Segmentation fault happens when recreate canvas buffer
Before posting
My program may repeatedly enter and exit a new page that needs to use the canvas. In order to save memory, I will free the buffer of the canvas every time I exit. However, I find that sometimes after I re-enter the page and create the canvas and buffer, the image buffer pointer used by lvgl’s drawing task is still the buffer used last time, but it has been freed , so there will be a segment error problem. At first, I thought it was my hardware problem, but I tested on the simulator and meet this problem either. What is the reason? Is there any problem with the way I use canvas? How to solve it?
lvgl simulator for windows
LVGL-7.4
delete and recerate canvas and buffer correctly
lv_obj_del(canvas);
free(buf);
void test_func()
lv_obj_t* canvas = NULL;
unsigned char* buf = NULL;
while(1)
    buf = (unsigned char*)malloc(LV_CANVAS_BUF_SIZE_TRUE_COLOR(720, 480));
    memset(buf, 0, LV_CANVAS_BUF_SIZE_TRUE_COLOR(720, 480));
    canvas = lv_canvas_create(lv_scr_act(), NULL);
    lv_canvas_set_buffer(canvas, buf, 720, 480, LV_IMG_CF_TRUE_COLOR);
    printf("\n\ncanvas:%#X, buf:%#X\n", canvas, buf);
    sleep(1);
    lv_obj_del(canvas);
    free(buf);
    canvas = NULL;
    buf = NULL;
    sleep(1);
LV_ATTRIBUTE_FAST_MEM static lv_res_t lv_img_draw_core(const lv_area_t * coords, const lv_area_t * clip_area,
                                                   const void * src,
                                                   const lv_draw_img_dsc_t * draw_dsc)
if(draw_dsc->opa <= LV_OPA_MIN) return LV_RES_OK;
lv_img_cache_entry_t * cdsc = _lv_img_cache_open(src, draw_dsc->recolor);
printf("cdsc:%#X\n", cdsc);
printf("img_data:%#X\n", cdsc->dec_dsc.img_data);
if(cdsc == NULL) return LV_RES_INV;
Before deleting the canvas try calling lv_img_cache_invalidate_src(lv_canvas_get_img(canvas)).
I suggest updating at least to v7.11. This issue is already fixed there.
Thanks for the answer
