Before posting
I set LV SW to LV_RADIUS_CIRCLE,But when the control state switches, the left side is not rounded, the programming square, why is this?
stm32F767
lvgl 6
lv_style_copy(&sw_bg_style, &lv_style_plain_color);
sw_bg_style.body.main_color = LV_COLOR_MAKE(0xCC, 0xCC, 0xCC);
sw_bg_style.body.grad_color = LV_COLOR_MAKE(0xCC, 0xCC, 0xCC);
sw_bg_style.body.radius = LV_RADIUS_CIRCLE;
sw_bg_style.body.padding.left = 4;
sw_bg_style.body.padding.right = 4;
sw_bg_style.body.padding.top = 4;
sw_bg_style.body.padding.bottom = 4;
lv_style_copy(&sw_indic_style, &lv_style_plain_color);
sw_indic_style.body.main_color = LV_COLOR_MAKE(0x65, 0xC4, 0x66);
sw_indic_style.body.grad_color = LV_COLOR_MAKE(0x65, 0xC4, 0x66);
sw_indic_style.body.radius = LV_RADIUS_CIRCLE;
sw_indic_style.body.padding.left = 0;
sw_indic_style.body.padding.top = 0;
sw_indic_style.body.padding.right = 0;
sw_indic_style.body.padding.bottom = 0;
//1.3 创建关闭状态时,旋钮的样式
lv_style_copy(&sw_knob_off_style, &lv_style_plain_color);
sw_knob_off_style.body.main_color = LV_COLOR_WHITE;
sw_knob_off_style.body.grad_color = LV_COLOR_WHITE;
sw_knob_off_style.body.radius = LV_RADIUS_CIRCLE;
sw_knob_off_style.body.shadow.color = LV_COLOR_MAKE(0xA0, 0xA0, 0xA0);
sw_knob_off_style.body.shadow.width = 0;
sw_knob_off_style.body.shadow.type = LV_SHADOW_BOTTOM;
sw1 = lv_sw_create(setpage, NULL);
lv_obj_set_size(sw1, 100, 50);
lv_obj_align(sw1, label1, LV_ALIGN_OUT_RIGHT_TOP, 300, 0);
lv_sw_off(sw1, LV_ANIM_ON);
lv_sw_set_style(sw1, LV_SW_STYLE_BG, &sw_bg_style);
lv_sw_set_style(sw1, LV_SW_STYLE_INDIC, &sw_indic_style);
lv_sw_set_style(sw1, LV_SW_STYLE_KNOB_OFF, &sw_knob_off_style);
lv_sw_set_style(sw1, LV_SW_STYLE_KNOB_ON, &sw_knob_off_style);
Look, When I change the state, the left-hand side is obviously not circular
