Before posting
I run lv_keyboard but when I click the keyboard it doesn’t print anything on the textarea . Can anyone tell me why???
LVGL simulator (Visual Studio)
7.9.1
Print a character when I click the keyboard.
#include "../../../lv_examples.h"
#include <stdio.h>
#define LV_IMG_DECLARE(var_name) extern const lv_img_dsc_t var_name;
static void kb_create(void);
static void ta_event_cb(lv_obj_t* ta, lv_event_t event);
static void signal_speed_create(void);
static const char* btn_map[] = { "Back", "Home", "Menu","" };
static lv_obj_t* kb;
static lv_obj_t* ta;
void lv_test_btnmatrix()
lv_obj_t* btnm1 = lv_btnmatrix_create(lv_scr_act(), NULL);
lv_btnmatrix_set_map(btnm1, btn_map);
lv_obj_align(btnm1, NULL, LV_ALIGN_IN_BOTTOM_MID, 0, 0);
lv_obj_t* signal = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(signal, LV_SYMBOL_WIFI);
lv_obj_align(signal, NULL, LV_ALIGN_IN_TOP_LEFT, 0, 0);
lv_obj_t* battery = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(battery, LV_SYMBOL_BATTERY_FULL);
lv_obj_align(battery, NULL, LV_ALIGN_IN_TOP_RIGHT, 0, 0);
lv_obj_t* clock = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(clock, "17:00");
lv_obj_align(clock, NULL, LV_ALIGN_IN_TOP_MID, 0, 0);
lv_obj_t* ID = lv_label_create(lv_scr_act(), NULL);
lv_label_set_text(ID, "101");
lv_obj_align(ID, battery, LV_ALIGN_IN_TOP_RIGHT, 0, 20);
signal_speed_create();
/*Create the custom map for the keyboard*/
static const char* kb_map[] = {
"1", "2", "3",LV_SYMBOL_BACKSPACE,"\n",
"4", "5", "6",LV_SYMBOL_CLOSE,"\n",
"7", "8", "9"," ","\n",
"0", LV_SYMBOL_LEFT, LV_SYMBOL_RIGHT," ",""
static const lv_btnmatrix_ctrl_t kb_ctrl[] = {
LV_BTNMATRIX_CTRL_NO_REPEAT, LV_BTNMATRIX_CTRL_NO_REPEAT, LV_BTNMATRIX_CTRL_NO_REPEAT, LV_BTNMATRIX_CTRL_NO_REPEAT,
LV_BTNMATRIX_CTRL_NO_REPEAT, LV_BTNMATRIX_CTRL_NO_REPEAT, LV_BTNMATRIX_CTRL_NO_REPEAT, LV_BTNMATRIX_CTRL_HIDDEN,
/* Create a keyboard*/
kb = lv_keyboard_create(lv_scr_act(), NULL);
lv_obj_set_size(kb, LV_HOR_RES/2, LV_VER_RES / 3);
lv_obj_align(kb, NULL, LV_ALIGN_IN_BOTTOM_MID, 0, 0);
lv_keyboard_set_mode(kb, LV_KEYBOARD_MODE_NUM);
lv_keyboard_set_map(kb, LV_KEYBOARD_MODE_NUM, kb_map);
lv_keyboard_set_ctrl_map(kb, LV_KEYBOARD_MODE_NUM, kb_ctrl);
lv_keyboard_set_textarea(kb, ta);
if (event == LV_EVENT_CLICKED) {
kb_create();
/*Create the text area*/
lv_obj_t* ta = lv_textarea_create(lv_scr_act(), NULL);
lv_obj_set_event_cb(ta, ta_event_cb);
lv_textarea_set_accepted_chars(ta, "0123456789");
lv_textarea_set_one_line(ta, true);
lv_textarea_set_text(ta, "");
lv_obj_align(ta, NULL, LV_ALIGN_CENTER, 0, 0);
Thanks,
Best regards,
