Before posting
I activate ILI9488 but I can’t open it in LVGL. As far as I’ve read on the forum, I need to use my disp flsuh function. Is there an example for this?
STM32F407 Discovery /Cube IDE
LVGL v8.3
IRunning ILI9488 from FSMC mode using stm32f4 discovery
I tested TFT from this library and tried to add the run My disp flush function to this library
static void tft_flush(lv_disp_drv_t * drv, const lv_area_t * area, lv_color_t * color_p)
/Return if the area is out the screen/
if(area->x2 < 0) return;
if(area->y2 < 0) return;
if(area->x1 > ILI9488_LCD_PIXEL_WIDTH - 1) return;
if(area->y1 > ILI9488_LCD_PIXEL_HEIGHT - 1) return;
int32_t act_x2 = area->x2 > ILI9488_LCD_PIXEL_WIDTH - 1 ? ILI9488_LCD_PIXEL_WIDTH - 1 : area->x2;
int32_t act_y2 = area->y2 > ILI9488_LCD_PIXEL_HEIGHT - 1 ? ILI9488_LCD_PIXEL_HEIGHT - 1 : area->y2;
x1_flush = act_x1;
y1_flush = act_y1;
x2_flush = act_x2;
y2_fill = act_y2;
y_fill_act = act_y1;
buf_to_flush = color_p;
/*##-7- Start the DMA transfer using the interrupt mode #*/
/* Configure the source, destination and buffer size DMA fields and Start DMA Stream transfer */
/* Enable All the DMA interrupts */
static volatile uint32_t t_saved = 0;
void monitor_cb(lv_disp_drv_t * d, uint32_t t, uint32_t p)
t_saved = t;
void tft_init(){
static lv_color_t disp_buf1[ILI9488_LCD_PIXEL_WIDTH * 30];
static lv_color_t disp_buf2[ILI9488_LCD_PIXEL_HEIGHT * 30];
static lv_disp_draw_buf_t buf;
lv_disp_draw_buf_init(&buf, disp_buf1, disp_buf2, (10UL * 1024UL)/2);
lv_disp_drv_init(&disp_drv);
ili9488_Init();
disp_drv.draw_buf = &buf;
disp_drv.flush_cb = tft_flush;
disp_drv.monitor_cb = monitor_cb;
disp_drv.hor_res = ILI9488_LCD_PIXEL_WIDTH;
disp_drv.ver_res = ILI9488_LCD_PIXEL_HEIGHT;
