Program stops without error when running lv_timer_handler();
I am running a simple program, trying to upgrade from v7 to v8, but the program stops at lv_timer_handler().
Arduino environment, nRF52, ST7789. I have code running with v7 code but am trying to adapt it for v8, starting with a simple “hello world”.
A simple “hello world” test.
Tried variations of the old code and searched and read some other issues which seem to be related to the LV_HOR_RES_MAX.
void loop() {
  Serial.println("loop started...");
  Serial.println("post lv_timer_handler");
  delay( 5 );
Current code:
/*Change to your screen resolution*/
static const uint16_t screenWidth  = 240;
static const uint16_t screenHeight = 240;
//static lv_disp_draw_buf_t draw_buf;
static lv_color_t buf[ screenWidth * 10 ];
Previous code:
#define buffer_lcd_size LV_HOR_RES_MAX * 30
static lv_color_t buf[buffer_lcd_size];
Be sure that lv_disp_drv_t and lv_indev_drv_t are also static.
That did it. Thank you!
Hello! I hit the same issue as you. May I know where did you modify to fix this issue?
Me too in spades – it’s BAD! I’ve tried all sorts of thing … sometimes it’s fine and others not. Makes Zero sense!
HELP!! Please!
I think to have the same issue. Did someone know how to resolve it?
I’m trying to make working a lilygo t-display s3 using lvgl 8.2.
Even with a simple program after a variable amount of time the lvgl library freeze and the aamlv_timer_handle never escape.
I did try to increase stack and heap. I did simplify again the software. No luck.
I did spent some time trying to upgrade to lvgl 9, but I didn’t find no configuration that shows something good on the screen. So I’m stuck between a 8.2 version working but freezing and a 9.2 not working.
Any help will be appreciated.
