Trying to use the fade in function but doesn't work
Before posting
  • Be sure you have checked the relevant part of the documentation. We will not respond in detail to posts where you haven’t read the relevant documentation.
ESP32, 2.8 TFT Display ILI9341 , Arduino IDE
Version 7.1
I want to make a scenario of fading in and out a label
i’ve tried to implement the lv_obj_fade_in() function but it doesn’t work
  lv_obj_t * Lora_label = lv_label_create(lv_scr_act(), NULL);
  lv_label_set_text(Lora_label, "LoRA");
  lv_obj_add_style(Lora_label, LV_OBJ_PART_MAIN, &bootstyle);
  lv_obj_align(Lora_label, NULL, LV_ALIGN_CENTER, -26, 0);
  lv_obj_fade_in(Lora_label,1000,0);
Hi @Ryan_Gania,
Do you have LV_USE_ANIMATION enabled in your lv_conf.h file?
If you do and it still doesn’t work could you share the bootstyle initialisation code please…
Kind Regards,
Pete
Resolved this problem by putting the label on a page object then apply the lv_obj_fade_in to the page object. The lv_obj_fade_in doesn’t seem to work with labels
  static lv_style_t bootbgstyle;
  lv_style_init(&bootbgstyle);
  lv_style_set_bg_opa(&bootbgstyle, LV_STATE_DEFAULT, LV_OPA_TRANSP);
  lv_style_set_border_opa(&bootbgstyle, LV_STATE_DEFAULT, LV_OPA_0);
  lv_obj_t * bootpage = lv_page_create(lv_scr_act(), NULL);
  lv_obj_set_size(bootpage, 240, 70);
  lv_obj_align(bootpage, NULL, LV_ALIGN_CENTER, 0, 0);
  lv_page_set_scrlbar_mode(bootpage, LV_SCRLBAR_MODE_HIDE);
  lv_obj_add_style(bootpage, LV_OBJ_PART_MAIN, &bootbgstyle);
  LV_FONT_DECLARE(unbutton);
  static lv_style_t bootstyle;
  lv_style_init(&bootstyle);
  lv_style_set_text_font(&bootstyle, LV_STATE_DEFAULT, &unbutton);
  lv_obj_t * Lora_label = lv_label_create(bootpage, NULL);
  lv_label_set_recolor(Lora_label, true);
  lv_label_set_text(Lora_label, "#FFFFFF LoRA#");
  lv_obj_t * AIS_label = lv_label_create(bootpage, NULL);
  lv_label_set_recolor(AIS_label, true);
  lv_label_set_text(AIS_label, "#FF0000 AIS#");
  lv_obj_add_style(AIS_label, LV_OBJ_PART_MAIN, &bootstyle);
  lv_obj_align(AIS_label, NULL, LV_ALIGN_CENTER, 50, 0);
  lv_obj_fade_in(bootpage,1000,0);
Right now I’m trying to combined this bootup logo with my main menu. Any suggestion to do this?
Hi @Ryan_Gania,
I would have your boot logo in a function, add a delay at the end of your code above for how long you want it to display for, add code in the function after the delay to delete the objects used for the boot logo and have the function call your main menu code which I would also put in a separate function. Then at startup just call your boot logo function and it will then start the menu for you.
Hope that helps…
Kind Regards,
Pete
I add delay between functions but at boot the screen doesn’t display anything then right after the delay ends the screen display the mainmenu() function.
  start_boot();
  delay(3000);
  mainmenu();
Hi @Ryan_Gania,
Please try this:
  start_boot();
  for( int i=0; i < 600; i++ ){
      lv_task_handler();
      delay(5);
  mainmenu();
Kind Regards,
Pete
This works amazing! Thank you very much!
You are welcome!
Please can you mark the post as the solution, Thank you.
Kind Regards,
Pete
