Tile view endless scroll?
Before posting
  • Be sure you have checked the relevant part of the documentation. We will not respond in detail to posts where you haven’t read the relevant documentation.
i making a smartwatch GUI. require endless scroll screen. i think tileview is the best widget fit to my requirement.
but i don’t know ho to make it scroll.
i mean, example i have 3 screen, s1, s2 and s3. when reach to s3 i want scroll back to s1.
… S3 ↔ S1 ↔ S2 ↔ S3 ↔ S1 …
simulator
v7.4.0
i make 3 screen, when scroll reach to s3, scroll to s1.
i try with tabview and tileview. i didn’t found any related question when search with google.
i workaround with set lv_tileview_set_tile_act when drag_begin in S3. it can jump to S1 but not meet the requirement (S3 to S1 with animation).
thank you
The tileview doesn’t support infinite scrolling.
@guoweilkd appears to have designed a new version of the tileview that does support this feature here, however, there is no code available at the moment.
thank you for reply.
how about tabview ? can tabview infinite scrolling ?
base on your plan, when will you release the infinite scrolling version ?
many thank your hardwork. :heart_eyes:
The tabview doesn’t support infinite scrolling at the moment either. It’s not the first time we’ve been asked about the feature - the main reason it isn’t implemented is because a full implementation requires extra logic to redraw objects at the beginning and end of the tabview. Currently we’re focused on streamlining the widget selection for the long term so I don’t see this being implemented within the next 3-6 months.
