I tried creating a driver library for 3.5inch 480x320 display ST7796 with RP2040. Before building the LVGL firmware, I changed the value of LV_COLOR_DEPTH to 16 in lib\lv_bindings. I am getting this error
File "<stdin>", line 6, in <module>
File "ili9xxx.py", line 323, in __init__
File "ili9xxx.py", line 311, in __init__
MemoryError: memory allocation failed, allocating 536923960 bytes
main.py
import lvgl as lv
import ili9xxx
from machine import SPI, Pin
spi = SPI(1, baudrate=27000000, sck=Pin(10), mosi=Pin(11), miso=Pin(8))
drv = ili9xxx.St7796(spi=spi, dc=23, cs=29, rst=28)
scr = lv.obj()
btn = lv.btn(scr)
btn.set_style_bg_color(lv.color_hex(0xFF0000), lv.PART.MAIN | lv.STATE.DEFAULT)
scr.set_style_bg_color(lv.color_hex(0x000000), lv.PART.MAIN | lv.STATE.DEFAULT)
label = lv.label(btn)
label.set_text("Hello World!")
btn.set_style_width(120, lv.PART.MAIN | lv.STATE.DEFAULT)
btn.set_style_height(35, lv.PART.MAIN | lv.STATE.DEFAULT)
bh = 18
bw = 60
by = 160 - bh
bx = 240 - bw
btn.set_x(bx)
btn.set_y(by)
lv.scr_load(scr)
ili9xxx.py
from micropython import const
import lvgl as lv
import machine
import time
import struct
_MADCTL = const(0x36)
_MADCTL_BGR = const(0x08) # colors are BGR (not RGB)
_MADCTL_RTL = const(0x04) # refresh right to left
MADCTL_MH = const(0x04) # Refresh 0=Left to Right, 1=Right to Left
MADCTL_ML = const(0x10) # Refresh 0=Top to Bottom, 1=Bottom to Top
MADCTL_MV = const(0x20) # 0=Normal, 1=Row/column exchange
MADCTL_MX = const(0x40) # 0=Left to Right, 1=Right to Left
MADCTL_MY = const(0x80) # 0=Top to Bottom, 1=Bottom to Top
ORIENTATION_TABLE = (MADCTL_MX, MADCTL_MV, MADCTL_MY, MADCTL_MY | MADCTL_MX | MADCTL_MV)
ST7796_PORTRAIT = const(0)
ST7796_LANDSCAPE = const(1)
ST7796_INV_PORTRAIT = const(2)
ST7796_INV_LANDSCAPE = const(3)
DISPLAY_TYPE_ST7789 = const(4)
DISPLAY_TYPE_ILI9488 = const(2)
COLOR_MODE_RGB = const(0x00)
class St77xx_hw(object):
def __init__(self, *, cs, dc, spi, res, suppRes, bl=None, model=None, suppModel=[], rst=None, rot=ST7796_LANDSCAPE, bgr=False, rp2_dma=None):
self.buf1 = bytearray(1)
self.buf2 = bytearray(2)
self.buf4 = bytearray(4)
self.cs,self.dc,self.rst=[(machine.Pin(p,machine.Pin.OUT) if isinstance(p,int) else p) for p in (cs,dc,rst)]
self.bl=bl
if isinstance(self.bl,int): self.bl=machine.PWM(machine.Pin(self.bl,machine.Pin.OUT))
elif isinstance(self.bl,machine.Pin): self.bl=machine.PWM(self.bl)
assert isinstance(self.bl,(machine.PWM,type(None)))
self.set_backlight(10) # set some backlight
self.rot=rot
self.bgr=bgr
self.width,self.height=(0,0) # this is set later in hard_reset->config->apply_rotation
if res not in suppRes: raise ValueError('Unsupported resolution %s; the driver supports: %s.'%(str(res),', '.join(str(r) for r in suppRes)))
if suppModel and model not in suppModel: raise ValueError('Unsupported model %s; the driver supports: %s.'%(str(model),', '.join(str(r) for r in suppModel)))
self.res=res
self.model=model
self.rp2_dma=rp2_dma
self.spi=spi
self.hard_reset()
def off(self): self.set_backlight(0)
def hard_reset(self):
if self.rst:
for v in (1,0,1):
self.rst.value(v)
time.sleep(.2)
time.sleep(.2)
self.config()
def config(self):
self.config_hw() # defined in child classes
self.apply_rotation(self.rot)
def set_backlight(self,percent):
if self.bl is None: return
self.bl.duty_u16(percent*655)
def set_window(self, x, y, w, h):
c0,r0=ST77XX_COL_ROW_MODEL_START_ROTMAP[self.res[0],self.res[1],self.model][self.rot%4]
struct.pack_into('>hh', self.buf4, 0, c0+x, c0+x+w-1)
self.write_register(ST77XX_CASET, self.buf4)
struct.pack_into('>hh', self.buf4, 0, r0+y, r0+y+h-1)
self.write_register(ST77XX_RASET, self.buf4)
def apply_rotation(self,rot):
self.rot=rot
if (self.rot%2)==0: self.width,self.height=self.res
else: self.height,self.width=self.res
self.write_register(ST77XX_MADCTL,bytes([(ST77XX_MADCTL_BGR if self.bgr else 0)|ST77XX_MADCTL_ROTS[self.rot%4]]))
def blit(self, x, y, w, h, buf, is_blocking=True):
self.set_window(x, y, w, h)
if self.rp2_dma: self._rp2_write_register_dma(ST77XX_RAMWR, buf, is_blocking)
else: self.write_register(ST77XX_RAMWR, buf)
def clear(self, color):
bs=128 # write pixels in chunks; makes the fill much faster
struct.pack_into('>h',self.buf2,0,color)
buf=bs*bytes(self.buf2)
npx=self.width*self.height
self.set_window(0, 0, self.width, self.height)
self.write_register(ST77XX_RAMWR, None)
self.cs.value(0)
self.dc.value(1)
for _ in range(npx//bs): self.spi.write(buf)
for _ in range(npx%bs): self.spi.write(self.buf2)
self.cs.value(1)
def write_register(self, reg, buf=None):
struct.pack_into('B', self.buf1, 0, reg)
self.cs.value(0)
self.dc.value(0)
self.spi.write(self.buf1)
if buf is not None:
self.dc.value(1)
self.spi.write(buf)
self.cs.value(1)
def _rp2_write_register_dma(self, reg, buf, is_blocking=True):
'If *is_blocking* is False, used should call wait_dma explicitly.'
SPI1_BASE = 0x40040000 # FIXME: will be different for another SPI bus?
SSPDR = 0x008
self.rp2_dma.config(
src_addr = uctypes.addressof(buf),
dst_addr = SPI1_BASE + SSPDR,
count = len(buf),
src_inc = True,
dst_inc = False,
trig_dreq= self.rp2_dma.DREQ_SPI1_TX
struct.pack_into('B',self.buf1,0,reg)
self.cs.value(0)
self.dc.value(0)
self.dc.value(1)
self.rp2_dma.enable()
if is_blocking: self.rp2_wait_dma()
def rp2_wait_dma(self):
Wait for rp2-port DMA transfer to finish; no-op unless self.rp2_dma is defined.
Can be used as callback before accessing shared SPI bus e.g. with the xpt2046 driver.
if self.rp2_dma is None: return
while self.rp2_dma.is_busy(): pass
self.rp2_dma.disable()
# wait to send last byte. It should take < 1uS @ 10MHz
time.sleep_us(1)
self.cs.value(1)
def _run_seq(self,seq):
Run sequence of (initialization) commands; those are given as list of tuples, which are either
`(command,data)` or `(command,data,delay_ms)`
for i,cmd in enumerate(seq):
if len(cmd)==2: (reg,data),delay=cmd,0
elif len(cmd)==3: reg,data,delay=cmd
else: raise ValueError('Command #%d has %d items (must be 2 or 3)'%(i,len(cmd)))
self.write_register(reg,data)
if delay>0: time.sleep_ms(delay)
def madctl(self, colormode, rotation, rotations):
if rotation >= 0:
return rotation | colormode
index = abs(rotation) - 1
if index > len(rotations):
RuntimeError('Invalid display rot value specified during init.')
return rotations[index] | colormode
class St7796_hw(St77xx_hw):
def __init__(self, **kw):
"""ST7796 TFT Display Driver.
Requires ``LV_COLOR_DEPTH=16`` when building lv_micropython to function.
super().__init__(
res=(480, 320),
suppRes=[
(480, 320),
model=None,
suppModel=None,
bgr=False,
**kw,
def display_config(self):
if lv.color_t.__SIZE__ == 4:
display_type = DISPLAY_TYPE_ILI9488
pixel_format = 0x06 # 262K-Colors
elif lv.color_t.__SIZE__ == 2:
pixel_format = 0x05 # 65K-Colors 55??
display_type = DISPLAY_TYPE_ST7789
else:
raise RuntimeError('ST7796 micropython driver requires defining LV_COLOR_DEPTH=32 or LV_COLOR_DEPTH=16')
return pixel_format
def config_hw(self):
self._run_seq(
(0x01,None, 120),
(0x11, None, 120),
(0xF0,b"\xc3"),
(0xF0,b"\x96"),
(0x36,bytes([self.madctl(COLOR_MODE_RGB, ST7796_LANDSCAPE, ORIENTATION_TABLE)])),
#(0X36,b"\x0"),
(0x3A,bytes([self.display_config()])),
(0xB4,b"\x01"),
(0xB6,b"\x80\x02\x3B"),
(0xE8,b"\x40\x8A\x00\x00\x29\x19\xA5\x33"),
(0xC1,b"\x06"),
(0xC2,b"\xA7"),
(0xC5,b"\x18", 120),
(0xE0,b"\xF0\x09\x0B\x06\x04\x15\x2F\x54\x42\x3C\x17\x14\x18\x1B"),
(0xE1,b"\xE0\x09\x0B\x06\x04\x03\x2B\x43\x42\x3B\x16\x14\x17\x1B", 120),
(0xF0,b"\x3C"),
(0xF0,b"\x69",120),
(0x29,b""),
def apply_rotation(self, rot):
self.rot = rot
if (self.rot % 2) == 0:
self.width, self.height = self.res
else:
self.height, self.width = self.res
self.write_register(_MADCTL,bytes([_MADCTL_BGR | ORIENTATION_TABLE[self.rot % 4]]),)
# if rotation is 0 or positive use the value as is.
if rotation >= 0:
# otherwise use abs(rotation)-1 as index to retreive value from rotations set
class St77xx_lvgl(object):
'''LVGL wrapper for St77xx, not to be instantiated directly.
* creates and registers LVGL display driver;
* allocates buffers (double-buffered by default);
* sets the driver callback to the disp_drv_flush_cb method.
def disp_drv_flush_cb(self,disp_drv,area,color):
# print(f"({area.x1},{area.y1}..{area.x2},{area.y2})")
self.rp2_wait_dma() # wait if not yet done and DMA is being used
# blit in background
self.blit(area.x1,area.y1,w:=(area.x2-area.x1+1),h:=(area.y2-area.y1+1),color.__dereference__(2*w*h),is_blocking=False)
self.disp_drv.flush_ready()
def __init__(self,doublebuffer=True,factor=4):
import lvgl as lv
import lv_utils
if lv.COLOR_DEPTH!=16: raise RuntimeError(f'LVGL *must* be compiled with LV_COLOR_DEPTH=16 (currently LV_COLOR_DEPTH={lv.COLOR_DEPTH}.')
bufSize=(self.width*self.height*lv.color_t.__SIZE__)//factor
if not lv.is_initialized(): lv.init()
# create event loop if not yet present
if not lv_utils.event_loop.is_running(): self.event_loop=lv_utils.event_loop()
# attach all to self to avoid objects' refcount dropping to zero when the scope is exited
self.disp_drv = lv.disp_create(self.width, self.height) //line 311
self.disp_drv.set_flush_cb(self.disp_drv_flush_cb)
self.disp_drv.set_draw_buffers(bytearray(bufSize), bytearray(bufSize) if doublebuffer else None, bufSize, lv.DISP_RENDER_MODE.PARTIAL)
self.disp_drv.set_color_format(lv.COLOR_FORMAT.NATIVE if self.bgr else lv.COLOR_FORMAT.NATIVE_REVERSED)
class St7796(St7796_hw, St77xx_lvgl):
def __init__(self, doublebuffer=True, factor=4, **kw):
"""See :obj:`Ili9341_hw` for the meaning of the parameters."""
import lvgl as lv
St7796_hw.__init__(self, **kw)
St77xx_lvgl.__init__(self, doublebuffer, factor)
@ kdschlosser can you have a look at this code. I used the library from this issue
