Before posting
how can I get a bit map data of a PNG image by C code?
ARM335X
V6.0.2/v8.0.1
- I want to convert an PNG image from file and convert it to a C array through C code. Like the Online Image Converter, the C array is what I need. more accurately, how to read a PNG image file and generate the RGB
lv_img_dsc_tstruct memberuint8_t* datamap。 - I want to show the video stream in LVGL , is LVGL support video stream? Or if I received a video stream buffer from video device, the I want to show one frame image through the LVGL, is it can achieved?
I have tried lv_lib_png and use lodepng , but it seems work not so well.
