Hi @pete-pjb,
thanks a lot. I had been changed the lv_conf.h and contained the symbols. Also, I’ll try it on a PC virtual machine. lv_theme_material.c
static void basic_init(void)
style_init_reset(&styles->scr);
lv_style_set_bg_opa(&styles->scr, LV_STATE_DEFAULT, LV_OPA_COVER);
lv_style_set_bg_color(&styles->scr, LV_STATE_DEFAULT, COLOR_SCR);
lv_style_set_text_color(&styles->scr, LV_STATE_DEFAULT, COLOR_SCR_TEXT);
lv_style_set_value_color(&styles->scr, LV_STATE_DEFAULT, COLOR_SCR_TEXT);
lv_style_set_text_font(&styles->scr, LV_STATE_DEFAULT, theme.font_normal);
lv_style_set_value_font(&styles->scr, LV_STATE_DEFAULT, theme.font_normal);
style_init_reset(&styles->bg);
lv_style_set_radius(&styles->bg, LV_STATE_DEFAULT, LV_DPX(8));
lv_style_set_bg_opa(&styles->bg, LV_STATE_DEFAULT, LV_OPA_COVER);
lv_style_set_bg_color(&styles->bg, LV_STATE_DEFAULT, COLOR_BG);
lv_style_set_border_color(&styles->bg, LV_STATE_DEFAULT, COLOR_BG_BORDER);
lv_style_set_border_color(&styles->bg, LV_STATE_FOCUSED, theme.color_primary);
lv_style_set_border_color(&styles->bg, LV_STATE_EDITED, theme.color_secondary);
lv_style_set_border_width(&styles->bg, LV_STATE_DEFAULT, BORDER_WIDTH);
lv_style_set_border_post(&styles->bg, LV_STATE_DEFAULT, true);
lv_style_set_text_font(&styles->bg, LV_STATE_DEFAULT, theme.font_normal);
lv_style_set_text_color(&styles->bg, LV_STATE_DEFAULT, COLOR_BG_TEXT);
lv_style_set_value_font(&styles->bg, LV_STATE_DEFAULT, theme.font_normal);
lv_style_set_value_color(&styles->bg, LV_STATE_DEFAULT, COLOR_BG_TEXT);
lv_style_set_image_recolor(&styles->bg, LV_STATE_DEFAULT, COLOR_BG_TEXT);
lv_style_set_line_color(&styles->bg, LV_STATE_DEFAULT, COLOR_BG_TEXT);
lv_style_set_line_width(&styles->bg, LV_STATE_DEFAULT, 1);
lv_style_set_pad_left(&styles->bg, LV_STATE_DEFAULT, PAD_DEF + BORDER_WIDTH);
lv_style_set_pad_right(&styles->bg, LV_STATE_DEFAULT, PAD_DEF + BORDER_WIDTH);
lv_style_set_pad_top(&styles->bg, LV_STATE_DEFAULT, PAD_DEF + BORDER_WIDTH);
lv_style_set_pad_bottom(&styles->bg, LV_STATE_DEFAULT, PAD_DEF + BORDER_WIDTH);
lv_style_set_pad_inner(&styles->bg, LV_STATE_DEFAULT, PAD_DEF);
lv_style_set_transition_time(&styles->bg, LV_STATE_DEFAULT, TRANSITION_TIME);
lv_style_set_transition_prop_6(&styles->bg, LV_STATE_DEFAULT, LV_STYLE_BORDER_COLOR);
style_init_reset(&styles->bg_sec);
lv_style_copy(&styles->bg_sec, &styles->bg);
lv_style_set_bg_color(&styles->bg_sec, LV_STATE_DEFAULT, COLOR_BG_SEC);
lv_style_set_border_color(&styles->bg_sec, LV_STATE_DEFAULT, COLOR_BG_SEC_BORDER);
lv_style_set_text_color(&styles->bg_sec, LV_STATE_DEFAULT, COLOR_BG_SEC_TEXT);
lv_style_set_value_color(&styles->bg_sec, LV_STATE_DEFAULT, COLOR_BG_SEC_TEXT);
lv_style_set_image_recolor(&styles->bg_sec, LV_STATE_DEFAULT, COLOR_BG_SEC_TEXT);
lv_style_set_line_color(&styles->bg_sec, LV_STATE_DEFAULT, COLOR_BG_SEC_TEXT);
style_init_reset(&styles->bg_click);
lv_style_set_bg_color(&styles->bg_click, LV_STATE_PRESSED, COLOR_BG_PR);
lv_style_set_bg_color(&styles->bg_click, LV_STATE_CHECKED, COLOR_BG_CHK);
lv_style_set_bg_color(&styles->bg_click, LV_STATE_PRESSED | LV_STATE_CHECKED, COLOR_BG_PR_CHK);
lv_style_set_bg_color(&styles->bg_click, LV_STATE_DISABLED, COLOR_BG_DIS);
lv_style_set_border_width(&styles->bg_click, LV_STATE_CHECKED, 0);
lv_style_set_border_color(&styles->bg_click, LV_STATE_FOCUSED | LV_STATE_PRESSED, lv_color_darken(theme.color_primary,
LV_OPA_20));
lv_style_set_border_color(&styles->bg_click, LV_STATE_PRESSED, COLOR_BG_BORDER_PR);
lv_style_set_border_color(&styles->bg_click, LV_STATE_CHECKED, COLOR_BG_BORDER_CHK);
lv_style_set_border_color(&styles->bg_click, LV_STATE_PRESSED | LV_STATE_CHECKED, COLOR_BG_BORDER_CHK_PR);
lv_style_set_border_color(&styles->bg_click, LV_STATE_DISABLED, COLOR_BG_BORDER_DIS);
lv_style_set_text_color(&styles->bg_click, LV_STATE_PRESSED, COLOR_BG_TEXT_PR);
lv_style_set_text_color(&styles->bg_click, LV_STATE_CHECKED, COLOR_BG_TEXT_CHK);
lv_style_set_text_color(&styles->bg_click, LV_STATE_PRESSED | LV_STATE_CHECKED, COLOR_BG_TEXT_CHK_PR);
lv_style_set_text_color(&styles->bg_click, LV_STATE_DISABLED, COLOR_BG_TEXT_DIS);
lv_style_set_image_recolor(&styles->bg_click, LV_STATE_PRESSED, COLOR_BG_TEXT_PR);
lv_style_set_image_recolor(&styles->bg_click, LV_STATE_CHECKED, COLOR_BG_TEXT_CHK);
lv_style_set_image_recolor(&styles->bg_click, LV_STATE_PRESSED | LV_STATE_CHECKED, COLOR_BG_TEXT_CHK_PR);
lv_style_set_image_recolor(&styles->bg_click, LV_STATE_DISABLED, COLOR_BG_TEXT_DIS);
lv_style_set_transition_prop_5(&styles->bg_click, LV_STATE_DEFAULT, LV_STYLE_BG_COLOR);
style_init_reset(&styles->btn);
lv_style_set_radius(&styles->btn, LV_STATE_DEFAULT, LV_RADIUS_CIRCLE);
lv_style_set_bg_opa(&styles->btn, LV_STATE_DEFAULT, LV_OPA_COVER);
lv_style_set_bg_color(&styles->btn, LV_STATE_DEFAULT, COLOR_BTN);
lv_style_set_bg_color(&styles->btn, LV_STATE_PRESSED, COLOR_BTN_PR);
lv_style_set_bg_color(&styles->btn, LV_STATE_CHECKED, COLOR_BTN_CHK);
lv_style_set_bg_color(&styles->btn, LV_STATE_CHECKED | LV_STATE_PRESSED, COLOR_BTN_CHK_PR);
lv_style_set_bg_color(&styles->btn, LV_STATE_DISABLED, COLOR_BTN);
lv_style_set_bg_color(&styles->btn, LV_STATE_DISABLED | LV_STATE_CHECKED, COLOR_BTN_DIS);
lv_style_set_border_color(&styles->btn, LV_STATE_DEFAULT, COLOR_BTN_BORDER);
lv_style_set_border_color(&styles->btn, LV_STATE_PRESSED, COLOR_BTN_BORDER_PR);
lv_style_set_border_color(&styles->btn, LV_STATE_DISABLED, COLOR_BTN_BORDER_INA);
lv_style_set_border_width(&styles->btn, LV_STATE_DEFAULT, BORDER_WIDTH);
lv_style_set_border_opa(&styles->btn, LV_STATE_CHECKED, LV_OPA_TRANSP);
lv_style_set_text_color(&styles->btn, LV_STATE_DEFAULT, IS_LIGHT ? lv_color_hex(0x31404f) : lv_color_hex(0xffffff));
lv_style_set_text_color(&styles->btn, LV_STATE_PRESSED, IS_LIGHT ? lv_color_hex(0x31404f) : lv_color_hex(0xffffff));
lv_style_set_text_color(&styles->btn, LV_STATE_CHECKED, lv_color_hex(0xffffff));
lv_style_set_text_color(&styles->btn, LV_STATE_CHECKED | LV_STATE_PRESSED, lv_color_hex(0xffffff));
lv_style_set_text_color(&styles->btn, LV_STATE_DISABLED, IS_LIGHT ? lv_color_hex(0x888888) : lv_color_hex(0x888888));
lv_style_set_image_recolor(&styles->btn, LV_STATE_DEFAULT, IS_LIGHT ? lv_color_hex(0x31404f) : lv_color_hex(0xffffff));
lv_style_set_image_recolor(&styles->btn, LV_STATE_PRESSED, IS_LIGHT ? lv_color_hex(0x31404f) : lv_color_hex(0xffffff));
lv_style_set_image_recolor(&styles->btn, LV_STATE_PRESSED, lv_color_hex(0xffffff));
lv_style_set_image_recolor(&styles->btn, LV_STATE_CHECKED | LV_STATE_PRESSED, lv_color_hex(0xffffff));
lv_style_set_image_recolor(&styles->btn, LV_STATE_DISABLED, IS_LIGHT ? lv_color_hex(0x888888) : lv_color_hex(0x888888));
lv_style_set_value_color(&styles->btn, LV_STATE_DEFAULT, IS_LIGHT ? lv_color_hex(0x31404f) : lv_color_hex(0xffffff));
lv_style_set_value_color(&styles->btn, LV_STATE_PRESSED, IS_LIGHT ? lv_color_hex(0x31404f) : lv_color_hex(0xffffff));
lv_style_set_value_color(&styles->btn, LV_STATE_CHECKED, lv_color_hex(0xffffff));
lv_style_set_value_color(&styles->btn, LV_STATE_CHECKED | LV_STATE_PRESSED, lv_color_hex(0xffffff));
lv_style_set_value_color(&styles->btn, LV_STATE_DISABLED, IS_LIGHT ? lv_color_hex(0x888888) : lv_color_hex(0x888888));
lv_style_set_pad_left(&styles->btn, LV_STATE_DEFAULT, LV_DPX(40));
lv_style_set_pad_right(&styles->btn, LV_STATE_DEFAULT, LV_DPX(40));
lv_style_set_pad_top(&styles->btn, LV_STATE_DEFAULT, LV_DPX(15));
lv_style_set_pad_bottom(&styles->btn, LV_STATE_DEFAULT, LV_DPX(15));
lv_style_set_pad_inner(&styles->btn, LV_STATE_DEFAULT, LV_DPX(20));
lv_style_set_outline_width(&styles->btn, LV_STATE_DEFAULT, 3);
lv_style_set_outline_opa(&styles->btn, LV_STATE_DEFAULT, LV_OPA_0);
lv_style_set_outline_opa(&styles->btn, LV_STATE_FOCUSED, LV_OPA_50);
lv_style_set_outline_color(&styles->btn, LV_STATE_DEFAULT, theme.color_primary);
lv_style_set_outline_color(&styles->btn, LV_STATE_EDITED, theme.color_secondary);
lv_style_set_transition_time(&styles->btn, LV_STATE_DEFAULT, TRANSITION_TIME);
lv_style_set_transition_prop_4(&styles->btn, LV_STATE_DEFAULT, LV_STYLE_BORDER_OPA);
lv_style_set_transition_prop_5(&styles->btn, LV_STATE_DEFAULT, LV_STYLE_BG_COLOR);
lv_style_set_transition_prop_6(&styles->btn, LV_STATE_DEFAULT, LV_STYLE_OUTLINE_OPA);
lv_style_set_transition_delay(&styles->btn, LV_STATE_DEFAULT, TRANSITION_TIME);
lv_style_set_transition_delay(&styles->btn, LV_STATE_PRESSED, 0);
style_init_reset(&styles->pad_inner);
lv_style_set_pad_inner(&styles->pad_inner, LV_STATE_DEFAULT,
lv_disp_get_size_category(NULL) <= LV_DISP_MEDIUM_LIMIT ? LV_DPX(20) : LV_DPX(40));
style_init_reset(&styles->pad_small);
lv_style_int_t pad_small_value = lv_disp_get_size_category(NULL) <= LV_DISP_MEDIUM_LIMIT ? LV_DPX(10) : LV_DPX(20);
lv_style_set_pad_left(&styles->pad_small, LV_STATE_DEFAULT, pad_small_value);
lv_style_set_pad_right(&styles->pad_small, LV_STATE_DEFAULT, pad_small_value);
lv_style_set_pad_top(&styles->pad_small, LV_STATE_DEFAULT, pad_small_value);
lv_style_set_pad_bottom(&styles->pad_small, LV_STATE_DEFAULT, pad_small_value);
lv_style_set_pad_inner(&styles->pad_small, LV_STATE_DEFAULT, pad_small_value);
lv_theme_t * lv_theme_material_init(lv_color_t color_primary, lv_color_t color_secondary, uint32_t flags,
const lv_font_t * font_small, const lv_font_t * font_normal, const lv_font_t * font_subtitle,
const lv_font_t * font_title)
/* This trick is required only to avoid the garbage collection of
* styles' data if LVGL is used in a binding (e.g. Micropython)
* In a general case styles could be simple `static lv_style_t my style` variables*/
if(!inited) {
LV_GC_ROOT(_lv_theme_material_styles) = lv_mem_alloc(sizeof(theme_styles_t));
styles = (theme_styles_t *)LV_GC_ROOT(_lv_theme_material_styles);
theme.color_primary = color_primary;
theme.color_secondary = color_secondary;
theme.font_small = font_small;
theme.font_normal = font_normal;
theme.font_subtitle = font_subtitle;
theme.font_title = font_title;
theme.flags = flags;
basic_init();
cont_init();
btn_init();
label_init();
bar_init();
img_init();
line_init();
led_init();
slider_init();
switch_init();
linemeter_init();
gauge_init();
arc_init();
spinner_init();
chart_init();
calendar_init();
cpicker_init();
checkbox_init();
btnmatrix_init();
keyboard_init();
msgbox_init();
page_init();
textarea_init();
spinbox_init();
list_init();
ddlist_init();
roller_init();
tabview_init();
tileview_init();
table_init();
win_init();
theme.apply_xcb = theme_apply;
inited = true;
lv_obj_report_style_mod(NULL);
return &theme;
