Before posting
I use lv_label_create create two Label widgets to display times and number;
the object hander is global variable,and i only create them one time,and set their style,
then,i try to updata the text of the labels,lilke this
for(PlayCounter=0;PlayCounter<CanDataPlayTotalCount;PlayCounter++)
lv_label_set_text_fmt(guider_ui.CanDataPlayLabel6,“%lld Times”,PlayCounter);
DelayMs(1);
printf(PlayCounter= %lld\r\n,PlayCounter);
lv_img_set_src(guider_ui.CanDataPlayImg,&Compelet);
the nmber can updata when the Circulation running;
when the Circulation have finished execution,
i see the printf contents is correct,but some times the lab shows the smaller data;
for example printf shows 12345,but i see 12341 on the screnn
what is more important,when the number not equal to the fact,
the code "lv_img_set_src(guider_ui.CanDataPlayImg,&Compelet);"did not work,it can not change the image;
when the printf number equals to label show,the lv_img_set_src work,and change the image.
stm32
V8.3.5
i want the Label show the data that needs to change
i guess,the Circulation function run too fast,the LVGL memory manage can not creat and free memory
in time,(infact,i allocate a huge memry to LVGL 40KB,it is enough ,wen the code runs,it have 20KB left)
i change the Label up data like lv_label_set_text_static,but it can not show the last data probability
the code like this(PlayCounterStr is globle)
sprintf(PlayCounterStr,“%lld Times”,PlayCounter);
lv_label_set_text_static(guider_ui.CanDataPlayLabel6,PlayCounterStr);
When the value of the label is not equal to the actual value, the image does not change;just
have less probability compared with lv_label_set_text_fmt;
i can affirm lv_task_handler();run correctly all the time.
C
/You code here/
the code is
typedef struct
lv_obj_t *ScrCanDataPlay;
bool ScrCanDataPlay_Del;
lv_obj_t *CanDataPlayLabel6;
}lv_ui;
lv_ui guider_ui;
//Write codes ScrCanDataPlay
guider_ui.ScrCanDataPlay = lv_obj_create(NULL);
lv_obj_set_scrollbar_mode(guider_ui.ScrCanDataPlay, LV_SCROLLBAR_MODE_OFF);
//Write style state: LV_STATE_DEFAULT for style_screen_main_main_default
static lv_style_t style_screen_main_main_default;
if (style_screen_main_main_default.prop_cnt > 1)
lv_style_reset(&style_screen_main_main_default);
lv_style_init(&style_screen_main_main_default);
lv_style_set_bg_color(&style_screen_main_main_default, lv_color_make(0xff, 0xff, 0xff));
lv_style_set_bg_opa(&style_screen_main_main_default, 0);
lv_obj_add_style(guider_ui.ScrCanDataPlay, &style_screen_main_main_default, LV_PART_MAIN|LV_STATE_DEFAULT);
//Write style state: LV_STATE_DEFAULT for style_screen_label_all_main_main_default
static lv_style_t style_screen_label_all_main_main_default;
if (style_screen_label_all_main_main_default.prop_cnt > 1)
lv_style_reset(&style_screen_label_all_main_main_default);
lv_style_init(&style_screen_label_all_main_main_default);
lv_style_set_radius(&style_screen_label_all_main_main_default, 0);
lv_style_set_bg_color(&style_screen_label_all_main_main_default, lv_color_make(0xff, 0xff, 0xff));
lv_style_set_bg_grad_color(&style_screen_label_all_main_main_default, lv_color_make(0x21, 0x95, 0xf6));
lv_style_set_bg_grad_dir(&style_screen_label_all_main_main_default, LV_GRAD_DIR_NONE);
lv_style_set_bg_opa(&style_screen_label_all_main_main_default, 255);
lv_style_set_shadow_width(&style_screen_label_all_main_main_default, 0);
lv_style_set_shadow_color(&style_screen_label_all_main_main_default, lv_color_make(0x21, 0x95, 0xf6));
lv_style_set_shadow_opa(&style_screen_label_all_main_main_default, 255);
lv_style_set_shadow_spread(&style_screen_label_all_main_main_default, 0);
lv_style_set_shadow_ofs_x(&style_screen_label_all_main_main_default, 0);
lv_style_set_shadow_ofs_y(&style_screen_label_all_main_main_default, 0);
lv_style_set_text_color(&style_screen_label_all_main_main_default, lv_color_make(0x00, 0x00, 0x00));
lv_style_set_text_font(&style_screen_label_all_main_main_default, &HeiTi16);
lv_style_set_text_letter_space(&style_screen_label_all_main_main_default, 0);
lv_style_set_text_line_space(&style_screen_label_all_main_main_default, 0);
lv_style_set_text_align(&style_screen_label_all_main_main_default, LV_TEXT_ALIGN_CENTER);
lv_style_set_pad_left(&style_screen_label_all_main_main_default, 0);
lv_style_set_pad_right(&style_screen_label_all_main_main_default, 0);
lv_style_set_pad_top(&style_screen_label_all_main_main_default, 5);
lv_style_set_pad_bottom(&style_screen_label_all_main_main_default, 0);
guider_ui.CanDataPlayLabel6 = lv_label_create(guider_ui.ScrCanDataPlay);
lv_obj_set_pos(guider_ui.CanDataPlayLabel6, CHINESELABWIDTH, 25);
lv_obj_set_size(guider_ui.CanDataPlayLabel6, INFORMATIONLABWIDTH, INFORMATIONLABHIGH);
lv_obj_set_scrollbar_mode(guider_ui.CanDataPlayLabel6, LV_SCROLLBAR_MODE_OFF);
lv_label_set_text(guider_ui.CanDataPlayLabel6, "");
lv_label_set_long_mode(guider_ui.CanDataPlayLabel6, LV_LABEL_LONG_SCROLL);
lv_obj_add_style(guider_ui.CanDataPlayLabel6, &style_screen_label_all_main_main_default, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_scr_load(guider_ui.ScrCanDataPlay);
uint64_t PlayCounter;
uint64_t CanDataPlayTotalCount = 12345;
char PlayCounterStr[50];
lv_label_set_text_fmt(guider_ui.CanDataPlayLabel6,"%lld Times",PlayCounter);
DelayMs(1);//1 ms delay
lv_label_set_text_fmt(guider_ui.CanDataPlayLabel6,“%lld Times”,PlayCounter); //updata the last time
printf("CanDataPlayTotalCount =%lld\r\n",CanDataPlayTotalCount);
sprintf(PlayCounterStr,“%lld Times”,PlayCounter);//updata the last time
