Before posting
BES2700BP
v8.3
When the page scrolls to the top or bottom, it will stop after continuing to scroll a certain distance to prevent the content from scrolling out of the screen.
Analyze the implementation of the elastic_diff and scroll_limit_difffunction.
#define LV_HOR_RES_MAX 466
#define LV_VER_RES_MAX 466
void CreateControlMenu(lv_obj_t *parent)
auto m_menu_container = lv_obj_create(parent);
lv_obj_remove_style_all(m_menu_container);
lv_obj_set_size(m_menu_container, LV_HOR_RES_MAX, LV_HOR_RES_MAX);
lv_obj_set_scroll_snap_y(m_menu_container, LV_SCROLL_SNAP_CENTER);
lv_obj_set_flex_flow(m_menu_container, LV_FLEX_FLOW_COLUMN);
lv_obj_align(m_menu_container, LV_ALIGN_TOP_MID, 0, 12);
lv_obj_set_style_bg_opa(m_menu_container, LV_OPA_0, LV_PART_MAIN);
lv_obj_set_style_rotary_sensitivity(m_menu_container, 64, 0);
lv_obj_set_scroll_dir(m_menu_container, LV_DIR_VER);
lv_obj_align(m_menu_container, LV_ALIGN_TOP_MID, 0, 0);
for (int8_t i = 0; i < 10; ++i)
lv_obj_t *obj;
lv_obj_t *label;
/*Add items to the column*/
obj = lv_obj_create(m_menu_container);
lv_obj_set_size(obj, LV_PCT(100), 100);
lv_obj_set_style_bg_opa(obj, 255, LV_PART_MAIN);
lv_obj_set_style_bg_color(obj, lv_color_hex(0x3FBFF5), LV_PART_MAIN);
label = lv_label_create(obj);
lv_label_set_text_fmt(label, "Item: %" LV_PRIu32, i);
lv_obj_set_style_bg_opa(label, 255, LV_PART_MAIN);
lv_obj_set_style_bg_color(label, lv_color_hex(0x3FF07F), LV_PART_MAIN);
lv_obj_center(label);
void CreateControlView(lv_obj_t *parent)
auto m_control_container = lv_obj_create(parent);
lv_obj_set_size(m_control_container, LV_HOR_RES_MAX, LV_VER_RES_MAX);
lv_obj_align(m_control_container, LV_ALIGN_TOP_MID, 0, 0);
lv_obj_set_style_bg_opa(m_control_container, 0, 0);
lv_obj_set_style_bg_opa(m_control_container, LV_OPA_0, LV_PART_SCROLLBAR | LV_STATE_DEFAULT);
lv_obj_set_style_bg_opa(m_control_container, LV_OPA_0, LV_PART_SCROLLBAR | LV_STATE_SCROLLED);
lv_obj_clear_flag(m_control_container, LV_OBJ_FLAG_SCROLL_MOMENTUM);
lv_obj_clear_flag(m_control_container, LV_OBJ_FLAG_SCROLL_ELASTIC);
CreateControlMenu(m_control_container);
lv_obj_scroll_to_y(m_control_container, 0, LV_ANIM_OFF);
scrolling up
Stop scrolling when reaching approximately one-third down the screen to prevent scrolling off the screen.
