Before posting
masterbranch.- Read the
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "freertos/task.h"
#include "soc/soc_caps.h"
#include "esp_log.h"
#include "esp_adc/adc_oneshot.h"
#include "esp_adc/adc_cali.h"
#include "esp_adc/adc_cali_scheme.h"
#include "esp_timer.h"
#include "esp_lcd_panel_io.h"
#include "esp_lcd_panel_ops.h"
#include "driver/i2c.h"
#include "esp_err.h"
#include "lvgl.h"
#include "esp_lvgl_port.h"
#if CONFIG_EXAMPLE_LCD_CONTROLLER_SH1107
#include "esp_lcd_sh1107.h"
#else
#include "esp_lcd_panel_vendor.h"
static const char *TAG = "example";
#define I2C_HOST 0
// #define LV_COLOR_DEPTH 1
#define EXAMPLE_LCD_PIXEL_CLOCK_HZ (400 * 1000)
#define EXAMPLE_PIN_NUM_SDA 4
#define EXAMPLE_PIN_NUM_SCL 5
#define EXAMPLE_PIN_NUM_RST -1
#define EXAMPLE_I2C_HW_ADDR 0x3C
// The pixel number in horizontal and vertical
#if CONFIG_EXAMPLE_LCD_CONTROLLER_SSD1306
#define EXAMPLE_LCD_H_RES 128
#define EXAMPLE_LCD_V_RES 64
#elif CONFIG_EXAMPLE_LCD_CONTROLLER_SH1107
#define EXAMPLE_LCD_H_RES 64
#define EXAMPLE_LCD_V_RES 128
// Bit number used to represent command and parameter
#define EXAMPLE_LCD_CMD_BITS 8
#define EXAMPLE_LCD_PARAM_BITS 8
//ADC1 Channels
#define EXAMPLE_ADC1_CHAN0 ADC_CHANNEL_2
#define EXAMPLE_ADC_ATTEN ADC_ATTEN_DB_11
static int adc_raw[2][10];
static int voltage[2][10];
static bool example_adc_calibration_init(adc_unit_t unit, adc_channel_t channel, adc_atten_t atten, adc_cali_handle_t *out_handle);
static void example_adc_calibration_deinit(adc_cali_handle_t handle);
adc_cali_handle_t adc1_cali_chan0_handle = NULL;
static lv_timer_t* s_ecg_timer;
static lv_obj_t* s_ecg_label;
static bool notify_lvgl_flush_ready(esp_lcd_panel_io_handle_t panel_io, esp_lcd_panel_io_event_data_t *edata, void *user_ctx)
lv_disp_t * disp = (lv_disp_t *)user_ctx;
lvgl_port_flush_ready(disp);
return false;
static void draw_test_patterns(lv_obj_t * scr) {
// 绘制一个矩形
lv_obj_t * rect = lv_obj_create(scr);
lv_obj_set_size(rect, 50, 50);
lv_obj_set_pos(rect, 15, 15);
// 设置矩形背景颜色为白色
lv_obj_set_style_bg_color(rect, lv_color_white(), LV_PART_MAIN);
lv_obj_set_style_bg_opa(rect, LV_OPA_COVER, LV_PART_MAIN);
// lv_obj_set_style_bg_color(rect, lv_color_white(), LV_PART_MAIN); // 设置为白色
// 绘制一条线条
lv_obj_t * line = lv_line_create(scr);
static lv_point_t line_points[] = { {10, 70}, {60, 70} };
lv_line_set_points(line, line_points, 2); /* Set the points */
lv_obj_set_style_line_width(line, 2, LV_PART_MAIN);
lv_obj_set_style_line_color(line, lv_color_white(), LV_PART_MAIN); // 设置为白色
void app_main(void)
//-------------ADC1 Init---------------//
adc_oneshot_unit_handle_t adc1_handle;
adc_oneshot_unit_init_cfg_t init_config1 = {
.unit_id = ADC_UNIT_1,
ESP_ERROR_CHECK(adc_oneshot_new_unit(&init_config1, &adc1_handle));
//-------------ADC1 Config---------------//
adc_oneshot_chan_cfg_t config = {
.bitwidth = ADC_BITWIDTH_DEFAULT,
.atten = EXAMPLE_ADC_ATTEN,
ESP_ERROR_CHECK(adc_oneshot_config_channel(adc1_handle, EXAMPLE_ADC1_CHAN0, &config));
//-------------ADC1 Calibration Init---------------//
bool do_calibration1_chan0 = example_adc_calibration_init(ADC_UNIT_1, EXAMPLE_ADC1_CHAN0, EXAMPLE_ADC_ATTEN, &adc1_cali_chan0_handle);
//-------------Initialize I2C---------------//
ESP_LOGI(TAG, "Initialize I2C bus");
i2c_config_t i2c_conf = {
.mode = I2C_MODE_MASTER,
.sda_io_num = EXAMPLE_PIN_NUM_SDA,
.scl_io_num = EXAMPLE_PIN_NUM_SCL,
.sda_pullup_en = GPIO_PULLUP_ENABLE,
.scl_pullup_en = GPIO_PULLUP_ENABLE,
.master.clk_speed = EXAMPLE_LCD_PIXEL_CLOCK_HZ,
ESP_ERROR_CHECK(i2c_param_config(I2C_HOST, &i2c_conf));
ESP_ERROR_CHECK(i2c_driver_install(I2C_HOST, I2C_MODE_MASTER, 0, 0, 0));
ESP_LOGI(TAG, "Install panel IO");
esp_lcd_panel_io_handle_t io_handle = NULL;
esp_lcd_panel_io_i2c_config_t io_config = {
.dev_addr = EXAMPLE_I2C_HW_ADDR,
.control_phase_bytes = 1, // According to SSD1306 datasheet
.lcd_cmd_bits = EXAMPLE_LCD_CMD_BITS, // According to SSD1306 datasheet
.lcd_param_bits = EXAMPLE_LCD_CMD_BITS, // According to SSD1306 datasheet
.dc_bit_offset = 6, // According to SSD1306 datasheet
.dc_bit_offset = 0, // According to SH1107 datasheet
.flags =
.disable_control_phase = 1,
ESP_ERROR_CHECK(esp_lcd_new_panel_io_i2c((esp_lcd_i2c_bus_handle_t)I2C_HOST, &io_config, &io_handle));
ESP_LOGI(TAG, "Install SSD1306 panel driver");
esp_lcd_panel_handle_t panel_handle = NULL;
esp_lcd_panel_dev_config_t panel_config = {
.bits_per_pixel = 1,
.reset_gpio_num = EXAMPLE_PIN_NUM_RST,
ESP_ERROR_CHECK(esp_lcd_new_panel_ssd1306(io_handle, &panel_config, &panel_handle));
ESP_ERROR_CHECK(esp_lcd_new_panel_sh1107(io_handle, &panel_config, &panel_handle));
ESP_ERROR_CHECK(esp_lcd_panel_reset(panel_handle));
ESP_ERROR_CHECK(esp_lcd_panel_init(panel_handle));
ESP_ERROR_CHECK(esp_lcd_panel_disp_on_off(panel_handle, true));
ESP_ERROR_CHECK(esp_lcd_panel_invert_color(panel_handle, true));
ESP_LOGI(TAG, "Initialize LVGL");
const lvgl_port_cfg_t lvgl_cfg = ESP_LVGL_PORT_INIT_CONFIG();
lvgl_port_init(&lvgl_cfg);
const lvgl_port_display_cfg_t disp_cfg = {
.io_handle = io_handle,
.panel_handle = panel_handle,
.buffer_size = EXAMPLE_LCD_H_RES * EXAMPLE_LCD_V_RES,
.double_buffer = true,
.hres = EXAMPLE_LCD_H_RES,
.vres = EXAMPLE_LCD_V_RES,
.monochrome = true,
.rotation = {
.swap_xy = false,
.mirror_x = false,
.mirror_y = false,
lv_disp_t * disp = lvgl_port_add_disp(&disp_cfg);
if (disp == NULL) {
ESP_LOGE(TAG, "Failed to add display");
return;
const esp_lcd_panel_io_callbacks_t cbs = {
.on_color_trans_done = notify_lvgl_flush_ready,
esp_lcd_panel_io_register_event_callbacks(io_handle, &cbs, disp);
lv_disp_set_rotation(disp, LV_DISP_ROT_NONE);
ESP_LOGI(TAG, "Display LVGL Scroll Text");
lv_obj_t *scr = lv_disp_get_scr_act(disp);
lv_obj_t *label = lv_label_create(scr);
lv_obj_set_width(label, disp->driver->hor_res);
lv_obj_align(label, LV_ALIGN_LEFT_MID, 0, 0);
draw_test_patterns(scr);
lv_obj_t * chart = lv_chart_create(lv_scr_act());
lv_obj_set_size(chart, EXAMPLE_LCD_H_RES - 10, EXAMPLE_LCD_V_RES - 10);
lv_obj_center(chart);
lv_chart_set_point_count(chart, 10);
lv_chart_set_type(chart, LV_CHART_TYPE_LINE);
lv_chart_set_range(chart, LV_CHART_AXIS_PRIMARY_Y, 10, 3000);
lv_chart_series_t * series = lv_chart_add_series(chart, lv_color_white(), LV_CHART_AXIS_PRIMARY_Y);
lv_chart_set_update_mode(chart, LV_CHART_UPDATE_MODE_CIRCULAR);
while (1) {
ESP_ERROR_CHECK(adc_oneshot_read(adc1_handle, EXAMPLE_ADC1_CHAN0, &adc_raw[0][0]));
ESP_LOGI(TAG, "ADC%d Channel[%d] Raw Data: %d", ADC_UNIT_1 + 1, EXAMPLE_ADC1_CHAN0, adc_raw[0][0]);
if (do_calibration1_chan0) {
ESP_ERROR_CHECK(adc_cali_raw_to_voltage(adc1_cali_chan0_handle, adc_raw[0][0], &voltage[0][0]));
ESP_LOGI(TAG, "ADC%d Channel[%d] Cali Voltage: %d mV", ADC_UNIT_1 + 1, EXAMPLE_ADC1_CHAN0, voltage[0][0]);
char disp_buf[32];
snprintf(disp_buf,sizeof(disp_buf),"%.1f",(float)voltage[0][0]);
lv_label_set_text(label,disp_buf);
lv_chart_set_next_value(chart, series, voltage[0][0]);
// read_chart_points(chart, series);
// // 刷新 chart 以显示数据
lv_chart_refresh(chart);
lv_task_handler();
vTaskDelay(pdMS_TO_TICKS(1000));
//Tear Down
ESP_ERROR_CHECK(adc_oneshot_del_unit(adc1_handle));
example_adc_calibration_deinit(adc1_cali_chan0_handle);
ADC Calibration
adc_cali_handle_t handle = NULL;
esp_err_t ret = ESP_FAIL;
bool calibrated = false;
#if ADC_CALI_SCHEME_CURVE_FITTING_SUPPORTED
if (!calibrated) {
ESP_LOGI(TAG, "calibration scheme version is %s", "Curve Fitting");
adc_cali_curve_fitting_config_t cali_config = {
.unit_id = unit,
.chan = channel,
.atten = atten,
ret = adc_cali_create_scheme_curve_fitting(&cali_config, &handle);
if (ret == ESP_OK) {
calibrated = true;
*out_handle = handle;
ESP_LOGI(TAG, "Calibration Success");
} else if (ret == ESP_ERR_NOT_SUPPORTED || !calibrated) {
ESP_LOGW(TAG, "eFuse not burnt, skip software calibration");
} else {
ESP_LOGE(TAG, "Invalid arg or no memory");
return calibrated;
ESP_LOGI(TAG, "deregister %s calibration scheme", "Curve Fitting");
ESP_ERROR_CHECK(adc_cali_delete_scheme_curve_fitting(handle));
