LVGL screen updating issue
Before posting
I’m using LVGL for my project. When I’m flashing the code to the default address location, it works fine. However, if I’m flashing to another boot location using the CAN bootloader, I face issues like screen lagging (updates are slower). Is there any specific reason for this? Am I missing any settings here?
NXP MIMXRT 1176
8.3
Smoother execution in screen
Does the other address belong to a different physical memory?
@kisvegabor
Thanks for the fast reply
Its same physical memory with default address location (0x30000000) and other boot location (0x30025000)
It must be something NXP specific. Probably the memory access time is different in these regions. Or one is not cache-able.
@kisvegabor
Thank you
The issue was resolved. It was a NOR flash speed issue.
