Before posting
I have a function which create for me a label “My_GUI__Label(…)”,
i pass every parameters of my requested label to it, but when user_data ckecked inside the function is correct but outside of function when accesse using
child = lv_obj_get_child(lv_scr_act(), i); user_strR = (char*)lv_obj_get_user_data(child);
the user_data of all objects or some of them THAT created with “My_GUI__Label(…)” goes wrong,
can somebody tell me how i write/access to “My_GUI__Label(…)”,
AND what is going wrong there?!?!
Visual Studio 2022 simulator
LVGL Ver: 8.3.0 dev
creating some LVGL object and write/read to USER DATA part from anywhere.
Tried many ways with any success.
* Label Creater
lv_obj_t* My_GUI__Label(char* _text, char* _id_strR, lv_obj_t* _parent,
lv_align_t _Align, uint16_t _X, uint16_t _Y,
int width, int height
lv_obj_t* label = lv_label_create(_parent);
lv_label_set_text(label, _text);
lv_obj_set_pos(label, 700, 100);
printf("\nMy_GUI__Label _id_strR String is: %s", _id_strR);
lv_obj_set_user_data(label, (char*) _id_strR);
return label;
* Test function to use Label Creater
void My_GUI_test_XX(void)
int int_desX = 700;
int int_desY = 50;
int int_width = 20;
int int_height = 50;
char text_strR[] = "My_GUI_test";
char append_STR[] = "My_GUI_test DATA0000000";
char append_STR1[] = "My_GUI_test DATA1111111";
char append_STR2[] = "My_GUI_test DATA2222222";
char append_STR3[] = "My_GUI_test DATA3333333";
lv_obj_t* lbl1 = My_GUI__Label(text_strR, append_STR, lv_scr_act(),
NULL, int_desX, int_desY //NULL set position 20,20
// LV_ALIGN_CENTER, 150, -40 //center align
, int_width, int_height
lbl1 = My_GUI__Label(text_strR, append_STR1, lv_scr_act(),
NULL, int_desX + 50, int_desY + 50 //NULL set position 20,20
lbl1 = My_GUI__Label(text_strR, append_STR2, lv_scr_act(),
lbl1 = My_GUI__Label(text_strR, append_STR3, lv_scr_act(),
lv_obj_t* label = lv_label_create(lv_scr_act());
lv_label_set_text(label, "My_GUI_test_TRADITIONAL");
lv_obj_set_user_data(label, (void*)"User_Data_My_GUI_test_TRADITIONAL");
//append_STR = (char*)lv_obj_get_user_data(label);
//printf("\n++Direct Read______USER data is: %s", append_STR);
* sample Traditional labels
void Traditional_testGUI(void)
lv_obj_t* button;
lv_obj_t* label;
char* got_user_data = NULL;;
const char* text_strR = NULL;
lv_label_set_text(label, "label0");
lv_obj_set_pos(label, 10, 100);
lv_obj_set_user_data(label, (void*)"TRADITIONAL Data_0");
got_user_data = (char*)lv_obj_get_user_data(label);
printf("\n\n\n\tTraditional_testGUI______USER data is: %s", got_user_data);
label = lv_obj_create(lv_scr_act());
//lv_label_set_text(label, "object0");
lv_obj_set_pos(label, 10, 300);
lv_obj_set_user_data(label, (void*)"TRADITIONAL Data_1");
printf("\n\tTraditional_testGUI______USER data is: %s", got_user_data);//------------------------
lv_label_set_text(label, "label1");
lv_obj_set_pos(label, 100, 100);
lv_obj_set_user_data(label, (void*)"TRADITIONAL Data_2");
lv_label_set_text(label, "label2");
lv_obj_set_pos(label, 180, 100);
lv_obj_set_user_data(label, (void*)"TRADITIONAL Data_3");
printf("\n\n");
int main()
printf("\n\n----------------------------------");
printf("\n*** LVGL Ver: %i.%i.%i %s ***", LVGL_VERSION_MAJOR, LVGL_VERSION_MINOR, LVGL_VERSION_PATCH, LVGL_VERSION_INFO);
printf("\n----------------------------------\n\n");
Traditional_testGUI();
char* user_strR = NULL;
printf("\n\n\n----------------- child = lv_obj_get_child(lv_scr_act(), i) -----------------");
lv_obj_t* child;
for (int i = 0; i < lv_obj_get_child_cnt(lv_scr_act()); i++) {
if (user_strR != NULL)
printf("\n++Child find USER data is i: %i %s", i, user_strR);
Another try
