This is a problem with the position of tick text on the chart
Before posting
  • Be sure you have checked the relevant part of the documentation.
The position and tick length of the tick text of the chart are not as desired.
and I want to change the line thickness of the chart series to 1 pixel.
Visual studio 2019 simmulator
7.10
I want it to look like the right side of the attached picture.
   chart_one = lv_chart_create(lv_scr_act(), NULL);
    lv_obj_set_size(chart_one, 460, 200);
    lv_obj_align(chart_one, NULL, LV_ALIGN_IN_TOP_MID, 0, +50);
    lv_chart_set_type(chart_one, LV_CHART_TYPE_LINE);
    lv_chart_set_range(chart_one, 0, 100);
lv_obj_set_style_local_value_font(chart_one, LV_CHART_PART_BG, LV_STATE_DEFAULT, lv_theme_get_font_subtitle());
    lv_obj_set_style_local_value_align(chart_one, LV_CHART_PART_BG, LV_STATE_DEFAULT, LV_ALIGN_OUT_TOP_MID);
    lv_obj_set_style_local_value_ofs_x(chart_one, LV_CHART_PART_BG, LV_STATE_DEFAULT, 10 /*LV_DPI / 20*/);
    lv_obj_set_style_local_value_color(chart_one, LV_CHART_PART_BG, LV_STATE_DEFAULT, LV_COLOR_YELLOW);
    lv_obj_set_style_local_value_str(chart_one, LV_CHART_PART_BG, LV_STATE_DEFAULT, "Chart_1");
    lv_obj_set_style_local_value_font(chart_one, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, lv_theme_get_font_small());
    lv_obj_set_style_local_bg_opa(chart_one, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, LV_OPA_COVER); /*Max. opa.*/
    lv_obj_set_style_local_bg_grad_dir(chart_one, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, LV_GRAD_DIR_VER);
    lv_obj_set_style_local_bg_main_stop(chart_one, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, 100);    /*Max opa on the top*/
    lv_obj_set_style_local_bg_grad_stop(chart_one, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, 0);
    lv_obj_set_style_local_pad_bottom(chart_one, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, 60);
    lv_obj_set_style_local_pad_left(chart_one, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, 40);
    lv_chart_set_y_tick_length(chart_one, 5, 0);
    lv_chart_set_x_tick_length(chart_one, 5, 0);
    lv_obj_set_style_local_bg_opa(chart_one, LV_CHART_PART_SERIES_BG, LV_STATE_DEFAULT, LV_OPA_20);
    lv_obj_set_style_local_bg_color(chart_one, LV_CHART_PART_SERIES_BG, LV_STATE_DEFAULT, LV_COLOR_RED);
    lv_chart_set_div_line_count(chart_one, 0, 0);
    lv_obj_set_style_local_border_width(chart_one, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, 0);
    lv_obj_set_style_local_outline_width(chart_two, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, 0);
    lv_obj_set_style_local_radius(chart_one, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, 0);
    // lv_chart_set_margin(chart_one, 40);
    lv_chart_set_point_count(chart_one, 100);
    lv_chart_set_update_mode(chart_one, LV_CHART_UPDATE_MODE_CIRCULAR);
    lv_chart_set_y_tick_texts(chart_one, "100\n80\n60\n40\n20\n0\n", 0, LV_CHART_AXIS_DRAW_LAST_TICK);
    lv_chart_set_x_tick_texts(chart_one, "0\n5\n10\n15\n20\n25\n30\n", 0, LV_CHART_AXIS_DRAW_LAST_TICK);
    lv_obj_set_style_local_line_dash_gap(chart_one, LV_CHART_PART_SERIES, LV_STATE_DEFAULT, 0);
Solved,
I modified the code to look like this
lv_chart_set_y_tick_texts(chart_one, “100\n80\n60\n40\n20\n0”, 0, LV_CHART_AXIS_DRAW_LAST_TICK);
thanks.
