Before posting
masterbranch.- Be sure you have checked the relevant part of the documentation.
In my programming, I create some timers. but it exists a strange situation between 2 particular timers(maybe there are some connections). For details, a timer called A is running,
the A timer period is 1 second and it will get the Linux system time and show it in the screen. So it should updates per second. Then I start the timer B, B’s period is also 1s, timer B is to read some record files and to show 10 records. The strange things occured, if I resume the timer B, the timer A’s period seems changed to 5s, so the display updates per 5 seconds. If I stop the timer B, the timer A runs OK again. Actually, I create other timers and make sure each time there are 2 timers is running(A and other one). And only when timer A and B is runing , the timer A affected. It puzzles me a lot. Because the same timer design is runs well in LVGL V 6.0.2.
v8.0.1
/* this is timer A */
static void TimeRefresh1sTaskCallBack(lv_timer_t* timer)
/* get system alarm events */
GetAllEvents(&g_Event.HMIEvent);
RefreshHeadBarStatus();
g_Event.LastEventCnt = g_Event.HMIEvent.cnt;
/* 清除缓存 */
memset(s_MenuBarRuntime.YMDCache, 0, sizeof(s_MenuBarRuntime.YMDCache));
memset(s_MenuBarRuntime.DMSCache, 0, sizeof(s_MenuBarRuntime.DMSCache));
/* get time*/
time_t time_seconds = time(0);
localtime_r(&time_seconds, &nowTime);
snprintf(s_MenuBarRuntime.YMDCache, MAX_HMI_STRLEN, "%02d-%02d-%02d",
nowTime.tm_year + 1900, nowTime.tm_mon + 1, nowTime.tm_mday);
snprintf(s_MenuBarRuntime.DMSCache, MAX_HMI_STRLEN, "%02d:%02d:%02d",
nowTime.tm_hour, nowTime.tm_min, nowTime.tm_sec);
/*update the timer label, it should update per second*/
lv_label_set_text_static(s_MenuBarObj.YearMonthDay, s_MenuBarRuntime.YMDCache);
lv_label_set_text_static(s_MenuBarObj.HourMinSec, s_MenuBarRuntime.DMSCache);
lv_obj_align_to(s_MenuBarObj.YearMonthDay, lv_scr_act(),
LV_ALIGN_BOTTOM_LEFT, 10, 0);
lv_obj_align_to(s_MenuBarObj.HourMinSec, lv_scr_act(),
LV_ALIGN_BOTTOM_LEFT, 18, -20);
/* this is timer B */
static void soe_time_cb(lv_timer_t* timer)
if (!s_soeRun.soeReq)
uint32_t tmpNum = s_soeRun.soeNum;
GetSOETotal(&tmpNum);
/* record updates */
if (tmpNum != s_soeRun.soeNum)
s_soeRun.soeNum = tmpNum;
EnableSOERefreshTask();
return;
return;// at most time, the timer will execute here and return ,the code below will not execute
/* 如果是发了但是还未收到回复的话,则不需要再度更新SOE数目 */
GET_STATUS_T ret = GetSOE(&g_SOE);
/* 更新收到的话则刷新表格 */
if (GET_OK_UPDATED == ret)
/* 重新计算总页面数并发送SOE请求消息队列 */
UpdateSOETotPage();
/* 接收到SOE信息后再重置按钮,从而保持数据刷新和控件显示同步 */
RefreshSOEPageInfo();
ShowSOEPageCtrlBtn();
RefreshShowSOETbl();
s_soeRun.soeReq = false;
/* 未更新成功需要进行处理 */
s_soeRun.soeUpdateErrCnt++;
/* 如果10s都没有更新成功,结束本次更新,重新获取SOE的总数 */
if (s_soeRun.soeUpdateErrCnt > 10)
s_soeRun.soeUpdateErrCnt = 0;
