Before posting
masterbranch.- Read the
I am just trying to display a button with some text.. I see three buttons instead and text looks like garbage excpet on one button
Nrf5340 MCU, Custom board, RM69090 Display controller (QSPI), 320%360 AMOLED display. Zephyr RTOS with Nordic NCS (SDK) with built-in gcc tools)
NCS version: 1.5.1
LVGL version: ## v7.6.1 (06.10.2020)
Zephyr RTOS version: 2.4.99
Get a button displayed on the screen but i see three identical buttons
Went through he documentation (pretty good), porting section, your git hub, zephyr’s (poor) VGVL documentation.. code compiles and there are no errors/crashes.. But the button shows up 3 times and text is surely not very clear. I don’t care for the button press getting recognized (yet) as I have not looked into integrating touch controller driver with lvgl yet. Just want to see a single button with text is all I am looking for right now. AS mentioned, I see multiple buttons when i am coding for just one (or so I think)
void btn_event_cb(lv_obj_t * btn, lv_event_t event) {
printf("Clicked\n");
void set_button(void) {
lv_obj_t * btn = lv_btn_create(lv_scr_act(), NULL); /*Add a button to the current screen*/
lv_obj_set_pos(btn, 10, 10); /*Set its position*/
lv_obj_set_size(btn, 150, 100); /*Set its size*/
lv_obj_set_event_cb(btn, btn_event_cb); /*Assign a callback to the button*/
lv_obj_t * label = lv_label_create(btn, NULL); /*Add a label to the button*/
lv_label_set_text(label, "Button"); /*Set the labels text*/
void main(void) {
//lots of hardware init stuff here
/* Initialize the device */
display_dev = device_get_binding(DISPLAY_DEV_NAME); //(CONFIG_LVGL_DISPLAY_DEV_NAME);
if (!display_dev) {
printk("Binding Display failed... will loop for ever");
return;
set_button();
lv_task_handler();
display_get_chipid(display_dev); //gets the chip id of the display controller)
