Before posting
MCU - MIMX RT1176
8.3
We are receiving image hex data from UART and want to display images faster (like 3 images per second) without hanging or delay during runtime.
- Copying received data to the image descriptor variable .data
lv_img_dsc_t img_des_;
memcpy((uint8_t *)img_des_.data, rcvdImgData, sizeof(rcvdImgData));
2 Tried lv_img_cache_invalidate_src(&img_des_);
3, Enabled
#define LV_MEM_CUSTOM 1
- #define LV_IMG_CACHE_DEF_SIZE 4
void setup_scr_screen(lv_ui *ui)
//Write codes screen
ui->screen = lv_obj_create(NULL);
lv_obj_set_size(ui->screen, 800, 480);
lv_obj_set_scrollbar_mode(ui->screen, LV_SCROLLBAR_MODE_OFF);
//Write style for screen, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
lv_obj_set_style_bg_opa(ui->screen, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
lv_obj_set_style_bg_color(ui->screen, lv_color_hex(0xffffff), LV_PART_MAIN|LV_STATE_DEFAULT);
//LV_USE_PNG
lv_png_init();
arr = malloc(640*480*4);
if(arr == NULL)
while(1)
img_des_.header.cf = LV_IMG_CF_TRUE_COLOR_ALPHA;
img_des_.header.always_zero = 0;
img_des_.header.reserved = 0;
img_des_.header.w = 640;
img_des_.header.h = 480;
img_des_.data_size = 640*480*4;
img_des_.data = arr;
//Update current screen layout.
lv_obj_update_layout(ui->screen);
uint8_t screen_flag;
void change_screen(lv_ui *ui)
if(update) //when image data is received completely Set update flag =1
memcpy((uint8_t *)img_des_.data, rcvdImgData, sizeof(rcvdImgData)); //rcvdImgData = Recieved data from UART
ui->screen_img_1 = lv_img_create(ui->screen);
lv_obj_add_flag(ui->screen_img_1, LV_OBJ_FLAG_CLICKABLE);
lv_img_set_src(ui->screen_img_1, &img_des_);
lv_img_set_pivot(ui->screen_img_1, 50,50);
lv_img_set_angle(ui->screen_img_1, 0);
lv_obj_set_pos(ui->screen_img_1, 0, 0);
lv_obj_set_size(ui->screen_img_1, img_des_.header.w, img_des_.header.h);
lv_obj_set_scrollbar_mode(ui->screen_img_1, LV_SCROLLBAR_MODE_OFF);
//Write style for screen_img_1, Part: LV_PART_MAIN, State: LV_STATE_DEFAULT.
lv_obj_set_style_img_opa(ui->screen_img_1, 0, LV_PART_MAIN|LV_STATE_DEFAULT);
// Invalidate the cache of the image source
lv_obj_center(ui->screen_img_1);
lv_obj_set_style_img_opa(ui->screen_img_1, 255, LV_PART_MAIN|LV_STATE_DEFAULT);
update = 0;
recvFlag = 1;
SCB_EnableDCache(); //Disabled before recieving data from UART , Enable after image update
SCB_EnableICache();
if(screen_flag)
Thanks
Akhil
