Sync crown features to pointer input device
Before posting
BES2700BP
I am using LVGL 8.3
I am syncing the commit of #5057, some functions depend on some previous modifications, such as send_event(LV_EVENT_ROTARY, &diff); . What other previous modifications do I also need to sync? Thank you.
It’s might be complicated to cherry-pick this feature from v9 to v8.
What is the main problem with updating your project to v9?
Hi kisvegabor,
The current code has been merged for adaptation, but the rotary knob is not responding. However, some functions are missing, and I am still using version 8, I am not sure if it has any impact.
/* get crown movemnet_px */
static void lv_knob_read(lv_indev_drv_t *indev_drv, lv_indev_data_t *data)
    static lv_coord_t last_y  = 0;
    static int16_t knob_diff = 0;
    if (knob_is_rotating()) {
          knob_get_movement_px(&knob_diff);
          STO_LOG_ERR(T_DRV_KNOB, ">>> knob_diff: %3d", knob_diff);
          data->enc_diff = knob_diff;
      } else {
static void indev_proc_pointer_diff(lv_indev_t * indev)
    lv_obj_t * obj = indev->proc.types.pointer.last_pressed;
    if(obj == NULL) {
        LV_LOG_WARN("obj is NULL.");
        return;
    if(indev->proc.types.pointer.diff == 0) {
        LV_LOG_WARN("diff is 0.");
        return;
    indev_obj_act = obj;
    bool editable = lv_obj_is_editable(obj);
    if(editable) {
        uint32_t indev_sensitivity = indev->driver->rotary_sensitvity;
        uint32_t obj_sensitivity = lv_obj_get_style_rotary_sensitivity(indev_obj_act, 0);
        int32_t diff = (int32_t)((int32_t)indev->proc.types.pointer.diff * indev_sensitivity * obj_sensitivity + 32768) >> 16;
        // send_event(LV_EVENT_ROTARY, &diff);
        lv_event_send(indev_obj_act, LV_EVENT_ROTARY, &diff);
    else {
        int32_t vect = indev->proc.types.pointer.diff > 0 ? indev->driver->scroll_limit : -indev->driver->scroll_limit;
        indev->proc.types.pointer.vect.y = vect;
        indev->proc.types.pointer.act_obj = obj;
        lv_obj_t * scroll_obj = find_scroll_obj(&(indev->proc));
        if(scroll_obj == NULL) {
            LV_LOG_WARN("scroll_obj is NULL.");
            return;
        uint32_t obj_sensitivity = lv_obj_get_style_rotary_sensitivity(scroll_obj, 0);
        indev->proc.types.pointer.scroll_throw_vect.y = diff;
        indev->proc.types.pointer.scroll_throw_vect_ori.y = diff;
        _lv_indev_scroll_handler(&(indev->proc));
For a watch crown that only functions to scroll through the menu list, is ‘editable’ always set to ‘false’, and therefore no ‘LV_EVENT_ROTARY’ event will be generated? I’m not sure if my understanding is correct.
The mouse-related code has not been merged; currently, it is not needed for the crown.
A total of 22 files have been modified.
The function “indev_proc_press” has not been modified.
 * Process the pressed state of LV_INDEV_TYPE_POINTER input devices
 * @param indev pointer to an input device 'proc'
 * @return LV_RES_OK: no indev reset required; LV_RES_INV: indev reset is required
static void indev_proc_press(_lv_indev_proc_t * proc)
    LV_LOG_INFO("pressed at x:%d y:%d", proc->types.pointer.act_point.x, proc->types.pointer.act_point.y);
    indev_obj_act = proc->types.pointer.act_obj;
    if(proc->wait_until_release != 0) return;
    lv_disp_t * disp = indev_act->driver->disp;
    bool new_obj_searched = false;
    /*If there is no last object then search*/
    if(indev_obj_act == NULL) {
        indev_obj_act = lv_indev_search_obj(lv_disp_get_layer_sys(disp), &proc->types.pointer.act_point);
        if(indev_obj_act == NULL) indev_obj_act = lv_indev_search_obj(lv_disp_get_layer_top(disp),
        if(indev_obj_act == NULL) indev_obj_act = lv_indev_search_obj(lv_disp_get_scr_act(disp),
        new_obj_searched = true;
    /*If there is last object but it is not scrolled and not protected also search*/
    else if(proc->types.pointer.scroll_obj == NULL &&
            lv_obj_has_flag(indev_obj_act, LV_OBJ_FLAG_PRESS_LOCK) == false) {
    /*The last object might have scroll throw. Stop it manually*/
    if(new_obj_searched && proc->types.pointer.last_obj) {
        proc->types.pointer.scroll_throw_vect.x = 0;
        proc->types.pointer.scroll_throw_vect.y = 0;
        _lv_indev_scroll_throw_handler(proc);
        if(indev_reset_check(proc)) return;
    /*If a new object was found reset some variables and send a pressed event handler*/
    if(indev_obj_act != proc->types.pointer.act_obj) {
        proc->types.pointer.last_point.x = proc->types.pointer.act_point.x;
        proc->types.pointer.last_point.y = proc->types.pointer.act_point.y;
        /*If a new object found the previous was lost, so send a Call the ancestor's event handler*/
        if(proc->types.pointer.act_obj != NULL) {
            /*Save the obj because in special cases `act_obj` can change in the Call the ancestor's event handler function*/
            lv_obj_t * last_obj = proc->types.pointer.act_obj;
            lv_event_send(last_obj, LV_EVENT_PRESS_LOST, indev_act);
        proc->types.pointer.act_obj  = indev_obj_act; /*Save the pressed object*/
        proc->types.pointer.last_obj = indev_obj_act;
        if(indev_obj_act != NULL) {
            /*Save the time when the obj pressed to count long press time.*/
            proc->pr_timestamp                 = lv_tick_get();
            proc->long_pr_sent                 = 0;
            proc->types.pointer.scroll_sum.x     = 0;
            proc->types.pointer.scroll_sum.y     = 0;
            proc->types.pointer.scroll_dir = LV_DIR_NONE;
            proc->types.pointer.gesture_dir = LV_DIR_NONE;
            proc->types.pointer.gesture_sent   = 0;
            proc->types.pointer.gesture_sum.x  = 0;
            proc->types.pointer.gesture_sum.y  = 0;
            proc->types.pointer.vect.x         = 0;
            proc->types.pointer.vect.y         = 0;
            /*Call the ancestor's event handler about the press*/
            lv_event_send(indev_obj_act, LV_EVENT_PRESSED, indev_act);
            if(indev_act->proc.wait_until_release) return;
            /*Handle focus*/
            indev_click_focus(&indev_act->proc);
    /*Calculate the vector and apply a low pass filter: new value = 0.5 * old_value + 0.5 * new_value*/
    proc->types.pointer.vect.x = proc->types.pointer.act_point.x - proc->types.pointer.last_point.x;
    proc->types.pointer.vect.y = proc->types.pointer.act_point.y - proc->types.pointer.last_point.y;
    proc->types.pointer.scroll_throw_vect.x = (proc->types.pointer.scroll_throw_vect.x + proc->types.pointer.vect.x) / 2;
    proc->types.pointer.scroll_throw_vect.y = (proc->types.pointer.scroll_throw_vect.y + proc->types.pointer.vect.y) / 2;
    proc->types.pointer.scroll_throw_vect_ori = proc->types.pointer.scroll_throw_vect;
    if(indev_obj_act) {
        lv_event_send(indev_obj_act, LV_EVENT_PRESSING, indev_act);
        _lv_indev_scroll_handler(proc);
        indev_gesture(proc);
        /*If there is no scrolling then check for long press time*/
        if(proc->types.pointer.scroll_obj == NULL && proc->long_pr_sent == 0) {
            /*Call the ancestor's event handler about the long press if enough time elapsed*/
            if(lv_tick_elaps(proc->pr_timestamp) > indev_act->driver->long_press_time) {
                lv_event_send(indev_obj_act, LV_EVENT_LONG_PRESSED, indev_act);
                /*Mark the Call the ancestor's event handler sending to do not send it again*/
                proc->long_pr_sent = 1;
                /*Save the long press time stamp for the long press repeat handler*/
                proc->longpr_rep_timestamp = lv_tick_get();
        /*Send long press repeated Call the ancestor's event handler*/
        if(proc->types.pointer.scroll_obj == NULL && proc->long_pr_sent == 1) {
            /*Call the ancestor's event handler about the long press repeat if enough time elapsed*/
            if(lv_tick_elaps(proc->longpr_rep_timestamp) > indev_act->driver->long_press_repeat_time) {
                lv_event_send(indev_obj_act, LV_EVENT_LONG_PRESSED_REPEAT, indev_act);
Hi kisvegabor,
Currently, there are several other issues with the project. My original intention was to make minimal changes to avoid triggering additional problems, and I plan to upgrade in new projects in the future, which is why I haven’t upgraded to version 9. Do you have any good suggestions?
I’m sorry, but in lack of time I cannot immerse in this topic now. :frowning:
To find the root of the issue I recommend debugging it on PC. By clicking through the code you should find where the information is lost. At least I’d do this.
I’m planning to use the lv_port_win_codeblock simulator for debugging. Thank you.
