Before posting
Debian GNU/Linux 11, Linux 6.1.21
8.3.11
I would like to take the current code that i have reading sensors on the raspberry pi and allow the dynamic changing of the lvgl text widgets on an exported squareline studios file with new values after a change in sensing occurs.
This is the current code that reads the sensors
import RPi.GPIO as GPIO
import time
GPIO setup
GPIO.setmode(GPIO.BCM)
Define sensor pins
sensor_pins = [19, 26, 20, 21]
num_players = 1
max_holes = 9
sensors_per_turn = 2
Set up each sensor pin as input with pull-down resistor
for pin in sensor_pins:
GPIO.setup(pin, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
Initialize player data
players = [{“score”: 0, “current_hole”: 1, “detection_count”: 0} for _ in range(num_players)]
last_activation_times = {pin: 100 for pin in sensor_pins} # Track last activation times for each sensor
DEBOUNCE_TIME = 3 # Time to prevent multiple sensor readings
current_player_index = 0
def sensor_callback(channel):
global players
global last_activation_times
global current_player_index
current_time = time.time()
# Debugging: Print which channel was triggered
#print(f"Channel {channel} triggered. Detection count: {players[current_player_index]['detection_count']}")
# Check for valid detection and debounce
if current_time - last_activation_times[channel] > DEBOUNCE_TIME:
last_activation_times[channel] = current_time
player = players[current_player_index]
# Only proceed if the current player has not reached the sensor limit for this turn
if player["detection_count"] < sensors_per_turn:
if channel == sensor_pins[0]:
player["score"] += 3
elif channel == sensor_pins[1]:
player["score"] += 4
elif channel == sensor_pins[2]:
player["score"] += 5
elif channel == sensor_pins[3]:
player["score"] += 0
player["detection_count"] += 1
print(f"Player {current_player_index + 1} - {player['current_hole']} - {player['detection_count']} - Score: {player['score']}")
# Check if the player has completed their turn
if player["detection_count"] == sensors_per_turn:
player["current_hole"] += 1
player["detection_count"] = 0 # Reset detection count for the next turn
current_player_index = (current_player_index + 1) % num_players # Move to the next player
# Check if all players have finished 9 holes
if all(player["current_hole"] > max_holes for player in players):
print("All players have completed the game.")
GPIO.cleanup(sensor_pins)
exit(0) # End the program
Add event detection for each sensor pin
GPIO.add_event_detect(pin, GPIO.FALLING, callback=sensor_callback, bouncetime=3500)
print(“Waiting for sensor inputs…”)
try:
while True:
time.sleep(1)
except KeyboardInterrupt:
print(“Exiting Program…”)
finally:
GPIO.cleanup(sensor_pins) # Clean up all sensor pins
