import espidf as esp
import lvgl as lv
import ili9XXX
class st7796(ili9XXX.ili9XXX):
# The st7795 display controller has an internal framebuffer
# arranged in 320 x 480
# configuration. Physical displays with pixel sizes less than
# 320 x 480 must supply a start_x and
# start_y argument to indicate where the physical display begins
# relative to the start of the
# display controllers internal framebuffer.
# this display driver supports RGB565 and also RGB666. RGB666 is going to
# use twice as much memory as the RGB565. It is also going to slow down the
# frame rate by 1/3, This is becasue of the extra byte of data that needs
# to get sent. To use RGB666 the color depth MUST be set to 32.
# so when compiling
# make sure to have LV_COLOR_DEPTH=32 set in LVFLAGS when you call make.
# For RGB565 you need to have LV_COLOR_DEPTH=16
# the reason why we use a 32 bit color depth is because of how the data gets
# written. The entire 8 bits for each byte gets sent. The controller simply
# ignores the lowest 2 bits in the byte to make it a 6 bit color channel
# We just have to tell lvgl that we want to use
def __init__(
self,
miso=-1,
mosi=19,
clk=18,
cs=13,
dc=12,
rst=4,
power=-1,
backlight=15,
backlight_on=1,
power_on=0,
spihost=esp.HSPI_HOST,
spimode=0,
mhz=80,
hybrid=True,
width=320,
height=480,
start_x=0,
start_y=0,
colormode=ili9XXX.COLOR_MODE_RGB,
rot=ili9XXX.LANDSCAPE,
invert=False,
double_buffer=False,
half_duplex=True,
asynchronous=False,
initialize=True,
color_format=lv.COLOR_FORMAT.NATIVE
if lv.color_t.__SIZE__ == 4:
display_type = ili9XXX.DISPLAY_TYPE_ILI9488
pixel_format = 0x06 # 262K-Colors
elif lv.color_t.__SIZE__ == 2:
pixel_format = 0x05 # 65K-Colors 55??
display_type = ili9XXX.DISPLAY_TYPE_ST7789
else:
raise RuntimeError(
'ST7796 micropython driver '
'requires defining LV_COLOR_DEPTH=32 or LV_COLOR_DEPTH=16'
self.display_name = 'ST7796'
self.init_cmds = [
{'cmd': 0x01, 'delay':120}, # SWRESET
{'cmd': 0x11, 'delay':120}, # SLPOUT
{'cmd': 0xF0, 'data': bytes([0xC3])}, # CSCON Enable extension command 2 partI
{'cmd': 0xF0, 'data': bytes([0x96])}, # CSCON Enable extension command 2 partII
{'cmd': 0x36, 'data': bytes([self.madctl(colormode, rot, ili9XXX.ORIENTATION_TABLE)])}, # MADCTL
# Interface_Pixel_Format
{'cmd': 0x3A, 'data': bytes([pixel_format])},
{'cmd': 0xB4, 'data': bytes([0x01])}, # INVTR 1-dot inversion
{'cmd': 0xB6, 'data': bytes([
0x80, # Bypass
0x02, # Source Output Scan from S1 to S960, Gate Output scan from G1 to G480, scan cycle=2
0x3B # LCD Drive Line=8*(59+1)
])}, # DFC
{'cmd': 0xE8, 'data': bytes([
0x40,
0x8A,
0x00,
0x00,
0x29, # Source eqaulizing period time= 22.5 us
0x19, # Timing for "Gate start"=25 (Tclk)
0xA5, # Timing for "Gate End"=37 (Tclk), Gate driver EQ function ON
0x33
])}, # DOCA
{'cmd': 0xC1, 'data': bytes([0x06])}, # PWR2 VAP(GVDD)=3.85+( vcom+vcom offset), VAN(GVCL)=-3.85+( vcom+vcom offset)
{'cmd': 0xC2, 'data': bytes([0xA7])}, # PWR3 Source driving current level=low, Gamma driving current level=High
{'cmd': 0xC5, 'data': bytes([0x18]), 'delay':120}, # VCMPCTL VCOM=0.9
{'cmd': 0xE0, 'data': bytes([
0xF0, 0x09, 0x0b, 0x06, 0x04, 0x15, 0x2F,
0x54, 0x42, 0x3C, 0x17, 0x14, 0x18, 0x1B
])}, # PGC
{'cmd': 0xE1, 'data': bytes([
0xE0, 0x09, 0x0B, 0x06, 0x04, 0x03, 0x2B,
0x43, 0x42, 0x3B, 0x16, 0x14, 0x17, 0x1B
]), 'delay':120}, # NGC
{'cmd': 0xF0, 'data': bytes([0x3C])}, # CSCON Disable extension command 2 partI
{'cmd': 0xF0, 'data': bytes([0x69]), 'delay':120}, # CSCON Disable extension command 2 partII
{'cmd': 0x29} # DISPON
super().__init__(
miso=miso,
mosi=mosi,
clk=clk,
cs=cs,
dc=dc,
rst=rst,
power=power,
backlight=backlight,
backlight_on=backlight_on,
power_on=power_on,
spihost=spihost,
spimode=spimode,
mhz=mhz,
hybrid=hybrid,
width=width,
height=height,
start_x=start_x,
start_y=start_y,
invert=invert,
double_buffer=double_buffer,
half_duplex=half_duplex,
display_type=display_type,
asynchronous=asynchronous,
initialize=initialize,
color_format=color_format
# #define PIN_SDA 18
# #define PIN_SCL 19
# #define TFT_MISO 12
# #define TFT_MOSI 13
# #define TFT_SCLK 14
# #define TFT_CS 15
# #define TFT_DC 21
# #define TFT_RST 22
# #define TFT_BL 23
LED = 23
RESET = 22
MOSI = 13
CS = 15
DC_RS = 21
SCK = 14
MISO = 12
# init display
disp = st7796(
miso=MISO,
mosi=MOSI,
clk=SCK,
cs=CS,
dc=DC_RS,
rst=RESET,
backlight=LED,
power=-1,
width=480,
height=320,
# screen = Screen()
# ui.Main(screen)
# lv.scr_load(screen)
scr = lv.obj()
btn = lv.btn(scr)
btn.set_style_bg_color(lv.color_hex(0xFF0000), lv.PART.MAIN | lv.STATE.DEFAULT)
scr.set_style_bg_color(lv.color_hex(0x000000), lv.PART.MAIN | lv.STATE.DEFAULT)
label = lv.label(btn)
label.set_text("Hello World!")
btn.set_style_width(120, lv.PART.MAIN | lv.STATE.DEFAULT)
btn.set_style_height(35, lv.PART.MAIN | lv.STATE.DEFAULT)
bh = 18
bw = 60
by = 160 - bh
bx = 240 - bw
btn.set_x(bx)
btn.set_y(by)
# Load the screen
lv.scr_load(scr)
You have to flip flop the width and height if you use portrait.
