MIPI-DSI support on Renesas RA8Dx
Before posting
  • Read the
Does LVGL support MIPI-DSI interface on Renesas RA8D1, RA8D2 devices ?
There is no mention of MIPI on Built-in Drivers of Renesas:
https://docs.lvgl.io/master/integration/chip_vendors/renesas/built_in_drivers.html
And also I cannot see any handling of MIPI in the LVGL port (v.9.3) on FSP (v6.4) looking at the RM_LVGL_PORT_Open function.
@AZ_Renesas, Yes, support RA8D1/D2/P1. Please, check website: Supported Boards — LVGL
Hi @halyssonJr ,
My question was for MIPI-DSI interface specifically. The example projects are using the Parallel RGB interface with GLCDC support. Is there anything with MIPI-DSI ?
Hey,
LVGL doesn’t have a builtin driver for Renesas MIPI Interface.
In the latest FSPs LVGL is a manged component, and the Renesas-LVGL glue code is also generated by FSP, not using any built-in LVGL driver.
So it’s and FSP question wether LVGL supports MIPI directly. Unfortunately I don’t have a MIPI development board to test it right now, but we can check if the generated code looks sane.
Thanks @kisvegabor
