Before posting
My TFT screen resolution is 292240, but my camera data is 320 240.
I want to show the camera data on the screen.
ARM M4 288MHz
8.3
Show the Image and cut some parts
m_UVC_dsc_t.header.cf = LV_IMG_CF_TRUE_COLOR;
m_UVC_dsc_t.header.always_zero = 0;
m_UVC_dsc_t.header.reserved = 0;
m_UVC_dsc_t.header.w = 320;
m_UVC_dsc_t.header.h = 240;
m_UVC_dsc_t.data_size = 320 * 240 * 2;
m_pConUVC = lv_obj_create(guider_ui.screen);
lv_obj_set_pos(m_pConUVC, 0, 0);
lv_obj_set_size(m_pConUVC, 296, 240);
lv_obj_set_scrollbar_mode(m_pConUVC, LV_SCROLLBAR_MODE_ON);
lv_obj_clear_flag(m_pConUVC, LV_OBJ_FLAG_HIDDEN);
lv_obj_set_style_border_width(m_pConUVC, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_radius(m_pConUVC, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_opa(m_pConUVC, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_color(m_pConUVC, lv_color_hex(0xffffff), LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_grad_dir(m_pConUVC, LV_GRAD_DIR_NONE, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_top(m_pConUVC, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_bottom(m_pConUVC, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_left(m_pConUVC, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_right(m_pConUVC, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_shadow_width(m_pConUVC, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
m_pUVCImage = lv_img_create(m_pConUVC);
lv_obj_set_size(m_pUVCImage, 320, 240);
lv_obj_align(m_pUVCImage, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_style_pad_top(m_pUVCImage, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_bottom(m_pUVCImage, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_left(m_pUVCImage, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_pad_right(m_pUVCImage, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_border_width(m_pUVCImage, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
And In Camera callback:
unsigned short* pd;
m_isUVCUpdate = 1;
m_UVC_dsc_t.data = (unsigned char*)pdata;
pd = (unsigned short*)pdata;
for (int i = 0; i < 320 * 240; i ++) {
pd[i] = swap_short_endian(pd[i]);
lv_img_set_src(m_pUVCImage, &m_UVC_dsc_t);
Now I can show the camera data, but it have a strange retangle. How to delete it?
And another question, how to support LSB RGB data? now you can see I need swap each data, it is not good solution.
