, hybrid=True, width=320, height=480,
invert=False, double_buffer=True, half_duplex=True)
HRES = lv.scr_act().get_disp().driver.hor_res
VRES = lv.scr_act().get_disp().driver.ver_res
from xpt2046 import xpt2046
touch = xpt2046(cs=21, spihost=esp.VSPI_HOST,cal_x0=0, cal_x1 = HRES, cal_y0=0, cal_y1 = VRES, transpose=True)
class Tpcal_point():
def __init__(self, x, y, name):
self.display_coordinates = lv.point_t({'x': x, 'y': y})
self.touch_coordinate = None
self.name = name
def __repr__(self):
return "%s: (%d, %d)" % (self.name,
self.touch_coordinate.x,
self.touch_coordinate.y)
# Calibration helper class
class Tpcal():
# Create a screen with a button and a label
CIRCLE_SIZE = const(20)
CIRCLE_OFFSET = const(20)
TP_MAX_VALUE = const(10000)
LV_COORD_MAX = const((1 << (8 * 2 - 1)) - 1000)
LV_RADIUS_CIRCLE = const(LV_COORD_MAX) # TODO use lv.RADIUS_CIRCLE constant when it's available!
def __init__(self, points, calibrate, touch_count = 5):
self.points = points
self.calibrate = calibrate
self.touch_count = touch_count
self.med = [lv.point_t() for i in range(0,self.touch_count)] # Storage point to calculate median
self.cur_point = 0
self.cur_touch = 0
self.scr = lv.obj(None)
self.scr.set_size(TP_MAX_VALUE, TP_MAX_VALUE)
lv.scr_load(self.scr)
# Create a big transparent button screen to receive clicks
style_transp = lv.style_t()
style_transp.init()
style_transp.set_bg_opa(lv.OPA.TRANSP)
self.big_btn = lv.btn(lv.scr_act())
self.big_btn.set_size(TP_MAX_VALUE, TP_MAX_VALUE)
self.big_btn.add_style(style_transp, lv.PART.MAIN)
#self.big_btn.set_layout(lv.LAYOUT.OFF)
self.big_btn.add_event_cb(lambda event, self=self: self.calibrate_clicked(),lv.EVENT.CLICKED, None)
# Create the screen, circle and label
self.label_main = lv.label(lv.scr_act())
style_circ = lv.style_t()
style_circ.init()
style_circ.set_radius(LV_RADIUS_CIRCLE)
self.circ_area = lv.obj(lv.scr_act())
self.circ_area.set_size(CIRCLE_SIZE, CIRCLE_SIZE)
self.circ_area.add_style(style_circ, lv.STATE.DEFAULT)
self.circ_area.clear_flag(lv.obj.FLAG.CLICKABLE) # self.circ_area.set_click(False)
self.show_circle()
def show_text(self, txt):
self.label_main.set_text(txt)
# self.label_main.set_align(lv.label.ALIGN.CENTER)
self.label_main.set_pos((HRES - self.label_main.get_width() ) // 2,
(VRES - self.label_main.get_height()) // 2)
def show_circle(self):
point = self.points[self.cur_point]
self.show_text("Click the circle in\n" + \
point.name + "\n" + \
"%d left" % (self.touch_count - self.cur_touch))
if point.display_coordinates.x < 0: point.display_coordinates.x += HRES
if point.display_coordinates.y < 0: point.display_coordinates.y += VRES
# print("Circle coordinates: x: %d, y: %d"%(point.display_coordinates.x - self.CIRCLE_SIZE // 2,
# point.display_coordinates.y - self.CIRCLE_SIZE // 2))
self.circ_area.set_pos(point.display_coordinates.x - CIRCLE_SIZE // 2,
point.display_coordinates.y - CIRCLE_SIZE // 2)
def calibrate_clicked(self):
indev = lv.indev_get_act()
indev.get_point(self.med[self.cur_touch])
# print("calibrate_clicked: x: %d, y: %d"%(self.med[self.cur_touch].x,self.med[self.cur_touch].y))
self.cur_touch += 1
if self.cur_touch == self.touch_count:
med_x = sorted([med.x for med in self.med])
med_y = sorted([med.y for med in self.med])
x = med_x[len(med_x) // 2]
y = med_y[len(med_y) // 2]
point.touch_coordinate = lv.point_t({
'x': x,
'y': y})
self.cur_point += 1
self.cur_touch = 0
if self.cur_point == len(self.points):
self.calibrate(self.points)
self.cur_point = 0
self.show_text("Click/drag on screen\n" + \
"to check calibration")
self.big_btn.set_event_cb(lambda event, self=self: self.check(), lv.EVENT.PRESSING, None)
else:
self.show_circle()
def check(self):
point = lv.point_t()
indev.get_point(point)
# print("click position: x: %d, y: %d"%(point.x,point.y))
self.circ_area.set_pos(point.x - CIRCLE_SIZE // 2,
point.y - CIRCLE_SIZE // 2)
# Calculate calibration, and calibrate
def calibrate(points):
visual_width = points[1].display_coordinates.x - points[0].display_coordinates.x
visual_height = points[1].display_coordinates.y - points[0].display_coordinates.y
touch_width = points[1].touch_coordinate.x - points[0].touch_coordinate.x
touch_height = points[1].touch_coordinate.y - points[0].touch_coordinate.y
pixel_width = touch_width / visual_width
pixel_height = touch_height / visual_height
x0 = points[0].touch_coordinate.x - points[0].display_coordinates.x * pixel_width
y0 = points[0].touch_coordinate.y - points[0].display_coordinates.y * pixel_height
x1 = points[1].touch_coordinate.x + (HRES - points[1].display_coordinates.x) * pixel_width
y1 = points[1].touch_coordinate.y + (VRES - points[1].display_coordinates.y) * pixel_height
print("Calibration result: x0=%d, y0=%d, x1=%d, y1=%d" % (round(x0), round(y0), round(x1), round(y1)))
touch.calibrate(round(x0), round(y0), round(x1), round(y1))
# Run calibration
tpcal = Tpcal([
Tpcal_point(20, 20, "upper left-hand corner"),
Tpcal_point(-40, -40, "lower right-hand corner"),
], calibrate)
# while True:
# pass
Using NodeMCU ESP32 (ESP32 wroom 32 dev board)
Commands to make lv_micropython in Ubuntu 20.04.2.0:
git clone https://github.com/lvgl/lv_micropython.git
cd lv_micropython
git submodule update --init --recursive
cd ports/esp32
make submodules
make LV_CFLAGS="-DLV_COLOR_DEPTH=32"
make erase
make deploy
