Before posting
masterbranch.- Try to reproduce the issue in a Simulator. If it’s working there then probably it’s not a LittlevGL issue.
STM32F407VE
What do you experience?
Give a detailed description. “It doesn’t work” is not enough information for us to diagnose the issue.
What do you expect?
I am new to lvgl. When I do not use DMA everything is fine but when I use DMA the color display is no longer accurate.
Add a code snippet to reproduce the issue in the simulator. It should contain only the relevant code which can be compiled. Bug reports without code snippets or with erroneous code snippets will not be reviewed.
Use the ```c and ``` tags to format your code:
lv_disp_drv_t *disp_dma;
/*The most simple case (but also the slowest) to put all pixels to the screen one-by-one*/
disp_dma = disp_drv;
ili9341_setaddress(area->x1, area->y1,area->x2, area->y2);
LCD_WRX_HIGH();
/* Reset LCD control line(/CS) and Send data */
LCD_CS_LOW();
uint32_t size = lv_area_get_width(area) * lv_area_get_height(area);
if ( HAL_SPI_Transmit_DMA(&hspi2, (uint8_t *)color_p, size*2) != HAL_OK) {
void HAL_SPI_TxCpltCallback(SPI_HandleTypeDef *hspi)
LCD_CS_HIGH();
lv_disp_flush_ready(disp_dma);
# when i not use DMA then this worked
LCD_WRX_HIGH();
LCD_CS_LOW();
if((SPI2->CR1 & SPI_CR1_SPE) != SPI_CR1_SPE)
// If disabled, I enable it
SET_BIT(SPI2->CR1, SPI_CR1_SPE);
for(uint32_t i=0;i<size;i++) {
//// for(x = area->x1; x <= area->x2; x++) {
//// /* Put a pixel to the display. For example: */
//// /* put_px(x, y, *color_p)*/
*((__IO uint8_t *)&hspi2.Instance->DR) = (color_p->full)>>8;
while(!__HAL_SPI_GET_FLAG(&hspi2, SPI_FLAG_TXE));
*((__IO uint8_t *)&hspi2.Instance->DR) = (color_p->full);
color_p++;
CLEAR_BIT(SPI2->CR1, SPI_CR1_SPE);
// /* IMPORTANT!!!
// * Inform the graphics library that you are ready with the flushing*/
// LCD_CS_HIGH();
