I connected a 3.5in ili9488 TFT with xpt2046 to the esp32 wrover, the display itself worked fine, but it didn’t respond to the touch at all.
The test code I used was a touch calibration script which I used last year with LVGL V6 on an ili9341 TFT with xpt2046 touch controller. I only modified the code a little bit since some API’s been changed in V7, but it didn’t work out this time, as mentioned, display was good but not responding to my touch, and no errors showed either. Wiring double checked.
I measured the voltage between the touch irq pin and the ground, it dropped when I touch the screen, so the hardware was functioning.
It’s strange as last time when I worked with V6 it was very straight forward…
Where should I start to trouble shoot? BTW, I have zero background in C programming, I don’t think I can test the C driver…
This is the touch calibration script I used to test the screen.
import machine
import ujson
import utime
import lvgl as lv
import lvesp32
class TouchCali:
def __init__(self, xpt2046_obj, cali_json_path='touch_cali.json'):
self.touch_obj = xpt2046_obj
self.cali_json_path = cali_json_path
self.cali_counter = 0
self.touch_cali_scr = lv.obj()
self.touch_cali_scr.set_click(True)
self.scr_width = self.touch_obj.screen_width
self.scr_height = self.touch_obj.screen_height
self.marker_pos = [
(int(self.scr_width * 0.6), int(self.scr_height * 0.4)),
(int(self.scr_width * 0.1), int(self.scr_height * 0.1)),
(int(self.scr_width * 0.9), int(self.scr_height * 0.1)),
(int(self.scr_width * 0.1), int(self.scr_height * 0.9)),
(int(self.scr_width * 0.9), int(self.scr_height * 0.9)),
(int(self.scr_width * 0.4), int(self.scr_height * 0.6)),
self.marker_x, self.marker_y = self.marker_pos[self.cali_counter]
self.marker_x_coords = []
self.marker_y_coords = []
self.raw_x_coords = []
self.raw_y_coords = []
self.marker_label = lv.label(self.touch_cali_scr)
self.marker_label.set_recolor(True)
self.marker_label.set_text('#FF0000 ' + lv.SYMBOL.PLUS + '#')
# self.marker_label.align_origo(self.touch_cali_scr, lv.ALIGN.IN_TOP_LEFT, self.marker_x, self.marker_y)
self.marker_label.align_mid(self.touch_cali_scr, lv.ALIGN.IN_TOP_LEFT, self.marker_x, self.marker_y)
# text_style = lv.style_t()
# lv.style_copy(text_style, lv.style_transp_tight)
# text_style.text.font = lv.font_roboto_12
self.text_label = lv.label(self.touch_cali_scr)
# self.text_label.set_style(lv.label.STYLE.MAIN, text_style)
# text_label.align(cali_scr, lv.ALIGN.IN_TOP_LEFT, marker_x, marker_y)
self.text_label.set_align(lv.label.ALIGN.CENTER)
self.text_label.set_recolor(True)
self.text_label.set_text('Click the marker\nto calibrate.')
# self.text_label.align_origo(self.touch_cali_scr, lv.ALIGN.CENTER, 0, 0)
self.text_label.align_mid(self.touch_cali_scr, lv.ALIGN.CENTER, 0, 0)
def start(self):
self.touch_cali_scr.set_event_cb(self.touch_cali_handler)
lv.scr_load(self.touch_cali_scr)
def touch_cali_handler(self, obj, event):
print(event)
if event == lv.EVENT.PRESSED:
if self.touch_obj.transpose:
raw_y, raw_x = self.touch_obj.get_med_coords(3)
else:
raw_x, raw_y = self.touch_obj.get_med_coords(3)
self.raw_x_coords.append(raw_x)
self.raw_y_coords.append(raw_y)
self.marker_x_coords.append(self.marker_x)
self.marker_y_coords.append(self.marker_y)
# globals()['coord_' + str(cali_counter)] = lv.label(cali_scr)
# globals()['coord_' + str(cali_counter)].align(cali_scr, lv.ALIGN.IN_TOP_LEFT, marker_x, marker_y)
# globals()['coord_' + str(cali_counter)].set_text('Raw_X: {}\nRaw_Y: {}'.format(raw_x, raw_y))
if self.cali_counter < len(self.marker_pos) - 1:
self.cali_counter += 1
else:
self.marker_label.set_hidden(True)
self.text_label.set_text('#16A000 Calibration Done!#\n#16A000 Click the screen to reboot.#')
print('calibration done.')
self.touch_cali_result()
utime.sleep_ms(300)
lambda obj, event: machine.reset() if event == lv.EVENT.PRESSED else None)
def touch_cali_result(self):
cal_x0_list = []
cal_x1_list = []
cal_y0_list = []
cal_y1_list = []
counter = len(self.raw_x_coords) // 2
for i in range(counter * 2):
if i % 2 == 0:
x1 = (-self.scr_width * self.raw_x_coords[i] + self.raw_x_coords[i] * self.marker_x_coords[
i + 1] + self.scr_width *
self.raw_x_coords[i + 1] - self.raw_x_coords[i + 1] * self.marker_x_coords[i]) \
(-self.marker_x_coords[i] + self.marker_x_coords[i + 1])
x0 = (self.scr_width * self.raw_x_coords[i] - self.marker_x_coords[i] * x1) \
(self.scr_width - self.marker_x_coords[i])
y1 = (-self.scr_height * self.raw_y_coords[i] + self.raw_y_coords[i] * self.marker_y_coords[
i + 1] + self.scr_height *
self.raw_y_coords[
i + 1] - self.raw_y_coords[i + 1] * self.marker_y_coords[i]) \
(-self.marker_y_coords[i] + self.marker_y_coords[i + 1])
y0 = (self.scr_height * self.raw_y_coords[i] - self.marker_y_coords[i] * y1) \
(self.scr_height - self.marker_y_coords[i])
cal_x0_list.append(x0)
cal_x1_list.append(x1)
cal_y0_list.append(y0)
cal_y1_list.append(y1)
cal_x0 = int(sum(cal_x0_list) / len(cal_x0_list))
cal_x1 = int(sum(cal_x1_list) / len(cal_x1_list))
cal_y0 = int(sum(cal_y0_list) / len(cal_y0_list))
cal_y1 = int(sum(cal_y1_list) / len(cal_y1_list))
print('cal_x0 = {}; cal_x1 = {};'.format(cal_x0, cal_x1))
print('cal_y0 = {}; cal_y1 = {};'.format(cal_y0, cal_y1))
with open(self.cali_json_path, 'w') as f:
data = {
'cal_x0': cal_x0,
'cal_x1': cal_x1,
'cal_y0': cal_y0,
'cal_y1': cal_y1,
try:
ujson.dump(data, f)
except:
print('Error occurs when saving calibration results.')
else:
print('Calibration params saved.')
This is the pin configuration.
# The VCC & LED pins of the TFT are directly connected to 3.3V pin of the dev board
TFT_CS_PIN = const(13)
TFT_SCK_PIN = const(19)
TFT_MOSI_PIN = const(18)
TFT_MISO_PIN = const(23)
TFT_DC_PIN = const(26)
TFT_RST_PIN = const(4)
TFT_WIDTH_PX = const(480)
TFT_HEIGHT_PX = const(320)
TFT_PORTRAIT = const(0x40) # See line 54 in driver file ili9XXX.py
TFT_LANDSCAPE = const(0x20) # See line 55 in driver file ili9XXX.py
TFT_ROT = TFT_LANDSCAPE
# The XPT2046 touch controller shares the same SPI bus with the TFT screen
TOUCH_CS_PIN = const(25)
TOUCH_TRANSPOSE = TFT_ROT == TFT_PORTRAIT
TOUCH_CALI_FILE = 'touch_cali.json' # json file used to store touch calibration params
This is the main.py
import lvgl as lv
import lvesp32
import ujson
import uos
from ili9XXX import ili9488
from xpt2046 import xpt2046
from config import *
lv.init()
disp = ili9488(
cs=TFT_CS_PIN,
clk=TFT_SCK_PIN,
mosi=TFT_MOSI_PIN,
miso=TFT_MISO_PIN,
dc=TFT_DC_PIN,
rst=TFT_RST_PIN,
width=TFT_WIDTH_PX,
height=TFT_HEIGHT_PX,
rot=TFT_ROT,
power=-1,
backlight=-1,
touch_args = dict()
touch_args['cs'] = TOUCH_CS_PIN
touch_args['transpose'] = TOUCH_TRANSPOSE
file_list = uos.listdir()
if TOUCH_CALI_FILE in file_list:
with open(TOUCH_CALI_FILE, 'r') as f:
cali_params_dict = ujson.load(f)
touch_args.update(cali_params_dict)
touch = xpt2046(**touch_args)
if TOUCH_CALI_FILE not in file_list:
from touch_cali import TouchCali
touch_cali = TouchCali(touch, TOUCH_CALI_FILE)
touch_cali.start()
else:
scr = lv.obj()
btn = lv.btn(scr)
btn.align(lv.scr_act(), lv.ALIGN.CENTER, 0, 0)
label = lv.label(btn)
label.set_text("Hello World!")
# Load the screen
lv.scr_load(scr)
