Rotating the buffer in fbdev.c
I am trying to rotate the screen on an external display (not simulator), which uses HDMI and the framebuffer.
HDMI display on Linux-PC
7.x
Rotate the display from landscape to portrait.
Changes in fbdev.c analogue to (example is for simulator) :
At the moment I have to multiply:
LV_HOR_RES_MAX by 2
LV_VER_RES_MAX by 1.2 (or LOW_VER_RES_MAX + LOW_VER_RES_MAX/4+1)
so
if LV_HOR_RES_MAX is 240, it has to be set to 480
and LV_VER_RES_MAX from 400 to 480
so that it works, I don’t know, what part is wrong.
fbdev.c change (code is largely copied from) :
void get_col2(const uint32_t * src, const lv_area_t * area, int32_t y, uint32_t * dest)
    lv_coord_t w = lv_area_get_width(area);
    lv_coord_t h = lv_area_get_height(area);
    lv_coord_t i;
    for(i = 0; i < h; i++) {
        dest[i] = src[y];
        src += w ;
 * Flush a buffer to the marked area
 * @param drv pointer to driver where this function belongs
 * @param area an area where to copy `color_p`
 * @param color_p an array of pixel to copy to the `area` part of the screen
void fbdev_flush(lv_disp_drv_t * drv, const lv_area_t * area, lv_color_t * color_p)
    if(fbp == NULL ||
            area->x2 < 0 ||
            area->y2 < 0 ||
            area->x1 > (int32_t)vinfo.xres - 1 ||
            area->y1 > (int32_t)vinfo.yres - 1) {
        lv_disp_flush_ready(drv);
        return;
    int32_t act_x2 = area->x2 > (int32_t)vinfo.xres - 1 ? (int32_t)vinfo.xres - 1 : area->x2;
    int32_t act_y2 = area->y2 > (int32_t)vinfo.yres - 1 ? (int32_t)vinfo.yres - 1 : area->y2;
    lv_coord_t w = (act_x2 - act_x1 + 1);
    long int location = 0;
    long int byte_location = 0;
    unsigned char bit_location = 0;
    /*32 or 24 bit per pixel*/
    if(vinfo.bits_per_pixel == 32 || vinfo.bits_per_pixel == 24) {
        // uint32_t * fbp32 = (uint32_t *)fbp;
        // int32_t y;
        // for(y = act_y1; y <= act_y2; y++) {
        //     location = (act_x1 + vinfo.xoffset) + (y + vinfo.yoffset) * finfo.line_length / 4;
        //     memcpy(&fbp32[location], (uint32_t *)color_p, (act_x2 - act_x1 + 1) * 4);
        //     color_p += w;
        lv_coord_t x2 = area->x2;
        if(x2 >= drv->ver_res) x2 = LV_VER_RES_MAX - 1;
        uint32_t* dest = (uint32_t *)fbp;
        dest +=  LV_HOR_RES_MAX * (LV_VER_RES_MAX - 1);
        dest -= LV_HOR_RES_MAX * area->x1;
        int32_t x;
        for(x = area->x1; x <= x2; x++) {
            get_col2(color_p, area, (x - area->x1), dest + area->y1);
            dest -= LV_HOR_RES_MAX;
In v7.11 @embeddedt added a software rotation option. See here: https://github.com/lvgl/lvgl/blob/acf42d399977eecfc431f9dd0bbb070724bd8e0a/src/lv_hal/lv_hal_disp.h#L86-L87
Awesome thanks to @embeddedt and you. I’ll have to look into it, how you did it. The operation has O(n^2) complexity as far as I see.
Besides enabling that software rotation option; which code should be implemented in runtime to get the display to rotate? What function should I call?
See Display interface — LVGL documentation
