I run the demo using LV_SYMBOL* in label, but i can’t see it…Can you tell me why? Please…
I use V7, maybe the “lv_theme_material” influences it?
Hi @Lucas.Liao,
Can you share some of your code please, so we can see how you are doing things?
Also are you using the built-in fonts or your own created with the font converter? If you have created your own fonts, you need to be sure to add the symbols when you create the fonts.
Kind Regards,
Pete
Hi @pete-pjb ,
I only use the built-in fonts, thanking you for your answer anyway.
lv_obj_t * btn;
btn = lv_btn_create(parent,NULL);
lv_obj_set_size(btn,320,40);
lv_obj_set_pos(btn, 0, 0);
lv_obj_t * title_label = lv_label_create(btn,NULL);
lv_label_set_text(title_label,LV_SYMBOL_LEFT" Test");
//lv_label_set_align(title_label,LV_LABEL_ALIGN_RIGHT);
//lv_btn_set_layout(btn,LV_LAYOUT_ROW_MID);
lv_obj_t * list = lv_list_create(parent, NULL);
lv_list_set_scroll_propagation(list, true);
lv_obj_set_size(list, 320, 200);
lv_obj_set_pos(list,0,40);
const char * txts[] = {LV_SYMBOL_SAVE, "Save", LV_SYMBOL_CUT, "Cut", LV_SYMBOL_COPY, "Copy",
LV_SYMBOL_OK, "This is a quite long text to scroll on the list", LV_SYMBOL_EDIT, "Edit", LV_SYMBOL_WIFI, "Wifi",
LV_SYMBOL_BLUETOOTH, "Bluetooth", LV_SYMBOL_GPS, "GPS", LV_SYMBOL_USB, "USB",
LV_SYMBOL_SD_CARD, "SD card", LV_SYMBOL_CLOSE, "Close", NULL};
uint32_t i;
for(i = 0; txts[i] != NULL; i += 2) {
btn = lv_list_add_btn(list, txts[i], txts[i + 1]);
lv_btn_set_checkable(btn, true);
/*Make a button disabled*/
if(i == 4) {
lv_btn_set_state(btn, LV_BTN_STATE_DISABLED);
Hi @Lucas.Liao,
I have run your code on the simulator with parent set to lv_scr_act(); and it appears to show the symbols and text items okay in the list. How ever if I scroll the list it crashes the simulator while:
If this line is removed all is well, I am unsure as to why this is the case, there may be an issue lurking here which is corrupting some memory. I will need to ask @embeddedt or @kisvegabor to comment here please.
In the mean time it may be worth you trying your code with the lv_list_set_scroll_propagation() commented out for the time being to see if it works correctly for you then?
Kind Regards,
Pete.
Scroll propagation only works when the immediate parent is derived from a page. It definitely shouldn’t crash, but even after this is fixed, it wouldn’t do anything if you make the parent an lv_obj (or any other non-page object).
I’m guessing the crash happens because there is no check that the parent is actually a page.
@embeddedt, thank you for confirming this, I thought it may be the reason, but was not totally sure ( Me assigning lv_scr_act() as the parent which is not derived from a page.)
So @Lucas.Liao can you confirm what type of object you have set as the parent in your code please?
Thanks,
Pete
@embeddedt @pete-pjb, thank you for your answers. Yes, I use lv_scr_act() as the parent object, Maybe it affects scrolling propagation. But should it not affect the display of the icon font?When I used “LV_ex_list”, there was also no icon font.Thanks again.
void lv_ex_list_1(void)
/Create a list/
lv_obj_t * list1 = lv_list_create(lv_scr_act(), NULL);
lv_obj_set_size(list1, 160, 200);
lv_obj_align(list1, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_t * list_btn;
list_btn = lv_list_add_btn(list1, LV_SYMBOL_FILE, "New");
lv_obj_set_event_cb(list_btn, event_handler);
list_btn = lv_list_add_btn(list1, LV_SYMBOL_DIRECTORY, "Open");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_CLOSE, "Delete");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_EDIT, "Edit");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_SAVE, "Save");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_BELL, "Notify");
list_btn = lv_list_add_btn(list1, LV_SYMBOL_BATTERY_FULL, "Battery");
Hi @Lucas.Liao,
So you are saying the example code unmodified is not showing the symbols on your system? Are you using the simulator or your own hardware?
Cheers,
Pete
Hi @pete-pjb,
Morning~Yes, I using my own hardware.
I forgot to mention it, and I’m using my own font library. I use V6 can display icon fonts, but not self-built fonts. Meantime, i can’t display icon fonts with V7, but my own fonts.
Maybe it’s a configuration issue?
Hi @Lucas.Liao,
It could be a configuration issue, please can you post your lv_conf.h file?
Hi @pete-pjb,
Thank you for your patient help. This is the configuration of V7,
* @file lv_conf.h
* COPY THIS FILE AS `lv_conf.h` NEXT TO the `lvgl` FOLDER
#ifndef LV_CONF_H
#define LV_CONF_H
/* clang-format off */
#include <stdint.h>
Graphical settings
/* Maximal horizontal and vertical resolution to support by the library.*/
#define LV_HOR_RES_MAX (320)
#define LV_VER_RES_MAX (240)
/* Color depth:
* - 1: 1 byte per pixel
* - 8: RGB332
* - 16: RGB565
* - 32: ARGB8888
#define LV_COLOR_DEPTH 16
/* Swap the 2 bytes of RGB565 color.
* Useful if the display has a 8 bit interface (e.g. SPI)*/
#define LV_COLOR_16_SWAP 0
/* 1: Enable screen transparency.
* Useful for OSD or other overlapping GUIs.
* Requires `LV_COLOR_DEPTH = 32` colors and the screen's style should be modified: `style.body.opa = ...`*/
#define LV_COLOR_SCREEN_TRANSP 0
/*Images pixels with this color will not be drawn (with chroma keying)*/
#define LV_COLOR_TRANSP LV_COLOR_LIME /*LV_COLOR_LIME: pure green*/
/* Enable anti-aliasing (lines, and radiuses will be smoothed) */
#define LV_ANTIALIAS 1
/* Default display refresh period.
* Can be changed in the display driver (`lv_disp_drv_t`).*/
#define LV_DISP_DEF_REFR_PERIOD 30 /*[ms]*/
/* Dot Per Inch: used to initialize default sizes.
* E.g. a button with width = LV_DPI / 2 -> half inch wide
* (Not so important, you can adjust it to modify default sizes and spaces)*/
#define LV_DPI 130 /*[px]*/
/* The the real width of the display changes some default values:
* default object sizes, layout of examples, etc.
* According to the width of the display (hor. res. / dpi)
* the displays fall in 4 categories.
* The 4th is extra large which has no upper limit so not listed here
* The upper limit of the categories are set below in 0.1 inch unit.
#define LV_DISP_SMALL_LIMIT 30
#define LV_DISP_MEDIUM_LIMIT 50
#define LV_DISP_LARGE_LIMIT 70
/* Type of coordinates. Should be `int16_t` (or `int32_t` for extreme cases) */
typedef int16_t lv_coord_t;
Memory manager settings
/* LittelvGL's internal memory manager's settings.
* The graphical objects and other related data are stored here. */
/* 1: use custom malloc/free, 0: use the built-in `lv_mem_alloc` and `lv_mem_free` */
#define LV_MEM_CUSTOM 0
#if LV_MEM_CUSTOM == 0
/* Size of the memory used by `lv_mem_alloc` in bytes (>= 2kB)*/
# define LV_MEM_SIZE (32U * 1024U)
/* Complier prefix for a big array declaration */
# define LV_MEM_ATTR
/* Set an address for the memory pool instead of allocating it as an array.
* Can be in external SRAM too. */
# define LV_MEM_ADR 0
/* Automatically defrag. on free. Defrag. means joining the adjacent free cells. */
# define LV_MEM_AUTO_DEFRAG 1
#else /*LV_MEM_CUSTOM*/
# define LV_MEM_CUSTOM_INCLUDE <stdlib.h> /*Header for the dynamic memory function*/
# define LV_MEM_CUSTOM_ALLOC malloc /*Wrapper to malloc*/
# define LV_MEM_CUSTOM_FREE free /*Wrapper to free*/
#endif /*LV_MEM_CUSTOM*/
/* Garbage Collector settings
* Used if lvgl is binded to higher level language and the memory is managed by that language */
#define LV_ENABLE_GC 0
#if LV_ENABLE_GC != 0
# define LV_GC_INCLUDE "gc.h" /*Include Garbage Collector related things*/
# define LV_MEM_CUSTOM_REALLOC your_realloc /*Wrapper to realloc*/
# define LV_MEM_CUSTOM_GET_SIZE your_mem_get_size /*Wrapper to lv_mem_get_size*/
#endif /* LV_ENABLE_GC */
Input device settings
/* Input device default settings.
* Can be changed in the Input device driver (`lv_indev_drv_t`)*/
/* Input device read period in milliseconds */
#define LV_INDEV_DEF_READ_PERIOD 30
/* Drag threshold in pixels */
#define LV_INDEV_DEF_DRAG_LIMIT 10
/* Drag throw slow-down in [%]. Greater value -> faster slow-down */
#define LV_INDEV_DEF_DRAG_THROW 10
/* Long press time in milliseconds.
* Time to send `LV_EVENT_LONG_PRESSSED`) */
#define LV_INDEV_DEF_LONG_PRESS_TIME 400
/* Repeated trigger period in long press [ms]
* Time between `LV_EVENT_LONG_PRESSED_REPEAT */
#define LV_INDEV_DEF_LONG_PRESS_REP_TIME 100
/* Gesture threshold in pixels */
#define LV_INDEV_DEF_GESTURE_LIMIT 50
/* Gesture min velocity at release before swipe (pixels)*/
#define LV_INDEV_DEF_GESTURE_MIN_VELOCITY 3
* Feature usage
/*1: Enable the Animations */
#define LV_USE_ANIMATION 1
#if LV_USE_ANIMATION
/*Declare the type of the user data of animations (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_anim_user_data_t;
/* 1: Enable shadow drawing*/
#define LV_USE_SHADOW 1
#if LV_USE_SHADOW
/* Allow buffering some shadow calculation
* LV_SHADOW_CACHE_SIZE is the max. shadow size to buffer,
* where shadow size is `shadow_width + radius`
* Caching has LV_SHADOW_CACHE_SIZE^2 RAM cost*/
#define LV_SHADOW_CACHE_SIZE 0
/* 1: Use other blend modes than normal (`LV_BLEND_MODE_...`)*/
#define LV_USE_BLEND_MODES 1
/* 1: Use the `opa_scale` style property to set the opacity of an object and its children at once*/
#define LV_USE_OPA_SCALE 1
/* 1: Use image zoom and rotation*/
#define LV_USE_IMG_TRANSFORM 1
/* 1: Enable object groups (for keyboard/encoder navigation) */
#define LV_USE_GROUP 1
#if LV_USE_GROUP
typedef void * lv_group_user_data_t;
#endif /*LV_USE_GROUP*/
/* 1: Enable GPU interface*/
#define LV_USE_GPU 1 /*Only enables `gpu_fill_cb` and `gpu_blend_cb` in the disp. drv- */
#define LV_USE_GPU_STM32_DMA2D 0
/* 1: Enable file system (might be required for images */
#define LV_USE_FILESYSTEM 1
#if LV_USE_FILESYSTEM
/*Declare the type of the user data of file system drivers (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_fs_drv_user_data_t;
/*1: Add a `user_data` to drivers and objects*/
#define LV_USE_USER_DATA 0
/*1: Show CPU usage and FPS count in the right bottom corner*/
#define LV_USE_PERF_MONITOR 0
/*1: Use the functions and types from the older API if possible */
#define LV_USE_API_EXTENSION_V6 1
* Image decoder and cache
/* 1: Enable indexed (palette) images */
#define LV_IMG_CF_INDEXED 1
/* 1: Enable alpha indexed images */
#define LV_IMG_CF_ALPHA 1
/* Default image cache size. Image caching keeps the images opened.
* If only the built-in image formats are used there is no real advantage of caching.
* (I.e. no new image decoder is added)
* With complex image decoders (e.g. PNG or JPG) caching can save the continuous open/decode of images.
* However the opened images might consume additional RAM.
* LV_IMG_CACHE_DEF_SIZE must be >= 1 */
#define LV_IMG_CACHE_DEF_SIZE 1
/*Declare the type of the user data of image decoder (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_img_decoder_user_data_t;
* Compiler settings
/* Define a custom attribute to `lv_tick_inc` function */
#define LV_ATTRIBUTE_TICK_INC
/* Define a custom attribute to `lv_task_handler` function */
#define LV_ATTRIBUTE_TASK_HANDLER
/* Define a custom attribute to `lv_disp_flush_ready` function */
/* With size optimization (-Os) the compiler might not align data to
* 4 or 8 byte boundary. This alignment will be explicitly applied where needed.
* E.g. __attribute__((aligned(4))) */
#define LV_ATTRIBUTE_MEM_ALIGN
/* Attribute to mark large constant arrays for example
* font's bitmaps */
/* Prefix performance critical functions to place them into a faster memory (e.g RAM)
* Uses 15-20 kB extra memory */
#define LV_ATTRIBUTE_FAST_MEM
/* Export integer constant to binding.
* This macro is used with constants in the form of LV_<CONST> that
* should also appear on lvgl binding API such as Micropython
* The default value just prevents a GCC warning.
#define LV_EXPORT_CONST_INT(int_value) struct _silence_gcc_warning
* HAL settings
/* 1: use a custom tick source.
* It removes the need to manually update the tick with `lv_tick_inc`) */
#define LV_TICK_CUSTOM 0
#if LV_TICK_CUSTOM == 1
#define LV_TICK_CUSTOM_INCLUDE "something.h" /*Header for the sys time function*/
#define LV_TICK_CUSTOM_SYS_TIME_EXPR (millis()) /*Expression evaluating to current systime in ms*/
#endif /*LV_TICK_CUSTOM*/
typedef void * lv_disp_drv_user_data_t; /*Type of user data in the display driver*/
typedef void * lv_indev_drv_user_data_t; /*Type of user data in the input device driver*/
* Log settings
/*1: Enable the log module*/
#define LV_USE_LOG 0
#if LV_USE_LOG
/* How important log should be added:
* LV_LOG_LEVEL_TRACE A lot of logs to give detailed information
* LV_LOG_LEVEL_INFO Log important events
* LV_LOG_LEVEL_WARN Log if something unwanted happened but didn't cause a problem
* LV_LOG_LEVEL_ERROR Only critical issue, when the system may fail
* LV_LOG_LEVEL_NONE Do not log anything
# define LV_LOG_LEVEL LV_LOG_LEVEL_WARN
/* 1: Print the log with 'printf';
* 0: user need to register a callback with `lv_log_register_print_cb`*/
# define LV_LOG_PRINTF 0
#endif /*LV_USE_LOG*/
* Debug settings
/* If Debug is enabled LittelvGL validates the parameters of the functions.
* If an invalid parameter is found an error log message is printed and
* the MCU halts at the error. (`LV_USE_LOG` should be enabled)
* If you are debugging the MCU you can pause
* the debugger to see exactly where the issue is.
* The behavior of asserts can be overwritten by redefining them here.
* E.g. #define LV_ASSERT_MEM(p) <my_assert_code>
#define LV_USE_DEBUG 1
#if LV_USE_DEBUG
/*Check if the parameter is NULL. (Quite fast) */
#define LV_USE_ASSERT_NULL 1
/*Checks is the memory is successfully allocated or no. (Quite fast)*/
#define LV_USE_ASSERT_MEM 1
/*Check the integrity of `lv_mem` after critical operations. (Slow)*/
#define LV_USE_ASSERT_MEM_INTEGRITY 0
/* Check the strings.
* Search for NULL, very long strings, invalid characters, and unnatural repetitions. (Slow)
* If disabled `LV_USE_ASSERT_NULL` will be performed instead (if it's enabled) */
#define LV_USE_ASSERT_STR 0
/* Check NULL, the object's type and existence (e.g. not deleted). (Quite slow)
#define LV_USE_ASSERT_OBJ 0
/*Check if the styles are properly initialized. (Fast)*/
#define LV_USE_ASSERT_STYLE 0
#endif /*LV_USE_DEBUG*/
* FONT USAGE
/* The built-in fonts contains the ASCII range and some Symbols with 4 bit-per-pixel.
* The symbols are available via `LV_SYMBOL_...` defines
* More info about fonts: https://docs.lvgl.com/#Fonts
* To create a new font go to: https://lvgl.com/ttf-font-to-c-array
/* Montserrat fonts with bpp = 4
* https://fonts.google.com/specimen/Montserrat */
#define LV_FONT_MONTSERRAT_12 0
#define LV_FONT_MONTSERRAT_14 0
#define LV_FONT_MONTSERRAT_16 1
#define LV_FONT_MONTSERRAT_18 0
#define LV_FONT_MONTSERRAT_20 0
#define LV_FONT_MONTSERRAT_22 0
#define LV_FONT_MONTSERRAT_24 0
#define LV_FONT_MONTSERRAT_26 0
#define LV_FONT_MONTSERRAT_28 0
#define LV_FONT_MONTSERRAT_30 0
#define LV_FONT_MONTSERRAT_32 0
#define LV_FONT_MONTSERRAT_34 0
#define LV_FONT_MONTSERRAT_36 0
#define LV_FONT_MONTSERRAT_38 0
#define LV_FONT_MONTSERRAT_40 0
#define LV_FONT_MONTSERRAT_42 0
#define LV_FONT_MONTSERRAT_44 0
#define LV_FONT_MONTSERRAT_46 0
#define LV_FONT_MONTSERRAT_48 0
#define TITILLIUMWEB_BOLD_12 0
#define TITILLIUMWEB_BOLD_14 0
#define TITILLIUMWEB_BOLD_16 0
#define TITILLIUMWEB_BOLD_18 1
#define TITILLIUMWEB_BOLD_20 0
#define TITILLIUMWEB_BOLD_32 0
#define TITILLIUMWEB_BOLD_60 0
/* Demonstrate special features */
#define LV_FONT_MONTSERRAT_12_SUBPX 0
#define LV_FONT_MONTSERRAT_28_COMPRESSED 0 /*bpp = 3*/
#define LV_FONT_DEJAVU_16_PERSIAN_HEBREW 0 /*Hebrew, Arabic, PErisan letters and all their forms*/
#define LV_FONT_SIMSUN_16_CJK 0 /*1000 most common CJK radicals*/
#define LV_ATTRIBUTE_IMG_BACK_ICON 1
/*Pixel perfect monospace font
* http://pelulamu.net/unscii/ */
#define LV_FONT_UNSCII_8 0
/* Optionally declare your custom fonts here.
* You can use these fonts as default font too
* and they will be available globally. E.g.
* #define LV_FONT_CUSTOM_DECLARE LV_FONT_DECLARE(my_font_1) \
* LV_FONT_DECLARE(my_font_2)
/* Enable it if you have fonts with a lot of characters.
* The limit depends on the font size, font face and bpp
* but with > 10,000 characters if you see issues probably you need to enable it.*/
#define LV_FONT_FMT_TXT_LARGE 1
/* Set the pixel order of the display.
* Important only if "subpx fonts" are used.
* With "normal" font it doesn't matter.
#define LV_FONT_SUBPX_BGR 1
/*Declare the type of the user data of fonts (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_font_user_data_t;
* THEME USAGE
/*Always enable at least on theme*/
/* No theme, you can apply your styles as you need
* No flags. Set LV_THEME_DEFAULT_FLAG 0 */
#define LV_USE_THEME_EMPTY 1
/*Simple to the create your theme based on it
#define LV_USE_THEME_TEMPLATE 1
/* A fast and impressive theme.
* Flags:
* LV_THEME_MATERIAL_FLAG_LIGHT: light theme
* LV_THEME_MATERIAL_FLAG_DARK: dark theme*/
#define LV_USE_THEME_MATERIAL 1
/* Mono-color theme for monochrome displays.
* If LV_THEME_DEFAULT_COLOR_PRIMARY is LV_COLOR_BLACK the
* texts and borders will be black and the background will be
* white. Else the colors are inverted.
#define LV_USE_THEME_MONO 1
#define LV_THEME_DEFAULT_INCLUDE <stdint.h> /*Include a header for the init. function*/
#define LV_THEME_DEFAULT_INIT lv_theme_material_init
#define LV_THEME_DEFAULT_COLOR_PRIMARY LV_COLOR_RED
#define LV_THEME_DEFAULT_COLOR_SECONDARY LV_COLOR_BLUE
#define LV_THEME_DEFAULT_FLAG LV_THEME_MATERIAL_FLAG_LIGHT
//#define LV_THEME_DEFAULT_FONT_SMALL &lv_font_montserrat_16
//#define LV_THEME_DEFAULT_FONT_NORMAL &lv_font_montserrat_16
//#define LV_THEME_DEFAULT_FONT_SUBTITLE &lv_font_montserrat_16
//#define LV_THEME_DEFAULT_FONT_TITLE &lv_font_montserrat_16
#define LV_THEME_DEFAULT_FONT_SMALL &titillumweb_bold_18
#define LV_THEME_DEFAULT_FONT_NORMAL &titillumweb_bold_18
#define LV_THEME_DEFAULT_FONT_SUBTITLE &titillumweb_bold_18
#define LV_THEME_DEFAULT_FONT_TITLE &titillumweb_bold_18
* Text settings
/* Select a character encoding for strings.
* - LV_TXT_ENC_UTF8
* - LV_TXT_ENC_ASCII
#define LV_TXT_ENC LV_TXT_ENC_ASCII
#define LV_TXT_BREAK_CHARS " ,.;:-_"
/* If a word is at least this long, will break wherever "prettiest"
* To disable, set to a value <= 0 */
#define LV_TXT_LINE_BREAK_LONG_LEN 0
/* Minimum number of characters in a long word to put on a line before a break.
* Depends on LV_TXT_LINE_BREAK_LONG_LEN. */
#define LV_TXT_LINE_BREAK_LONG_PRE_MIN_LEN 3
/* Minimum number of characters in a long word to put on a line after a break.
/* The control character to use for signalling text recoloring. */
#define LV_TXT_COLOR_CMD "#"
/* Support bidirectional texts.
* Allows mixing Left-to-Right and Right-to-Left texts.
* The direction will be processed according to the Unicode Bidirectioanl Algorithm:
* https://www.w3.org/International/articles/inline-bidi-markup/uba-basics*/
#define LV_USE_BIDI 0
#if LV_USE_BIDI
/* Set the default direction. Supported values:
* `LV_BIDI_DIR_LTR` Left-to-Right
* `LV_BIDI_DIR_RTL` Right-to-Left
* `LV_BIDI_DIR_AUTO` detect texts base direction */
#define LV_BIDI_BASE_DIR_DEF LV_BIDI_DIR_AUTO
/* Enable Arabic/Persian processing
* In these languages characters should be replaced with
* an other form based on their position in the text */
/*Change the built in (v)snprintf functions*/
#define LV_SPRINTF_CUSTOM 0
#if LV_SPRINTF_CUSTOM
# define LV_SPRINTF_INCLUDE <stdio.h>
# define lv_snprintf snprintf
# define lv_vsnprintf vsnprintf
#endif /*LV_SPRINTF_CUSTOM*/
* LV_OBJ SETTINGS
#if LV_USE_USER_DATA
/*Declare the type of the user data of object (can be e.g. `void *`, `int`, `struct`)*/
typedef void * lv_obj_user_data_t;
/*Provide a function to free user data*/
#define LV_USE_USER_DATA_FREE 0
#if LV_USE_USER_DATA_FREE
# define LV_USER_DATA_FREE_INCLUDE "something.h" /*Header for user data free function*/
/* Function prototype : void user_data_free(lv_obj_t * obj); */
# define LV_USER_DATA_FREE (user_data_free) /*Invoking for user data free function*/
/*1: enable `lv_obj_realaign()` based on `lv_obj_align()` parameters*/
#define LV_USE_OBJ_REALIGN 1
/* Enable to make the object clickable on a larger area.
* LV_EXT_CLICK_AREA_OFF or 0: Disable this feature
* LV_EXT_CLICK_AREA_TINY: The extra area can be adjusted horizontally and vertically (0..255 px)
* LV_EXT_CLICK_AREA_FULL: The extra area can be adjusted in all 4 directions (-32k..+32k px)
#define LV_USE_EXT_CLICK_AREA LV_EXT_CLICK_AREA_TINY
* LV OBJ X USAGE
* Documentation of the object types: https://docs.lvgl.com/#Object-types
/*Arc (dependencies: -)*/
#define LV_USE_ARC 1
/*Bar (dependencies: -)*/
#define LV_USE_BAR 1
/*Button (dependencies: lv_cont*/
#define LV_USE_BTN 1
/*Button matrix (dependencies: -)*/
#define LV_USE_BTNMATRIX 1
/*Calendar (dependencies: -)*/
#define LV_USE_CALENDAR 1
/*Canvas (dependencies: lv_img)*/
#define LV_USE_CANVAS 1
/*Check box (dependencies: lv_btn, lv_label)*/
#define LV_USE_CHECKBOX 1
/*Chart (dependencies: -)*/
#define LV_USE_CHART 1
#if LV_USE_CHART
# define LV_CHART_AXIS_TICK_LABEL_MAX_LEN 256
/*Container (dependencies: -*/
#define LV_USE_CONT 1
/*Color picker (dependencies: -*/
#define LV_USE_CPICKER 1
/*Drop down list (dependencies: lv_page, lv_label, lv_symbol_def.h)*/
#define LV_USE_DROPDOWN 1
#if LV_USE_DROPDOWN != 0
/*Open and close default animation time [ms] (0: no animation)*/
# define LV_DROPDOWN_DEF_ANIM_TIME 200
/*Gauge (dependencies:lv_bar, lv_linemeter)*/
#define LV_USE_GAUGE 1
/*Image (dependencies: lv_label*/
#define LV_USE_IMG 1
/*Image Button (dependencies: lv_btn*/
#define LV_USE_IMGBTN 1
#if LV_USE_IMGBTN
/*1: The imgbtn requires left, mid and right parts and the width can be set freely*/
# define LV_IMGBTN_TILED 1
/*Keyboard (dependencies: lv_btnm)*/
#define LV_USE_KEYBOARD 1
/*Label (dependencies: -*/
#define LV_USE_LABEL 1
#if LV_USE_LABEL != 0
/*Hor, or ver. scroll speed [px/sec] in 'LV_LABEL_LONG_ROLL/ROLL_CIRC' mode*/
# define LV_LABEL_DEF_SCROLL_SPEED 25
/* Waiting period at beginning/end of animation cycle */
# define LV_LABEL_WAIT_CHAR_COUNT 3
/*Enable selecting text of the label */
# define LV_LABEL_TEXT_SEL 0
/*Store extra some info in labels (12 bytes) to speed up drawing of very long texts*/
# define LV_LABEL_LONG_TXT_HINT 0
/*LED (dependencies: -)*/
#define LV_USE_LED 1
#if LV_USE_LED
# define LV_LED_BRIGHT_MIN 120 /*Minimal brightness*/
# define LV_LED_BRIGHT_MAX 255 /*Maximal brightness*/
/*Line (dependencies: -*/
#define LV_USE_LINE 1
/*List (dependencies: lv_page, lv_btn, lv_label, (lv_img optionally for icons ))*/
#define LV_USE_LIST 1
#if LV_USE_LIST != 0
/*Default animation time of focusing to a list element [ms] (0: no animation) */
# define LV_LIST_DEF_ANIM_TIME 100
/*Line meter (dependencies: *;)*/
#define LV_USE_LINEMETER 1
#if LV_USE_LINEMETER
/* Draw line more precisely at cost of performance.
* Useful if there are lot of lines any minor are visible
* 0: No extra precision
* 1: Some extra precision
* 2: Best precision
# define LV_LINEMETER_PRECISE 0
/*Mask (dependencies: -)*/
#define LV_USE_OBJMASK 1
/*Message box (dependencies: lv_rect, lv_btnm, lv_label)*/
#define LV_USE_MSGBOX 1
/*Page (dependencies: lv_cont)*/
#define LV_USE_PAGE 1
#if LV_USE_PAGE != 0
/*Focus default animation time [ms] (0: no animation)*/
# define LV_PAGE_DEF_ANIM_TIME 400
/*Preload (dependencies: lv_arc, lv_anim)*/
#define LV_USE_SPINNER 1
#if LV_USE_SPINNER != 0
# define LV_SPINNER_DEF_ARC_LENGTH 60 /*[deg]*/
# define LV_SPINNER_DEF_SPIN_TIME 1000 /*[ms]*/
# define LV_SPINNER_DEF_ANIM LV_SPINNER_TYPE_SPINNING_ARC
/*Roller (dependencies: lv_ddlist)*/
#define LV_USE_ROLLER 1
#if LV_USE_ROLLER != 0
/*Focus animation time [ms] (0: no animation)*/
# define LV_ROLLER_DEF_ANIM_TIME 200
/*Number of extra "pages" when the roller is infinite*/
# define LV_ROLLER_INF_PAGES 7
/*Slider (dependencies: lv_bar)*/
#define LV_USE_SLIDER 1
/*Spinbox (dependencies: lv_ta)*/
#define LV_USE_SPINBOX 1
/*Switch (dependencies: lv_slider)*/
#define LV_USE_SWITCH 1
/*Text area (dependencies: lv_label, lv_page)*/
#define LV_USE_TEXTAREA 1
#if LV_USE_TEXTAREA != 0
# define LV_TEXTAREA_DEF_CURSOR_BLINK_TIME 400 /*ms*/
# define LV_TEXTAREA_DEF_PWD_SHOW_TIME 1500 /*ms*/
/*Table (dependencies: lv_label)*/
#define LV_USE_TABLE 1
#if LV_USE_TABLE
# define LV_TABLE_COL_MAX 12
/*Tab (dependencies: lv_page, lv_btnm)*/
#define LV_USE_TABVIEW 1
# if LV_USE_TABVIEW != 0
/*Time of slide animation [ms] (0: no animation)*/
# define LV_TABVIEW_DEF_ANIM_TIME 300
/*Tileview (dependencies: lv_page) */
#define LV_USE_TILEVIEW 1
#if LV_USE_TILEVIEW
# define LV_TILEVIEW_DEF_ANIM_TIME 300
/*Window (dependencies: lv_cont, lv_btn, lv_label, lv_img, lv_page)*/
#define LV_USE_WIN 1
* Non-user section
#if defined(_MSC_VER) && !defined(_CRT_SECURE_NO_WARNINGS) /* Disable warnings for Visual Studio*/
# define _CRT_SECURE_NO_WARNINGS
/*--END OF LV_CONF_H--*/
#endif /*LV_CONF_H*/
Hi @pete-pjb,
And this is the configuration of V6,
* @file lv_conf.h
#ifndef LV_CONF_H
#define LV_CONF_H
#include <stdint.h>
Graphical settings
/* Color depth:
* - 8: RGB233
* - 16: RGB565
* - 32: ARGB8888
#define LV_DPI 100 /*[px]*/
#define LV_INDEV_DEF_DRAG_THROW 20
* Feature usage
#if LV_USE_GROUP
#define LV_USE_USER_DATA 1
* Compiler settings
* font's bitmaps */
* HAL settings
* Log settings
#if LV_USE_LOG
* 0: user need to register a callback with `lv_log_register_print`*/
* THEME USAGE
#define LV_THEME_LIVE_UPDATE 0 /*1: Allow theme switching at run time. Uses 8..10 kB of RAM*/
#define LV_USE_THEME_TEMPL 0 /*Just for test*/
#define LV_USE_THEME_DEFAULT 0 /*Built mainly from the built-in styles. Consumes very few RAM*/
#define LV_USE_THEME_ALIEN 0 /*Dark futuristic theme*/
#define LV_USE_THEME_NIGHT 1 /*Dark elegant theme*/
#define LV_USE_THEME_MONO 0 /*Mono color theme for monochrome displays*/
#define LV_USE_THEME_MATERIAL 0 /*Flat theme with bold colors and light shadows*/
#define LV_USE_THEME_ZEN 0 /*Peaceful, mainly light theme */
#define LV_USE_THEME_NEMO 0 /*Water-like theme based on the movie "Finding Nemo"*/
* FONT USAGE
* More info about fonts: https://docs.littlevgl.com/#Fonts
* To create a new font go to: https://littlevgl.com/ttf-font-to-c-array
/* Robot fonts with bpp = 4
* https://fonts.google.com/specimen/Roboto */
#define LV_FONT_ROBOTO_12 0
#define LV_FONT_ROBOTO_16 1
#define LV_FONT_ROBOTO_22 0
#define LV_FONT_ROBOTO_28 0
#define TITILLIUMWEB_BOLD_12 1
/*Always set a default font from the built-in fonts*/
#define LV_FONT_DEFAULT &lv_font_roboto_16
#define LV_FONT_FMT_TXT_LARGE 0
* Text settings
* - LV_TXT_ENC_UTF8
* LV_OBJ SETTINGS
#define LV_USE_EXT_CLICK_AREA LV_EXT_CLICK_AREA_OFF
* LV OBJ X USAGE
* Documentation of the object types: https://docs.littlevgl.com/#Object-types
#if LV_USE_BTN != 0
/*Enable button-state animations - draw a circle on click (dependencies: LV_USE_ANIMATION)*/
# define LV_BTN_INK_EFFECT 0
#define LV_USE_BTNM 1
#define LV_USE_CB 1
#if LV_USE_CHART
# define LV_CHART_AXIS_TICK_LABEL_MAX_LEN 20
#define LV_USE_DDLIST 1
#if LV_USE_DDLIST != 0
# define LV_DDLIST_DEF_ANIM_TIME 200
/*Gauge (dependencies:lv_bar, lv_lmeter)*/
#if LV_USE_IMGBTN
# define LV_IMGBTN_TILED 0
#define LV_USE_KB 1
#define LV_USE_LMETER 1
#define LV_USE_MBOX 1
#define LV_USE_PRELOAD 1
#if LV_USE_PRELOAD != 0
# define LV_PRELOAD_DEF_ARC_LENGTH 60 /*[deg]*/
# define LV_PRELOAD_DEF_SPIN_TIME 1000 /*[ms]*/
# define LV_PRELOAD_DEF_ANIM LV_PRELOAD_TYPE_SPINNING_ARC
#define LV_USE_SW 1
#define LV_USE_TA 1
#if LV_USE_TA != 0
# define LV_TA_DEF_CURSOR_BLINK_TIME 400 /*ms*/
# define LV_TA_DEF_PWD_SHOW_TIME 1500 /*ms*/
#if LV_USE_TABLE
#if LV_USE_TILEVIEW
* Non-user section
/*Be sure every define has a default value*/
#include "lvgl/src/lv_conf_checker.h"
Hi @Lucas.Liao,
Please can you edit your post and add in line code formatting.
This will enable us to read it properly.
Many thanks,
Pete
Hi @pete-pjb,
Sorry, thanks. I have revised it.
Hi @Lucas.Liao,
Can you post your call to lv_theme_material_init(); please from your initialisation code.
I am assuming you are using your own font based on the configuration file so can you, as a test, revert the configuration file as follows to the default font and test it please:
//#define LV_THEME_DEFAULT_FONT_SMALL &titillumweb_bold_18
//#define LV_THEME_DEFAULT_FONT_NORMAL &titillumweb_bold_18
//#define LV_THEME_DEFAULT_FONT_SUBTITLE &titillumweb_bold_18
//#define LV_THEME_DEFAULT_FONT_TITLE &titillumweb_bold_18
Rebuild the library and your application and let me know if this works?
Cheers,
Pete
Also, make sure you’re using the latest patch release (release/v7). 7.0.0 had a few minor issues with font rendering that have since been fixed.
Hi @embeddedt,
I think it’s related to this, but I updated it just the same.
Best regard,
Lucas
Hi @pete-pjb,
I’ve tried it this way. I don’t think there’s anything wrong with my initialization, do I?
But thank you for referring to it. Also, I’m not using a touch screen, just a display screen.
tft_init();
void monitor_cb(lv_disp_drv_t * d, uint32_t t, uint32_t p)
t_saved = t;
void tft_init(void)
static lv_disp_buf_t buf;
lv_disp_buf_init(&buf, LcdFlushBuf, NULL, 320);
lv_disp_drv_init(&disp_drv);
disp_drv.buffer = &buf;
disp_drv.flush_cb = tft_flush;
disp_drv.monitor_cb = monitor_cb;
Hi @Lucas.Liao,
It was your call to lv_theme_material_init(); I wanted to see please.
Is it possible your font titillumweb_bold_18 does not contain the symbols? Are you sure you added them when you made it with the online font converter. The notes about adding symbols from the Converter Page are as follows:
Blockquote List of built-in symbols Use this FontAwesme symbol font and copy this list to Range :
61441,61448,61451,61452,61452,61453,61457,61459,61461,61465,
61468,61473,61478,61479,61480,61502,61512,61515,61516,61517,
61521,61522,61523,61524,61543,61544,61550,61552,61553,61556,
61559,61560,61561,61563,61587,61589,61636,61637,61639,61671,
61674,61683,61724,61732,61787,61931,62016,62017,62018,62019,
62020,62087,62099,62212,62189,62810,63426,63650
Did you change the lv_conf.h file the way I showed in my previous post and rebuild the library and your application to test if it works okay with the built in Montserrat font?
Kind Regards,
Pete
