Since the latest master commits today when LVGL attempts to render an object wit…h an OPA value less than 100%, the following message is generated if logging is enabled:
[Warn] (120.944, +167) refr_obj: Rendering this widget needs LV_COLOR_SCREEN_TRANSP 1 (in lv_refr.c line #872)
The object concerned is also not being rendered correctly.
Just as an experiment I have tried LV_COLOR_SCREEN_TRANSP 1 in lv_conf.h and rebuilt the library
This fixes the problem in the simulator with the test code below, but on my target hardware I just get a blank black screen with the same configuration.
I also tried adding the following lines to my driver initialisation code but I still just get a blank black screen on my target system.
```c
lv_obj_set_style_bg_opa(lv_scr_act(), LV_OPA_TRANSP, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_disp_set_bg_opa(NULL, LV_OPA_TRANSP);
Some test code:
```c
#define NO_MSG_SLOTS 10
#define MSG_B_SIZEX 1014
#define MSG_B_SIZEY 40
#define MSG_ANIM_TIME 1000
#define MSG_DISP_TIME 5000
static void anim_x_cb(void * var, lv_coord_t v) {
lv_obj_set_x(var, v);
static void anim_x_cb1(void * var, lv_coord_t v) { // This is required as you can't call the same function from two different animation parts!
char *sys_msgs[] = {
"System message 1",
"System message 2",
"System_message 3",
static void show_sys_message( uint16_t message_id ) {
static uint8_t msg_pos = 0, first_call = true;
static lv_obj_t *mbox[NO_MSG_SLOTS];
static lv_style_t mbox_style;
static lv_anim_t a1[NO_MSG_SLOTS], a2[NO_MSG_SLOTS];
static lv_anim_timeline_t *anim_timeline[NO_MSG_SLOTS];
if( first_call ) {
lv_style_init(&mbox_style);
lv_style_set_radius(&mbox_style, 3);
lv_style_set_opa(&mbox_style, LV_OPA_70);
lv_style_set_border_width(&mbox_style, 2);
lv_style_set_text_align(&mbox_style, LV_TEXT_ALIGN_CENTER);
for( uint8_t i = 0; i < NO_MSG_SLOTS; i++ ) {
mbox[i] = lv_textarea_create(lv_scr_act());
lv_textarea_set_one_line(mbox[i], true);
lv_obj_add_style(mbox[i], &mbox_style, LV_PART_MAIN);
lv_obj_set_width( mbox[i], MSG_B_SIZEX);
lv_obj_set_pos(mbox[i], SDL_HOR_RES, (105 + (MSG_B_SIZEY * i)) );
lv_anim_init(&a1[i]);
lv_anim_set_var(&a1[i], mbox[i]);
lv_anim_set_values(&a1[i], SDL_HOR_RES, (SDL_HOR_RES - MSG_B_SIZEX - 10));
lv_anim_set_time(&a1[i], MSG_ANIM_TIME);
lv_anim_set_exec_cb(&a1[i], (lv_anim_exec_xcb_t)anim_x_cb);
lv_anim_set_path_cb(&a1[i], lv_anim_path_ease_in);
lv_anim_init(&a2[i]);
lv_anim_set_var(&a2[i], mbox[i]);
lv_anim_set_values(&a2[i], (SDL_HOR_RES - MSG_B_SIZEX - 10), SDL_HOR_RES);
lv_anim_set_time(&a2[i], MSG_ANIM_TIME);
lv_anim_set_exec_cb(&a2[i], (lv_anim_exec_xcb_t) anim_x_cb1);
lv_anim_set_path_cb(&a2[i], lv_anim_path_ease_in);
anim_timeline[i] = lv_anim_timeline_create();
lv_anim_timeline_add(anim_timeline[i], 0, &a1[i]);
lv_anim_timeline_add(anim_timeline[i], MSG_DISP_TIME, &a2[i]);
first_call = false;
lv_textarea_set_text(mbox[msg_pos], sys_msgs[message_id]);
lv_obj_move_foreground( mbox[msg_pos] );
lv_anim_timeline_start(anim_timeline[msg_pos]);
if( msg_pos++ == NO_MSG_SLOTS ) msg_pos = 0;
show_sys_message( 0 );
Prior to todays updates I have never had to use LV_COLOR_SCREEN_TRANSP 1 in lv_conf.h maybe this is an ongoing mistake on my part but either way I can't seem to get things to work correctly since this update. @kisvegabor if you have any suggestions as to where I should be looking for a solution to this I would very much appreciate some pointers.
Kind Regards,
Pete
