Before posting
BES2700BP
v8.3
Scroll propagation in multi-layer Flex layouts to parent objects.
Analyze the implementation of the lv_indev_find_scroll_obj function.
lv_obj_t * lv_indev_find_scroll_obj(lv_indev_t * indev)
/*Vertical scroll*/
snap_cnt = 0;
int32_t st = 0;
int32_t sb = 0;
lv_scroll_snap_t snap_y = lv_obj_get_scroll_snap_y(obj_act);
if(snap_y != LV_SCROLL_SNAP_NONE) {
uint32_t child_cnt = lv_obj_get_child_count(obj_act);
uint32_t i;
for(i = 0; i < child_cnt; i++) {
if(lv_obj_has_flag(lv_obj_get_child(obj_act, i), LV_OBJ_FLAG_SNAPPABLE)) {
snap_cnt++;
if(snap_cnt == 2) {
st = 1; /*Assume scrolling*/
sb = 1;
break;
if(snap_y == LV_SCROLL_SNAP_NONE || snap_cnt < 2) {
st = lv_obj_get_scroll_top(obj_act);
sb = lv_obj_get_scroll_bottom(obj_act);
/*If this object is scrollable into the current scroll direction then save it as a candidate.
*It's important only to be scrollable on the current axis (hor/ver) because if the scroll
*is propagated to this object it can show at least elastic scroll effect.
*But if not hor/ver scrollable do not scroll it at all (so it's not a good candidate)*/
if((st > 0 || sb > 0) &&
((up_en && obj_scroll_sum.y >= scroll_limit) ||
(down_en && obj_scroll_sum.y <= - scroll_limit))) {
obj_candidate = obj_act;
dir_candidate = LV_DIR_VER;
if(st <= 0) up_en = false;
if(sb <= 0) down_en = false;
if(sl <= 0) left_en = false;
if(sr <= 0) right_en = false;
/*Try the parent*/
obj_act = lv_obj_get_parent(obj_act);
