I’m using esp32, arduino, developing with Visual Studio 2022 LVGL v9.2
I’ve recently been shown how to use animations and timeline.
It is a fantastic feature and I can now move an image around the screen.
My code works well, but I need to pause and continue the timeline.
Whilst you can pause a timeline with lv_anim_timeline_pause,
there doesn’t appear to be continue option.
If I start it again, I get a new image, and an image artefact on the screen.
Pause and restart a few times and it gets messy.
My code for the timeline is:-
lv_obj_t* supply_arrow;
lv_anim_timeline_t* supply_arrow_timeline;
void create_supply_arrow_anim(void)
// arrow object
//LV_IMG_DECLARE(arrows_down_25_25);
supply_arrow = lv_img_create(lv_scr_act());
//lv_obj_t* img2 = lv_img_create(lv_scr_act());
lv_img_set_src(supply_arrow, &arrows_down_25_25);
//lv_img_set_src(img2, &arrows_down_25_25);
lv_obj_set_size(supply_arrow, 150, 150);
//lv_obj_set_size(img2, 150, 150);
lv_obj_set_pos(supply_arrow, IMPORT_EXPORT_ARROW_X_POS, IMPORT_EXPORT_ARROW_Y_POS);
//lv_obj_set_pos(img2, IMPORT_EXPORT_ARROW_X_POS, IMPORT_EXPORT_ARROW_Y_POS + 100);
//lv_image_set_rotation(img2, 900);
//Arrow down
int arrow_finish_pos = IMPORT_EXPORT_ARROW_Y_POS + 90;
lv_anim_t a1;
lv_anim_init(&a1);
lv_anim_set_var(&a1, supply_arrow);
lv_anim_set_values(&a1, IMPORT_EXPORT_ARROW_Y_POS, arrow_finish_pos);
lv_anim_set_duration(&a1, 1000);
//lv_anim_set_repeat_delay(&a1, 50);
//lv_anim_set_repeat_count(&a1, LV_ANIM_REPEAT_INFINITE);
lv_anim_set_exec_cb(&a1, anim_y_cb);
//lv_anim_start(&a1);
//arrow rotate
lv_anim_t a2;
lv_anim_init(&a2);
lv_anim_set_var(&a2, supply_arrow);
lv_anim_set_values(&a2, 0, 900);
lv_anim_set_duration(&a2, 1000);
lv_anim_set_exec_cb(&a2, anim_r_cb);
//Arrow left
lv_anim_t a3;
lv_anim_init(&a3);
//lv_obj_set_pos(img1, 150, arrow_finish_pos+20);
lv_anim_set_var(&a3, supply_arrow);
lv_anim_set_values(&a3, 300, 100);
lv_anim_set_duration(&a3, 1000);
//lv_anim_set_repeat_delay(&a2, 50);
//lv_anim_set_repeat_count(&a2, LV_ANIM_REPEAT_INFINITE);
lv_anim_set_exec_cb(&a3, anim_x_cb);
//lv_anim_start(&a2);
//create animation timeline
supply_arrow_timeline = lv_anim_timeline_create();
lv_anim_timeline_add(supply_arrow_timeline, 0, &a1);
lv_anim_timeline_add(supply_arrow_timeline, 850, &a2);
lv_anim_timeline_add(supply_arrow_timeline, 1600, &a3);
lv_anim_timeline_start(supply_arrow_timeline);
//lv_anim_t* a = lv_anim_timeline_get_anim_progressing(supply_arrow_timeline);
//lv_anim_set_repeat_count(a, LV_ANIM_REPEAT_INFINITE);
//delay(2000);
//lv_anim_timeline_get lv_anim_timeline_get_progress(anim_timeline);
//lv_anim_timeline_pause(supply_arrow_timeline);
//delay(1000);
//lv_anim_timeline_start(anim_timeline);
void stop_supply_arrow_anim(void) {
//supply_arrow = NULL;
void start_supply_arrow_anim(void) {
I’ve tried using lv_anim_timeline_start.
I’ve tried
Before posting
