EDIT: Screen freezes.
ESP32.
lvgl v8.0.
I want it to work to reproduce my codes.
I want to use the latest version of LVGL.
N/A
I don’t think it will be necessary.
Can anyone send an example of disp_draw? because I think I’m missing something.
It seems it’s the duplication of I'm having problems with version 8.0 · Issue #2296 · lvgl/lvgl · GitHub
Let’s continue here.
Can you use a debugger to see where it freezes? Please also enable logging in LVGL.
[Trace] (0.000, +0) lv_timer_handler: begin (in lv_timer.c line #68)
[Trace] (0.000, +0) lv_timer_handler: finished (30 ms until the next timer call) (in lv_timer.c line #132)
What about this?
And how do you now it freezes? What it does or doesn’t do?
How do I do that? Should I add monitor_cb?
You said the “screen freezes”. We need to know exactly what happens and where the program stops.
My display flush:
uint64_t w = (area->x2 - area->x1 + 1);
uint64_t h = (area->y2 - area->y1 + 1);
tft.startWrite();
tft.pushColors(&color_p->full, w * h, true);
tft.endWrite();
Serial.print("Display flush width: ");
Serial.println(w);
Serial.print("Display flush height: ");
Serial.println(h);
lv_disp_flush_ready(disp);
I added a debugger.
Debugger:
Display flush width: 480
Display flush height: 50
Display flush height: 20
The program stops at:
[Info] (0.000, +0) lv_label_create: begin (in lv_label.c line #75)
But I don’t know what the mistake would be.
Note: TRACE does not send messages about LV_LOG_TRACE_INDEV and LV_LOG_TRACE_DISP_REFR.
And how that label create code looks like?
Also be sure that there is no warnings when you compile your code.
I’m using the music demo.
Please try a simpler example. E.g. lv_example_btn_1.
I’m getting this error: 'lv_example_btn_1' was not declared in this scope
You need to include #include "lvgl/examples/lv_examples.h".
lvgl/examples/lv_examples.h: No such file or directory
How does lvgl.h get included? You might have to use #include "examples/lv_examples.h" instead.
lvgl.h comes before examples/lv_examples.h
Ready, but still freezes
On which line does it freeze?
