Scroll_to_y may unuseful sometimes,how to deal it?
Before posting
Linux
lvglV8.3.0
scroll_to_y to set the custom roller be set to index 0
I design a custom roller ,it can scroll to other index insted of 0 ,1,28,29…(there are the first、second One)
//created by Sean on 2024.1.2
//实现基础的自定义roller样式,其他效果需自行实现
#include "view.h"
typedef struct scrollParam
    int step;
    int first_y;
    int selectindex;
}scrollParam_t;
static void scroll_event(lv_event_t * e)
    lv_obj_t * scroll_container = lv_event_get_target(e);                                               // 获取事件的初始对象
    scrollParam_t *param = (scrollParam_t*)e->user_data;
    lv_coord_t scroll_y = lv_obj_get_scroll_y(scroll_container);
    printf("scroll_y = %d \r\n",scroll_y);//看打印知道位置-100 -42 16 xxx(步进58)
    //这个是get_selected
    if ((scroll_y-(param->first_y))%param->step == 0) //选中项
        param->selectindex = (scroll_y-(param->first_y))/param->step;//选中项
        printf("param->selectindex = %d \r\n",param->selectindex);
    for (int i = 0; i < lv_obj_get_child_cnt(scroll_container); i++) {
        lv_obj_t * item = lv_obj_get_child(scroll_container, i);
        lv_obj_t* label = lv_obj_get_child(lv_obj_get_child(scroll_container, i),0);
        int child_scroll_y = i*param->step+(param->first_y);
        //选中的样式
        if ( scroll_y > child_scroll_y - param->step/2 && scroll_y < child_scroll_y + param->step/2) {
            lv_obj_set_style_text_font(label,biz_fonts.ft_regular_60.font,0);
            lv_obj_set_style_text_opa(label,255,0);
            // printf("1 = %d \r\n",lv_obj_get_y(label));//10
            // lv_obj_set_y(label,10);
            lv_obj_set_align(label,LV_ALIGN_CENTER);
        else if ( scroll_y > child_scroll_y - param->step/2 - param->step && scroll_y < child_scroll_y + param->step/2 + param->step) {
            lv_obj_set_style_text_font(label,biz_fonts.ft_regular_36.font,0);
            lv_obj_set_style_text_opa(label,200,0);
            // printf("2 = %d \r\n",lv_obj_get_y(label));//24
            // lv_obj_set_y(label,24);
        else //非选中样式
            lv_obj_set_style_text_font(label,biz_fonts.ft_regular_18.font,0);
            lv_obj_set_style_text_opa(label,150,0);
            // printf("3 = %d \r\n",lv_obj_get_y(label));//35
            if (i < param->selectindex)
                lv_obj_set_align(label,LV_ALIGN_BOTTOM_MID);
                lv_obj_set_align(label,LV_ALIGN_TOP_MID);
lv_obj_t *view_custom_roller_create(lv_obj_t *parent,uint16_t width,uint16_t height,uint16_t num,uint16_t visable_sum)
    lv_obj_t *container = lv_obj_create(parent);
    lv_obj_style_clean(container);//clean后设置bg color等style属性就会无效了
    // lv_obj_set_style_border_width(container,0,0);
    // lv_obj_set_style_bg_color(container,lv_color_hex(0x000000), 0);
    lv_obj_add_flag(container,LV_OBJ_FLAG_SCROLLABLE);
    lv_obj_set_scrollbar_mode(container, LV_SCROLLBAR_MODE_OFF);
    lv_obj_set_flex_flow(container, LV_FLEX_FLOW_COLUMN);
    //改父对象和子对象的size来实现visable
    lv_obj_set_size(container,width,height);
    lv_obj_set_scroll_snap_y(container, LV_SCROLL_SNAP_CENTER);
    for (size_t i = 0; i < num; i++)
        lv_obj_t *child = lv_obj_create(container);
        lv_obj_style_clean(child);
        lv_obj_set_height(child,height/visable_sum);
        lv_obj_t *label = lv_label_create(child);
        lv_obj_center(label);
        lv_label_set_text_fmt(label, "%d",i);
        lv_obj_set_style_text_color(label,lv_color_hex(0xffffff),0);
        lv_obj_set_style_text_align(label, LV_TEXT_ALIGN_CENTER, 0);
    container->user_data = (scrollParam_t*)malloc(sizeof(scrollParam_t));
    ((scrollParam_t*)(container->user_data))->step = height/visable_sum+8;
    ((scrollParam_t*)(container->user_data))->first_y = 0 - (visable_sum/2)*(height/visable_sum);
    // printf(" ((scrollParam_t*)(container->user_data))->step = %d , ((scrollParam_t*)(container->user_data))->y = %d \r\n", ((scrollParam_t*)(container->user_data))->step, ((scrollParam_t*)(container->user_data))->first_y);
    lv_obj_add_event_cb(container,scroll_event, LV_EVENT_SCROLL, container->user_data);
    //手动snap初始化
    lv_obj_update_snap(container,LV_ANIM_OFF);
    return container;
int view_custom_roller_get_selected(lv_obj_t *des)
    return ((scrollParam_t*)(des->user_data))->selectindex;
void view_custom_roller_set_selected(lv_obj_t *des,uint16_t index,lv_anim_enable_t anim_en)
    int pos = index*(((scrollParam_t*)(des->user_data))->step)+((((scrollParam_t*)(des->user_data))->first_y));
    printf("pos = %d step=%d firsty=%d \r\n",pos,(((scrollParam_t*)(des->user_data))->step),(((scrollParam_t*)(des->user_data))->first_y));
    lv_obj_scroll_to_y(des,pos,anim_en);
    //sean 现在仍然有bug,没法滚到前2个/后2个,需定位什么原因
I use this in main(),view_custom_roller_set_selected(_holder->custom_roller,5,LV_ANIM_ON);is okay,
but when I view_custom_roller_set_selected(_holder->custom_roller,0/1/29/30,LV_ANIM_ON);
scroll_to_y doesn't work,please tell me how to deal it~
    _holder->custom_roller = view_custom_roller_create(_layout,200,450,30,5);
    view_custom_roller_set_selected(_holder->custom_roller,0,LV_ANIM_ON);
I want to scroll to y ,index = 0/1/29/30,like this:
I can set this picture by drag a mouse , but the code lv_obj_scroll_to_y seems not effective
I mean your flex container cant scroll because alligned…
Simple way is add two dummy spaces instead 0…
hey gus,I solve my problem by change the set_selected function to this:
void view_custom_roller_set_selected(lv_obj_t des,uint16_t index,lv_anim_enable_t anim_en)
int pos = index
// printf(“pos = %d step=%d firsty=%d \r\n”,pos,(((scrollParam_t*)(des->user_data))->step),(((scrollParam_t*)(des->user_data))->first_y));
// lv_obj_scroll_to_y(des,pos,anim_en);
lv_obj_scroll_by(des,0,0-pos,anim_en);
lv_obj_update_snap(des,LV_ANIM_OFF);
Ok and FYI in roller you have two size font and more cool smooth opacity you can do with place image alpha gradient over roller object.
or fade mask Roller (lv_roller) — LVGL documentation
Thank you, brother. I will give it a try
