Before posting
Get familiar with Markdown to format and structure your post
Be sure to update lvgl from the latest version from the master branch.
Be sure you have checked the relevant part of the documentation.
If applicable use the Simulator to eliminate hardware related issues.
I have several questions about using chart widget
If I add 4 series to a chart, how to hide one or more series in some case?
In the docs example lv_example_chart_5, how to show the x axis value of pressed points?
In the lv_example_chart_6 has an API called lv_obj_draw_part_check_type, but I didn’t found it in version 8.0.1? Is it a mistake?
8.0.1
As for the second question, in lv_example_chart_5 I display 1000 data with zoom, then I want to show the x axis ,range from 1~1000, and I add some codes in the examples
Another quesion, in lv_example_chart_4 it can show the value of the point, I combine this example with lv_example_chart_5(it mean display 1000 points and can show the pressed point value), now I want to show the x axis when I pressed one point, so I add some codes
Thanks, I tried lv_chart_set_type(chart, LV_CHART_TYPE_SCATTER),the line becomes wired and the chart_event_cb seems can’t show the pressed point value.
Yes, so if I used the line chart to show 30000 datas, and I use the zoom effect, then how to set X axis to show the range from 1~30000 while the chart is zooming
The fact is , based on the code of lv_example_chart_5, I add the Y axis tick by lv_chart_set_axis_tick(), it shows the Y axis tick well. Then I add the X axis tick by lv_chart_set_axis_tick(chart, LV_CHART_AXIS_PRIMARY_X, 10, 5, 20, 2, true, 50), the number of major ticks on the axis is 20, so the expected tick labels should be “0, 1500, 3000 …”, for I set the range is (0, 30000), but in fact it shows 0, 1, 2, …19, it seems it’s worthless by set X axis tick in the lv_example_chart_5
