I have a custom ESP32-S3 board with a 5 inch 800 x 480 RGB display using an Arduino environment. Screen is using buttons and sliders. Original board used a GT911 touch controller.
This worked flawlessly using Arduino GFX and TASM911 driver. New display uses a FT5446 touch screen controller. Display works fine, but touches are not registered reliably and slowly.
Before posting
