How do you change the focus style for the button matrix of a tabview?
V7
change the color of the focused button when the tab is selected.
I have tried the code below and the button pressed state color changes so I think coding is right. But the focused state color does not change.
What am I missing?
Thanks
static lv_style_t style8;
lv_style_init(&style8);
lv_style_set_bg_color(&style8, LV_STATE_FOCUSED, LV_COLOR_GREEN); // FOCUSED is not working ???
lv_style_set_bg_color(&style8, LV_STATE_PRESSED, LV_COLOR_RED);
lv_obj_add_style(tabview, LV_TABVIEW_PART_TAB_BTN, &style8);
I looked through lv_tabview_set_act. It looks like the tabview uses the “checked” feature of the button matrix on selected tabs, so I think you’re looking for LV_STATE_CHECKED, not LV_STATE_FOCUSED. I’ve submitted a pull request to add this to the docs here.
Hello, thanks for the quick response. But I have tried the LV_STATE_CHECKED and it does not work either. I still only get the red pressed state.
Also I added a default state below and that is not working either.
lv_style_set_bg_color(&style8, LV_STATE_DEFAULT, LV_COLOR_CYAN); // DEFAULT is not working ???
I have also tried adding this style to the tab and the tabview with no luck. But the border width is working and border color. when added to the tabview LV_TABVIEW_PART_TAB_BTN.
Any other suggestions?
I have tried a lot of things now. It all works if I just create a BTNMATRIX. I can get the checked state to display the correct color. it just will not work in the Tabview. I have even tried to run the same code that worked on the BTNMATRIX by setting it directly on the tabview’s btnmatrix, with ext->btns, but that does not work either.
I have also checked that the btmmatrix button 0 is in the checked state.
What is different about the btmmatrix in the tabview?
Also I’m running lv_arduino which has V7.0.2 and I noticed the current version is 7.3 could this be the issue? if so when will lv_arduino be updated?
