Before posting
visual studio 2017
v7
how to overcome roller events influence each other
Change the roller style and some other property
/******************************roller_test.h*******************/
#pragma once
#ifndef ROLLER_TEST_H
#define ROLLER_TEST_H
#include "lvgl/lvgl.h"
#ifdef __cplusplus
extern "C" {
#endif // __cplusplus
void SetupScreen(lv_obj_t *obj);
#ifdef __cplusplus
#endif // ! UI_MORE_TIMER_H
/******************************roller_test.c*******************/
#include "roller_test.h"
static lv_obj_t *tabview = NULL;
static lv_obj_t *tab1 = NULL;
static lv_style_t rollerBgStyle, rollerSelStyle;
static char hourStrBuf[3] = { 0 };
static char minuteStrBuf[3] = { 0 };
static char secondStrBuf[3] = { 0 };
static lv_obj_t *hourRoller = NULL;
static lv_obj_t *minuteRoller = NULL;
static lv_obj_t *secondRoller = NULL;
static uint32_t timerTmp = 60;
static const char *HourBuf = "00\n01\n02\n03\n04\n05\n06\n07\n08\n09\n10\n11\n12\n13\n14\n15\n16\n17\n18\n19\n20\n21\n22\n23";
static const char *MinuteBuf = "00\n01\n02\n03\n04\n05\n06\n07\n08\n09\n10\n11\n12\n13\n14\n15\n16\n17\n18\n19\n20\n21\n22\n23\n24\n25\n26\n27\n28\n29"
"\n30\n31\n32\n33\n34\n35\n36\n37\n38\n39\n40\n41\n42\n43\n44\n45\n46\n47\n48\n49\n50\n51\n52\n53\n54\n55\n56\n57\n58\n59";
static const char *SecondBuf = "00\n01\n02\n03\n04\n05\n06\n07\n08\n09\n10\n11\n12\n13\n14\n15\n16\n17\n18\n19\n20\n21\n22\n23\n24\n25\n26\n27\n28\n29"
static void InitTableview(lv_obj_t *obj)
static lv_style_t bgStyle;
static lv_style_t scrlStyle;
tabview = lv_tabview_create(obj, NULL);
lv_obj_set_size(tabview, LV_HOR_RES, LV_VER_RES);
lv_obj_add_style(tabview, LV_OBJ_PART_MAIN, &bgStyle);
lv_tabview_set_btns_pos(tabview, LV_TABVIEW_TAB_POS_NONE);
lv_obj_align(tabview, NULL, LV_ALIGN_IN_TOP_LEFT, 0, 0);
tab1 = lv_tabview_add_tab(tabview, "Tab1");
lv_page_set_scrlbar_mode(tab1, LV_SCRLBAR_MODE_OFF);
lv_obj_add_style(tab1, LV_PAGE_PART_SCROLLABLE, &scrlStyle);
lv_tabview_set_tab_act(tabview, 1, LV_ANIM_OFF);
static void RollerSetting(lv_obj_t *roller, const char *opt, lv_coord_t xpos, uint16_t index, lv_event_cb_t event)
roller = lv_roller_create(tab1, NULL);
lv_roller_set_options(roller, opt, LV_ROLLER_MODE_INIFINITE);
lv_obj_set_size(roller, 36, 150);
lv_obj_add_style(roller, LV_ROLLER_PART_BG, &rollerBgStyle);
lv_obj_add_style(roller, LV_ROLLER_PART_SELECTED, &rollerSelStyle);
lv_roller_set_auto_fit(roller, false);
lv_roller_set_visible_row_count(roller, 3);
lv_roller_set_selected(roller, index, LV_ANIM_OFF);
if (&event == NULL) {
lv_obj_set_event_cb(roller, event);
lv_obj_align(roller, NULL, LV_ALIGN_IN_TOP_LEFT, xpos, 40);
static void TimerHourRollerEventHandler(lv_obj_t *obj, lv_event_t event)
if (event == LV_EVENT_VALUE_CHANGED) {
memset(hourStrBuf, 0, sizeof(hourStrBuf));
lv_roller_get_selected_str(obj, hourStrBuf, sizeof(hourStrBuf));
static void TimerMinuteRollerEventHandler(lv_obj_t *obj, lv_event_t event)
memset(minuteStrBuf, 0, sizeof(minuteStrBuf));
lv_roller_get_selected_str(obj, minuteStrBuf, sizeof(minuteStrBuf));
static void TimerSecondRollerEventHandler(lv_obj_t *obj, lv_event_t event)
memset(secondStrBuf, 0, sizeof(secondStrBuf));
lv_roller_get_selected_str(obj, secondStrBuf, sizeof(secondStrBuf));
static void SettingTimerUI(void)
uint16_t hourIndex = timerTmp / 3600 + 2;
if (hourRoller == NULL) {
RollerSetting(hourRoller, HourBuf, 30, hourIndex, TimerHourRollerEventHandler);
uint16_t minuteIndex = timerTmp % 3600 / 60 + 5;
if (minuteRoller == NULL) {
RollerSetting(minuteRoller, MinuteBuf, 133, minuteIndex, TimerMinuteRollerEventHandler);
uint16_t secondIndex = timerTmp % 60 + 5;
if (secondRoller == NULL) {
RollerSetting(secondRoller, SecondBuf, 234, secondIndex, TimerSecondRollerEventHandler);
static void InitRollerStyle(void)
lv_style_reset(&rollerBgStyle);
lv_style_init(&rollerBgStyle);
lv_style_set_bg_color(&rollerBgStyle, LV_STATE_DEFAULT, LV_COLOR_BLACK);
lv_style_set_bg_grad_color(&rollerBgStyle, LV_STATE_DEFAULT, LV_COLOR_BLACK);
lv_style_set_bg_opa(&rollerBgStyle, LV_STATE_DEFAULT, LV_OPA_100);
lv_style_set_radius(&rollerBgStyle, LV_STATE_DEFAULT, 0);
lv_style_set_border_width(&rollerBgStyle, LV_STATE_DEFAULT, 0);
lv_style_set_text_opa(&rollerBgStyle, LV_STATE_DEFAULT, LV_OPA_100);
lv_style_set_text_line_space(&rollerBgStyle, LV_STATE_DEFAULT, 32);
lv_style_set_text_color(&rollerBgStyle, LV_STATE_DEFAULT, LV_COLOR_GRAY);
lv_style_reset(&rollerSelStyle);
lv_style_init(&rollerSelStyle);
lv_style_set_bg_color(&rollerSelStyle, LV_STATE_DEFAULT, LV_COLOR_BLACK);
lv_style_set_bg_grad_color(&rollerSelStyle, LV_STATE_DEFAULT, LV_COLOR_BLACK);
lv_style_set_text_color(&rollerSelStyle, LV_STATE_DEFAULT, LV_COLOR_MAKE(0x00, 0xd8, 0xff));
InitTableview(obj);
InitRollerStyle();
SettingTimerUI();
## Screenshot and/or video
I build three roller and each of them has an event,but
when I rolling one of them with no stop exactly on an option and at this time rolling another,the previous even move.
