Setting rotated option in lv_disp_drv_t causes hard fault
stm32f746_discovery_no_os demo program hard faults when i try to rotate the display.
STM32 F746 discovery board + SW4STM32 IDE
I want to rotate the display clock wise by 90 Deg.
I tested this feature in the simulator and it works fine. I changed the following things in the simulator.
in win_drv.c
disp_drv.rotated = 1;
in lv_drv_conf.h
define WINDOW_HOR_RES 272
define WINDOW_VER_RES 480
in lv_conf.h
#define LV_HOR_RES_MAX (272)
#define LV_VER_RES_MAX (480)
When i make similar changes in the STM32 program, i get a hard fault.
What could be the issue?
Thanks
LV_HOR_RES_MAX is used as size of a line buffer. After rotation the line length is 480, so either use landscape as default orientation or use 480 for both HOR and RES
The rotated option requires additional logic in the driver which I haven’t implemented yet, so it’s not going to work at the moment. Sorry about that.
@beppone: @polmon already mentioned that he has changed the appropriate defines to the correct values.
Can i rotate the buf_to_flush array while copying to my_fb?
You can, just read buf_to_flush column-by-column instead of it’s row-by-row.
I have tried the following code to read col by col. But i cant seem to find the issue.
I made the screen into a 272 x 272 square.
for (x_fill_act = x1_flush ; x_fill_act <= x2_flush; x_fill_act++)
for(y_fill_act = act_y1; y_fill_act <= y2_fill; y_fill_act ++)
memcpy((uint32_t)&my_fb[(271 - x_fill_act) * 272 + y_fill_act], (uint32_t)(buf_to_flush + (272*y_fill_act + x_fill_act)),2);
I managed to get it ALMOST working with the following code.
  for (x_fill_act = x2_flush ; x_fill_act >= x1_flush; x_fill_act--)
       memcpy((uint32_t)&my_fb[(271 - x_fill_act) * (272) + y_fill_act], (uint32_t)(buf_to_flush + x_fill_act + (y_fill_act - act_y1)*(x2_flush - x1_flush + 1)),2);
However there is still some issue with the copying algorithm. I get the following issue in the attached picture.
Later today I’ll create an an example rotate function.
Here is the code which worked me in the simulator:
void get_col(const lv_color_t * src, const lv_area_t * area, lv_coord_t y, lv_color_t * dest)
    lv_coord_t w = lv_area_get_width(area);
    lv_coord_t h = lv_area_get_height(area);
    lv_coord_t i;
    for(i = 0; i < h; i++) {
        dest[i].full = src[y].full;
        src += w ;
void monitor_flush(lv_disp_drv_t * disp_drv, const lv_area_t * area, lv_color_t * color_p)
    lv_coord_t x2 = area->x2;
    if(x2 >= disp_drv->ver_res) x2 = MONITOR_VER_RES - 1;
    lv_color_t * dest = (lv_color_t *)monitor.tft_fb;
    dest +=  MONITOR_HOR_RES * (MONITOR_VER_RES - 1);
    dest -= MONITOR_HOR_RES * area->x1;
    lv_coord_t x;
    for(x = area->x1; x <= x2; x++) {
          get_col(color_p, area, (x - area->x1), dest + area->y1);
          dest -= MONITOR_HOR_RES;
Works like a charm! Thank you!
Great! :slight_smile:
It was already asked a lot times. Good to know that there is a working reference code now.
polmon can you post your results?
what is monitor.tft_fb and how to define it?
It’s the target frame buffer.
However now display rotation is available as built-in feature too. See Display interface — LVGL documentation
What is this “monitor.tft_fb” buffer, And where should I get its location in LVGL 9.1.1
It’s an old topic. Please open a new topic one to describe what you are trying to achieve and with which LVGL version.
New thread created, Please follow below link
yes in rk3566 i meet the same problem
