Before posting
masterbranch.- Be sure you have checked the relevant part of the documentation.
There is a problem that the previous screen is erased to white when switching screens.
Visual studio 2017 simulation
v7.11
I hope it looks like the link below.
I looked at the docs but couldn’t find a solution.
lv_obj_t* btn1;
lv_obj_t* btn2;
LV_EVENT_CB_DECLARE(button_event_cb)
if ((obj == btn1) && (e == LV_EVENT_CLICKED))
printf("forward btn clicked\n\r");
lv_scr_load_anim(screen2, LV_SCR_LOAD_ANIM_MOVE_RIGHT, 500, 200, false);
// lv_scr_load(screen2);
else if ((obj == btn2) && (e == LV_EVENT_CLICKED))
printf("back btn clicked\n\r");
lv_scr_load_anim(screen1, LV_SCR_LOAD_ANIM_MOVE_RIGHT, 500, 200, false);
// lv_scr_load(screen1);
void button_demo_main_window_create(lv_obj_t * p)
(void)p;
LV_THEME_DEFAULT_INIT(lv_theme_get_color_primary(), lv_theme_get_color_secondary(),
LV_THEME_MATERIAL_FLAG_DARK,
lv_theme_get_font_small(), lv_theme_get_font_small(), lv_theme_get_font_normal(), lv_theme_get_font_normal());
_lv_obj_set_style_local_color(lv_scr_act(), LV_BTN_PART_MAIN, LV_STYLE_BG_COLOR, LV_COLOR_BLACK);
screen1 = lv_scr_act(); //lv_obj_create(NULL, NULL);
screen2 = lv_obj_create(NULL, NULL);
_lv_obj_set_style_local_color(screen1, LV_BTN_PART_MAIN, LV_STYLE_BG_COLOR, LV_COLOR_YELLOW);
_lv_obj_set_style_local_color(screen2, LV_BTN_PART_MAIN, LV_STYLE_BG_COLOR, LV_COLOR_BLUE);
// button_demo_main_window_create(lv_scr_act());
scr1_create();
scr2_create();
// lv_disp_set_default(screen1);
void scr1_create(void)
lv_obj_t* la;
btn1 = lv_btn_create(screen1, NULL);
lv_obj_align(btn1, screen1, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_event_cb(btn1, button_event_cb);
la = lv_label_create(btn1, NULL);
lv_label_set_text(la, "SCREEN2");
lv_obj_align(la, btn1, LV_ALIGN_CENTER, 0, 0);
void scr2_create(void)
lv_obj_t* la;
btn2 = lv_btn_create(screen2, NULL);
lv_obj_align(btn2, screen2, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_event_cb(btn2, button_event_cb);
la = lv_label_create(btn2, NULL);
lv_label_set_text(la, "SCREEN1");
lv_obj_align(la, btn2, LV_ALIGN_CENTER, 0, 0);
